Question about Xantrex Technology Heart Freedom 20 12 Inverter
No inverting for appliances or?
Since buying, used, my Monaco Knight 2002, the inverter has never worked in regards to getting 110 use while parked without exterior source. Green invert flashes like the book says I can turn off and on charge like the book says and select battery type(wet) but cannot get invert to power interior lights/ any plugs or microwave, tv etc. And the remote panel (tested in another RV and showed good) does not light up. It once did, but when the invert button was pushed, nada Then suddenly it stopped lighting up ??????
3 Suggested Answers
nitrospawn
  • 290 Answers
SOURCE: inverter is draining house batterys on rv
it is possible that you batteries are bad, if you have used it for over a year you will need to replace it with new ones
Posted on Feb 25, 2010
SOURCE: Freedom 20 Inverter/Converter Charger installed
Second Freedom 25 inverter/charger...first one repaired, this one went to fault...started microwave on fire, fried the satillite receiver and possibly other components....installing a Mangnum....."do not let anyone rebuild the Freedom 25" First time about $900.00 to rebuild...this time about $9000.00 with components it fried. Fleetwood LLC Corporate knows of problems and only offer to sell you the conversion kit for about $4200.00....bankruptcy sanctifies previous problems "they" left with us.
Posted on Jun 22, 2011
How can I install a apple tv into my 2014 ford explorer?
??.. You can get an inverter to supply 110 voltage..(or get a 12V TV).. what about reception?.. guess you could use an antenna... This is new to me... sorry..
Inverters Us Your DC to AC Power Inverter Superstore
I know it sounds corny.. this is the only place I buy mine from.. (3) ..they are VERY smart when it comes to knowing what you need,, just tell them what you want to do,, they will tell you how much "inverter" you need..
Jul 10, 2017 | Ford Cars & Trucks
Tip
WHAT IS A POWER INVERTER?
A power inverter is an electronic device that converts electricityfrom one form to another. Power inverters have become more popularrecently as the technology has become more efficient and much moreaffordable.
The most popular use for a power inverter isconverting battery electricity into mains electricity. For exampleconverting your car batteries' 12 volts DC into mains electricity 240Volt AC (Australia) or 110 Volt AC (USA).
WHAT POWER INVERTERS WILL HELP YOU DO
  1. Power inverters enablemains operated electrical equipment to be used even where there is nomains outlets, like in your car, caravan or even on your boat!
  2. Powerinverters bring creature comforts from home when you go camping orcaravaning allowing you to use your TV, fridge or electric shaver infact most of the normal mains powered conveniences from the home.
  3. You can charge your laptop in the car even if it doesn't happen tohave a 12 volt adapter. In fact a power inverter can be a very handygadget just to have in your car for those times you need to use a mainspowered appliance while you're away from a power socket.
WHAT TO LOOK FOR WHEN BUYING A POWER INVERTER
Apartfrom looking for a good quality well priced product there are a coupleof important elements to consider when selecting your power inverter:
HOW MUCH POWER IS ENOUGH ?
Powerinverters come in a range of power capacities so selecting the rightone for you is very important. Your power inverter needs to be able toprovide sufficient power for the equipment you want to use it with.
Here is a brief check list:
  1. Check the power consumption for the device you want to power
  2. Allow an additional 20% free board
  3. Add the power for all the devices you want to run at the same time
Note also that devices with induction electric motors like an power saw mayrequire 3 to 7 times the operating power when they start.
Usingan under-powered power inverter may damage it or the appliance you aretrying to use, so be sure to check the specific wattage requirementsand operating instructions for appliances / tools to be used.
PURE SINE WAVE INVERTERS
Normal mains power is known as Alternating Current (AC) and is a sine wave shape like the black line in the drawing below
Pure sine wave (black) versus modified sine wave (red)
Atypical power inverter produces a 'modified sine wave output' like thered line in the drawing above. While this works for most appliances,light dimmers, variable speed drills, sewing machine speed controls,some laser printers etc. will not operate correctly with a modifiedsine wave power inverter.
Pure sine wave power inverters areespecially designed to provide a more accurate sine wave output and socan be used with these appliances, but unfortunately they are moreexpensive.
Check with your with appliance manufacturer or itsspecifications to confirm if you can use a conventional power inverteror will need a pure sine wave inverter.
WARRANTY
One of thegreat things about electronic equipment is there is no moving parts(although there is a fan in some models) so you can expect a longserviceable life from a power inverter.
STANDARDS
Powerinverters generate dangerous mains voltages so ensure the product youchoose is approved for use with your mains voltage and supplier.
Powerinverters can also generate electro-magnetic radiation that caninterfere with other electronic equipment such as radios transmittersetc. Check for compliance with relevant standards such as C-Tick etc
SAFETY
Powerinverters can generate potentially lethal voltages so the utmost ofcare should be exercised using them to avoid accidental electrocution.
SUMMARY
To select your power inverter carefully check the power requirements for the appliance(s) you intend to use it with.
