Question about RCA CC-439 Camcorder
RCA DSP3 CC493 VHS camcorder
I need a manual fast and bad plz got this at garage sale and I got the battery and strap to carry it and dc plug and battery charger but i charge the battery and it wont work i put it in the camcorder and it doesent turn on plz help me get a manual i looked all over online
SOURCE: RCA 400x Digital Zoom Mini DV Camcorder
I've got the same problem the only option is to purchase a new cord for 102.50 that I've found.
Posted on Jun 26, 2007
Benimur
  • 6966 Answers
SOURCE: RCA cc540 VHS camcorder
Hi, Try running the camera using the AC power (charger) instead of the battery. If the viewfinder works then, it is possible that the replacement battery somehow is not suited for your particular brand/model and is not capable of supplying all the need voltages/power. Try continuously charging the battery for 16 hrs at least to see if this will correct the problem. If even in using the AC power (adapter) instead of the battery, the view finder is still off, then you have a camera fault. Normal problem for this is the thin flexible flat cable that attaches the screen to the electronics inside the camera. In some case, it is the backlight of the display that is at fault. Either which would require the services of a qualified professional. Hope this be of some help/idea to you. Good luck and kind regards.
Posted on Aug 24, 2007
SOURCE: RCA camcorder CC4352 damaged DC cable
My son has the same model camcorder so we are taking turns using the DC cable.
Posted on Sep 17, 2008
biigg53566
  • 89 Answers
SOURCE: need the battery
Have you tried Batteries Plus near you or go online to www.batteriesplus.com
they list both the batteries and the chargers for this model of camcorder
Posted on Nov 18, 2008
  • 4234 Answers
SOURCE: RCA VHS CAMCORDER
Let us attack this from a different perspective. What is the problem with the camcorder? Typical labor rates will be in the $150 range, so you are looking at that much for the repair without parts. Please update this with a problem description and I'll try to provide you with what needs to be done to fix it.
Thanks,
Dan
Posted on Dec 08, 2008
How do we charge this chair?
off board chargers plug into the front of the joystick. after 10-12 hrs the chair should be charged, Unless the batteries are bad, or the charger is bad. Plug into joystick before power cord into wall outlet. also charge every night!
Mar 15, 2016 | Health & Beauty
Tip
Samsung TL205 Battery Charger Samsung TL205 Charger
With the most high-quality camera battery charger,
Description: Home Travel Charger
Input Voltage (AC): 100-240V 50-60HZ
Car Input Voltage (DC): 12-24V
Output Voltage: 4.2V/8.4V
Output Current: 600mA
Dimensions: 1.86" x 3.33" x 1.50"
Weight: 2.5oz (85g)
Color: Black
Features:
A. Direct Plug-In wall Samsung TL210 Battery Charger - No cable necessary
B. Samsung TL210 Battery Charger Output: DC 4.2V 600mA
C. 110-220 Volts - Works in every country in the world
D. AC Car Adapter - Charge your battery at home or in your car
E. Fast Charger 800mA - Charges most batteries in 60-120 minutes
F. LED Charger Indicator - Red light: needs charging, Green light: charging is complete
G. Samsung TL210 Digital Camera Battery with Manufacturer's 1 Year Warranty.
H. The Samsung TL210 Battery Charger is for charging your battery only. It does not work as AC adapter for your camera
on Sep 21, 2010 | Cameras
Battery and or charger won't work. Charged a full 18 hrs. Help
Possible suspects are:
1. A severely drained battery.
2. Check battery terminals for damage or corrosion, check the battery cables at "BOTH" ends for loose, corroded, or broken connectors, "INSIDE" and outside the cable harness, perform connector wiggle test and check cables with an ohmmeter if necessary.
3. Faulty main circuit breaker and or connections.
4. Faulty ignition coil and or connections.
5. Faulty spark plug, oil or gas fouled, wrong heat range or service type, wrong gap, loose in the cylinder head, broken electrode or insulator.
6. Faulty spark plug cables, leaking or broken, internal damage.
7. Faulty ignition module, switch, CKP, MAP, CMP, sensor and or any connector in the ignition circuit could have corroded, loose, or broken pins/sockets
8. Burnt exhaust valve or air leak in the exhaust system.
Nov 27, 2015 | Motorcycles
My car's 12 volt battery died 1 week ago. i bought and attached the Schumacher XC6-CA battery charger. The battery's fluids are good and i bought the battery in mid 2012. How long should it take for
if the battery is flat and below 5 volts the charger on digital charger dont charge, you need an old charger one with a 4 to 6 amp charging capacity to charge the battery, digital chargers have a safety device on them to stop the charger from working as when a battery becomes faulty it stops charging.
