Question about Toshiba Satellite A105 Notebook
A105 MB... I was attempting to replace a cmos battery, when I noticed it was clipped on top and bottom, so I decided to close case and get more info on this issue. But now, the power and battery lights are the only thing tyhat comes on. What can I do? Could it be the MB or CPU failed? Urgent!!!
  • 33 Answers
HI
Plz make sure you didnt touch any other device while attempting to change the cmos battery.
Open the laptop again, and make sure things are in the right place & Cables ar well connected.
I hope you fix this.
Posted on Nov 06, 2008
    Scholar:
  • 181 Answers
Hi,Can I ask why you were replacing the cmos battery? Check your memory; uninstall and re-install. Good luck
Posted on Aug 19, 2007
  • 58 Answers
Make sure before u close u connected all the ribbon wire's and socket before u close. Check if the monitor connecting plug or wires are all connected u see this connection most on the back upper side of your laptop. This maybe accidentally disconnect when you open the cover. Good luck Hope this may help
Posted on Aug 06, 2007
  • 65 Answers
Remove the main battery, (not the cmos battery) remove the power adapter from the laptop. Plug in the laptop with the battery still out. This should reset the power logic.
SOURCE:
WHERE IS THE BIO BATTERY LOCATED
Acer Aspire cmos battery
Remove the Phillips screws that secure the motherboard cover (refer to your owner's manual if necessary), then release the cover from the clips on the bottom of the plastic casing.
Lay the cover aside, then locate the CMOS battery cable on the right side of the motherboard. Unplug the cable, then remove the battery.
http://www.youtube.com/watch?v=cg_wvp1YdSI
laptop cmos battery
Mar 08, 2013 | Acer Aspire Computers & Internet
Tip
How to replace the CMOS battery in an Acer Aspire laptop.
General info
All laptops have a CMOS battery. The main purpose for the CMOS battery is to store the system time, date and BIOS settings even if the computer is turned off or the main battery dies. Individual Acer Aspire laptop models differ somewhat, but the general steps are the same when replacing a dead CMOS battery.
Before you start
1) Read through the owner's manual for your particular Acer Aspire laptop to determine what kind of CMOS battery you need.
2) Purchase the battery through Acer or a local or online computer parts dealer.
3) Turn the laptop off and unplug it. Also unplug any external hard drives, cameras, or other external devices.
4) Turn the laptop over (bottom facing up), then touch something metal to remove static charge.
Removal of the CMOS battery
Remove the Phillips screws that secure the motherboard cover (refer to your owner's manual if necessary), then release the cover from the clips on the bottom of the plastic casing. Lay the cover aside then locate the CMOS battery cable on the right side of the motherboard. Unplug the cable then remove the battery.
The battery should look something like this
Plugging the new battery in
Plug the new CMOS battery cable into the motherboard. Slide the battery partially under the laptop casing (somewhere to hold it in place), then align the cover with the slots on the bottom of the laptop housing. Replace the screws then turn the laptop back over.
Finalizing
1) Turn the laptop on.
2)Enter your BIOS (usually by pressing the "Delete" key) before the operating system loads.
3) Follow the BIOS prompts or refer to your Acer Aspire owner's manual to reset your time, date and desired system settings.
Reason: Anytime the CMOS battery is unplugged for more than a few seconds your BIOS will be reset to the default manufacturer settings. If you make any changes to the BIOS that cause problems with your Acer Aspire, unplug the CMOS battery for 3 to 5 seconds to correct the problem.
Please rate this tip by clicking the thumbs up at the bottom right of this solution. Your rating is much appreciated.
<SPAN style="LINE-HEIGHT: 115%; FONT-FAMILY: 'Arial','sans-serif'; COLOR: black; FONT-SIZE: 10pt; mso-fareast-font-family: 'Times New Roman
on Nov 12, 2010 | Computers & Internet
Replace bios battery
http://www.asus.com/Motherboard/P5KPLAMPS/
FOLLOW Anti-Static Precautions
Anti-Static Precautions:
Your body carries Static electricity. Static WILL fry out (Short Circuit), the delicate hardware components inside a computer.
Relieve your body of Static BEFORE, reaching inside your unplugged from power, computer.
Computer on a table, computer unplugged from power, computer case open;
TOUCH an unpainted surface of the metal frame, of the open computer case.
This action will relieve your body of Static.
IF, you leave your computer in the middle of working on it, be SURE to Touch the metal frame again, upon your return.
Motherboard installed in computer case, the CMOS battery, (BIOS battery), is located at the Bottom/Right corner; above the four Red SATA connectors.
The CMOS Battery holder has a lock clip on one side.
This clip is eased to the Outside edge, in order to release the CR2032 CMOS Battery. (A type of watch battery)
Suggest use a stiff plastic object to release lock clip.