  1. Start power - Allow up to seven times for an induction motor
  2. Operating power - Allow a 20% margin
  3. Pure or modified sine wave
on Mar 04, 2010 | Electronics - Others
Power is on, but appliances connected to the inverter are not working.
power surge or not enough power to the inverter for the items you are running,remember,compressors and heating elements and motors use 3 times as much as ratings to use or start,if you have those hooked up,then the inverter is burned out
May 20, 2015 | Electronics - Others
110 to 220 ??? power from a common outlet to travel trailer
A TRANSDUCER WILL STEP 220 DOWN TO 110 .
I BELIEVE AN INVERTER WILL BOOST IT FROM 110 TO 220 A ALL IN ONE TRANSFORMER WILL WORK
Jun 30, 2013 | Cruiser RV 2013 Fun Finder X X-214WSD
Hi. I plugged a 600w oven grill and a kettle which is 110w into a 1000w Ring power 1024 inverter 24v-240. And now it dont seem to work. The inverter is wired straight to the battery.
Does it work if you plug in just your smallest appliance 110W?. How about just your 600W appliance What size wire are you using to supply power to the inverter? The inverter will draw about 30 amps from the battery with your load. You need to use wires as large as a number 8 from the battery to the inverter. The length should be as short as possible but could be 20 ft away. My inverter is a 2000 Watt continous and I use welding cable size 0 at about 3ft max between the battery and the inverter.
Jan 29, 2012 | Electronics - Others
175 watt 350 peak inverter 12v dc to 110 ac need a fuse but don't know what size to use. old fuse is missing.
Hi
15/16 amp would be recommended.
You could to try a 20 amp, but you will risk overheating and the possible failure of the vehicle circuit fuse.
Regards
Jan 30, 2011 | NexxTech 175W Power Inverter
In my question as to using two inverters of 110 volts each, they are not to be run in series but parallel. One inverter would tie into one side of the electrical panel and the other would tie into the...
this solution would likely work fine if you were only looking to have 110vac power. In order to have 220vac from two 110vac devices, you would need expensive equipment, and technical knowledge.
What you need to do in order to get 220vac is buy an inverter that will provide 220vac. There are many available.
Hope that helps.... Good Luck!
Nov 23, 2009 | Electronics - Others
My heart inverter makes 140 votes, is there a way to adjust it.?
You may want to check your voltmeter against domestic current. It may be reading high. Failing that, the manufacturer should help you. If the spec on the machine is 110 - 120, then 140 is too far out of spec. They should calibrate to this. Is the machine on warranty?
If not, depending on how you're using it, you can install a dimmer switch between it and the item you're powering with it - just a regular lamp dimmer switch you can get at the hardware store. Leads from the inverter go to the input wiring terminals on the dimmer, and your voltmeter goes onto the output; just dial the dimmer back until your vm reads 110 or 120 - whatever you need - and then connect to your appliance. You'll likely be better off with the rotary kind than the switch kind.
Sep 14, 2009 | Xantrex Technology RS3000 Sine Wave...
Hi, i've got a skytronic 300w soft start inverter making loud beep and then cutting out. I know its one of the safety cut outs but not which one. can it be repaired ? thanks
If your appliance draws over 300W or if your 12 v battery charge is low you will get a loud beep warning. Do you get the same beep with a low current appliance like a lamp? Make sure your battery has a good charge.
Some appliances have huge draw at start up even though they are rated under 300w your inverter may not be able to start.
Also some electric motors don't like modified sign wave inverters.
What are you trying to run and what is its rated watts?
I had my inverter beep when I had it connected via a cigarette lighter plug but when I used a connection straight to the battery it worked fine.
I was running a 500w grinder on a 1000w el cheepo inverter.
Aug 17, 2009 | Electronics - Others
12C Power Supply
Power inverters are plentiful on eBay in the range of $25-$100 US and any within that range would satisfactorily supply 110-120 VAC for your set. These items are also available at auto & RV parts outlets.
Check the rated power consumption on the set itself or in the user guide but I doubt that it will need more than 150 watts at 120 VAC.  If the consumption is not given in watts but instead amperes, multiply that number by 120 (for the liine voltage) and the result will be in watts. Any higher wattage that you buy will give you the possibility of using it for things other than your TV.
All later consumer items such as your set are able to deal with the quasi-sine wave output of this kind of primitive inverter.
Power inverters
Not all items can use this kind of AC; any power tool or kitchen appliance with brushes for the motor will accept this kind of voltage, as well as resistance type of appliances like hair dryers, curlers, etc. If you are in doubt about something you might like to attach to an inverter, listen closely to the device and if it doesn't sound like it did at home, don't use it.  Also if it starts to emit an odor or heats excessively, stop using it.
Sep 16, 2007 | Sansui LCDVD200 20 in. TV/DVD Combo
Xantrex Technology Heart Freedom 20 12 Inverter Logo
48 people viewed this question
Top Xantrex Technology Boating Experts
Craig Butler
Craig Butler
Steve
Steve
Are you a Xantrex Technology Boating Expert? Answer questions, earn points and help others