Aug 02, 2017 | Electrical Supplies
I need a user's manual for Voltcraft Fast Charge Delta Peak model MW3610HC. I believe it is a battery pack charger. It is a Europian product that requires a U.S. AC adapter. I want to know what size...
SPECYFIKACJA :
  • V detection
  • Cigarette lighter plug
  • Double output
  • Discharge function
  • Dla Ni-Cd/ Ni-MH battery
  • Input voltage: 230V AC, 50Hz, 13.8V do 24V DC
  • Output :
  • Dla 230V AC or 24V DC input: 5.6V DC (4 celle) do 11.2V DC (8 cell)
    • Dla 24V AC input: 5.6V DC (4 celle) do 8.4V DC (6 cell)
  • Output regulowany : 1,000/2,000/3,000mA
Sep 04, 2011 | Vacuums
I purchased a lot sale from a garage sale. One of the items in the lot was a Jumper 850 car battery charger manufactured by Century Mfg. Co. How do I charge the charger? It didn't come with any...
You should have a ac to dc converter plug to charge it.
http://www.centurytool.net/OUTPAC_900_Peak_Amp_12_Volt_Jump_Starter_s/176.htm
http://www.centurytool.net/ESA22_Charger_W_Small_Jack_p/esa22.htm
Jul 17, 2011 | GPS
My stinger light will not take charge,if i use my other light i can charge the battery. what it can be the problem
All batteries go bad eventually. Heat is bad for them, as well as freezing. Slow charging is better than fast charging. Often if I take the built in batteries in to a electronics place, I can get cheap replacements that can easily be soldered in. Hobby shops are good for this, because they go through batteries so quickly on radio controlled toys.
Feb 24, 2011 | Stinger Streamlight XT Rechargeable...
Hi left my garmin gps 265 plugged in my car for 2 weeks it doesnt light up anymore whats the problem can yu let me know plz
If your garmin nuvi does not turn on, then you need to carry out some test. First is for you to test the battery by trying it out on another nuvi, to do that, insert the battery in another nuvi, charge it for about 2 hours, then try to power it on. If it comes on, then the battery is alright, but if it does not come on, then, it is obvious that the battery is bad and the solution is for you to replace it with a new one.
Another test is for you to test the charger. Try to use the charger on another gps, if it charges, then it is okay, but if it does not, then the charger is bad and need no be replaced.
After carrying out the test and both the charger and the battery seem to be okay, connect your nuvi to your computer to see if it comes on and charges. If it does not come on, then there is an internal problem or something.
Dec 24, 2010 | Garmin n?vi 265WT Car GPS Receiver
My battery will not charge
Hello Following issue could be possible
Issue:Main computer battery does not charge.
Cause:This issue can be caused by any of the below possibilities.
  1. Computer AC / DC cable is bad not allowing the computer battery to charge.
  2. Battery is bad.
  3. Battery charger board is bad.
Solutions:
Verify that the AC and or DC cable is not bad by testing the computer only with the power plug connected and the battery out of the laptop.
Battery is bad
It is possible that if the power plug is good that the computer battery is bad. Leave the computer connected to the power with the battery connected in the computer for at least one hour; if the battery does not charge, consider having the battery and/or the laptop serviced or repaired.
If the computer and/or battery is not in warranty consider just replacing the battery as it is very likely that it is just a bad battery.
If the battery has been replaced or an alternate battery from an alternate identical laptop does not work in the computer, it is likely that the power or charger board within the laptop is bad. It is recommended that the laptop be serviced or repaired.
Aug 18, 2009 | Computers & Internet
When i plug in my charger to my laptop it doesnt work and i dont know whats wrong with it
This issue can be caused by any of the below possibilities. 1.- Computer AC / DC cable is bad not allowing the computer battery to charge.
2.- Battery is bad.
3.- Battery charger board is bad.
Solutions:
2.- Battery is bad
This will fix your problem.
Don't forget to rate my help! :-)
Thank you for using FIXYA!
Pablo
Oct 14, 2008 | Computers & Internet
RCA CC-439 Camcorder Logo
95 people viewed this question
Top RCA Video Cameras Experts
Lawrence Oravetz
abdul rauf
abdul rauf
Are you a RCA Video Camera Expert? Answer questions, earn points and help others