Most however, use a small Jewelers flat tipped screwdriver.
You want to JUST press on the Lock Clip itself.
The battery should just pop-up a little. Then a fingernail is used to lift that side up, to access the battery.
When reinstalling remember the Positive ( + ) side ALWAYS goes UP.
After locking the new battery in, make sure no cables were accidentally pulled loose.
Also just for ease of mind, try to push the Ram Memory module/s in ('Stick') more. Make sure the Locks on both ends are locked in place.
A lot of times the Ram Memory modules get bumped loose, accidentally.
Close the computer case. Plug computer back into power.
WAIT 1 minute, turn the computer on.
Go to the taskbar at the bottom of the Windows screen, and to the right.
-> Right-click on the Time.
Now reset the Date/Time to what it should be.
Need guidance on that post back in a Comment.
Regards,
joecoolvette
Feb 28, 2013 | ASUS P5KPL-AM/PS Motherboard
Bios password has me lock out
Yes there is. What you need to do is remove the backup battery on the motherboard (disc shapped mercury battery).This will default your BIOS
Mar 17, 2010 | Toshiba Satellite A105 Notebook
Motherboard Shuttle FS51 Problem losing date and time when off for a while. Believe new CMOS battery needed Are you able to advise the type/ number and voltage of suitable battery. Are you able to advise...
The CMOS battery you need is a CR2032 3V battery. You can get them from places like Radioshack, PC World or any good computer store.
Click on the link that I have provided below, it takes you through to Radioshack where you will see the battery for yourself>>>>>
http://www.radioshack.com/pwr/product-reviews/Power-Batteries/Home-office-power/Calculator-watch-batteries/RadioShack/p/2062105-CR2032-3V-230mAh-High-Energy-Lithium-Battery.html
Regards.
Feb 04, 2010 | Computers & Internet
I have a satellite A105 and When i turn it on it asks for password but I don't have the password. So how to I get past this to be able to use it again?
just remove the cmos battery
the bios stores the password and the cmos battery provides it power to store it
if you remove cmos battery the bios reverts to factory settings and the password is removed
cmos battery is different than the laptop backup battery
cmos battery is found inside the laptop case on the motherboard, you will have to open the laptop to remove the cmos battery
Sep 29, 2009 | Toshiba Satellite A105 Notebook
MY PC HAS BOOTING PROBLEM
Hi bridey28, when you replaced the cmos battery & the bios did not maintain the correct time than the cmos is not at fault. More likely its your power supply. The cmos receives its power (Recharge) from the power supply. An average cmos battery should last for 5 years. The fact that you attempt to power up the PC & you have to wait, points to a power supply problem. Not a bios problem.
Bios corruption is rare, unless you have tried to flash the bios & it failed. Replace the power supply before attempting flashing the bios. Every manufacture warns against flashing the bios. Only flash the bios if your 100% sure that it will correct a bios malfunction. If the issue presist after replacing the power supply, Intel has instructions of (How to flash the bios) on their site.
Here are the instruction from Intel for your MB model number.
http://downloadmirror.intel.com/5519/ENG/BIOS%20Update%20Readme.pdf
You'll need this link to download the bios file;
http://downloadcenter.intel.com/filter_results.aspx?strTypes=all&ProductID=899&OSFullName=Windows*+XP+Home+Edition&lang=eng&strOSs=45&submit=Go%21#SAP
Good luck bridey28!
Need more info, post here.
Mike
Jan 14, 2009 | Computers & Internet
How to safely remove the CMOS battery
The battery is a button type battery, you can release by pressing the metal clip to the side and the battery should pop up, if not use a thin blade screw driver to lift the battery up whilst pressing the metal clip to the side, Do not hold the battery (top & bottom) with metal tweeters, you will create a short circuit condition.
Dec 21, 2008 | Toshiba Satellite A105 Notebook
Need to reset bios password for acer 4620 laptop. tryed removing battery on mb . no good . ? passmord bios
Try removing the main battery and the CMOS battery (ie the battery on the mb). If you don't want to wait for 1/2 hour for the CMOS to discharge then short out the CMOS battery connections with a bent paper clip.
Then without instralling both battery, power up your laptop, you should then get into the BIOS, power off and re-install your batteries.
Aug 19, 2008 | Computers & Internet
Cmos Battery
Look for the CMOS Battery under the keyboard, if not near the memory at the bottom of the laptop, there are screws to remove.
Hope this Fixya an idea where the battery is kept.
Feb 08, 2008 | Toshiba Satellite A105 Notebook
Toshiba Satellite A105 Notebook Logo
139 people viewed this question
Top Toshiba Computers & Internet Experts
Ekse
Alun Cox
Are you a Toshiba Computer and Internet Expert? Answer questions, earn points and help others
