Question about THQ Udraw Studio for Nintendo Wii
Does this product work with new wii console? Cannot plug in like before...help please
    Problem Solver:
  • 8 Answers
Try it if not it isen,t
Posted on May 28, 2013
My wii will not work the wires are plugged in but the light is not on it was working fine yesterday but it wont work now please help
Try your wii power supply in your friends' house. If your power supply didn't work on your friends wii, Buy new power supply. If it worked on your friend's wii then your wii is dead. Call Nintendo to take care of it. If you dont have a warranty, do it yourself. Take out the motherboard and google Wii FUSE. Chage the fuse. If you don't have the fuse, use soldering iron and join the palce you place the fuse together. If that didn't work again, Replace the wii motherboard. Trust me your wii will work this time and your MII you created will still be there because they are all on your harddrive not wii motherboard.
Rate if this helped you.
Apr 12, 2011 | Nintendo Wii Console
Console won't turn on
Hi there, Most power issues with the Wii can be fixed by resetting the AC adapter. You can easily reset the AC adapter by following these steps:
1. Unplug the Wii AC adapter at both ends (from the back of the Wii system and from the wall outlet or power strip).
2. The AC adapter must remain unplugged at both ends for a full 2 minutes.
3. We also recommend you unplug anything connected to the USB ports and the Nintendo GameCube Controller ports (such as LAN Adapters, keyboards, Nintendo GameCube controllers, etc.).
4. While you're waiting, check the AC Adapter for the following:
? Make sure that the word "Wii" and the model number "RVL-002 (USA)" molded into the AC adapter. Unlicensed products are not fully compatible and may not work correctly.
? Check the AC Adapter for physical damage. Physical damage, such as frayed wiring or a cracked housing can cause the system to shut down. If your AC Adapter shows signs of physical damage and needs to be replaced, you can purchase one from Nintendo's online store.
5. After you've waited 2 minutes, plug the AC adapter into the Wii system and directly into a wall outlet, not a surge protector or power strip. If the power light comes on and stays on, then it appears resetting the AC Adapter worked.
If resetting the AC Adapter did not fix your power issues, please continue reading:
? Avoid the use of unlicensed products such as memory cards, controllers, and cheat devices. Some of these products are poorly manufactured and may result in damage to your system. If one of these products is attached to your system, remove it and try resetting the AC Adapter (see above).
? Check any accessories that connect to the Nintendo GameCube Controller ports or the USB ports of the Wii -- whether licensed or not -- for physical damage. Physical damage, such as frayed wiring or a cracked housing can cause the system to shut down. Remove any damaged products and try resetting the AC Adapter again (see above).
? Make sure the Wii has good ventilation. Avoid operating the Wii while it's on carpeting or inside an enclosed space. If you have the Wii placed in a vertical position, make sure the vent on the bottom is lined up properly with the hole in the plastic stand and no foreign material is obstructing that hole.
? Check the vents on the back and side of the Wii for dust build up. The system will shut down if it cannot vent properly to prevent overheating. If there is a build-up, remove it using a vacuum cleaner with a soft brush attachment.
? Make sure that your wall outlet works. To check it, try plugging a lamp into the same outlet where your system was plugged in. Turn the lamp on the verify the outlet works. Also, make sure you are not using an outlet that is operated from a wall switch. If you do, make sure the wall switch is in the ON position.
? Make sure the AC adapter is attached properly. Firmly plug your AC adapter into the back of the Wii (the port is labeled 12V IN) and into a working wall outlet (not a power strip or surge protector). Click here for detailed instructions.
? Once plugged in, check the power light on the Power button to see if the system is receiving power.
If the power is still continually shutting off regularly, please click here for repair options. For this particular symptom, it is best to include your Wii console's AC Adapter with your system. This will help our technicians ensure they are able to resolve your issue.
Take care.
Sep 27, 2010 | Nintendo Wii Console
The console is not turning on.We checked all plugs and everything appears to be working but the wii console is not even showing a light that it is plugged in.
You can unplug the AC adaptor on both ends for two minutes.
Check if your adapter is a license product of nintendo WII if its not, you can purchase one on nintendo online store
May 28, 2010 | Nintendo Wii Console
Our console wont turn on
Hello :
Common problem .
Most power problems with the Wii can be fixed by resetting the [AC] adapter. You can easily reset the [AC] adapter by following these steps:
It's also recommended you unplug anything connected to the USB ports and the Nintendo GameCube Controller ports (such as LAN Adapters, keyboards, Nintendo GameCube controllers, etc.).
1:Make sure that the word "Wii" and the model number "RVL-002 (USA)" molded into the AC adapter. Unlicensed products are not fully compatible and may not work correctly.
2:Check the AC Adapter for physical damage. Physical damage, such as frayed wiring or a cracked housing can cause the system to shut down. If your AC Adapter shows signs of physical damage and needs to be replaced, you can purchase one from Nintendo's online store.
If resetting the AC Adapter did not fix your power problems, please continue reading:
3:Avoid the use of unlicensed products such as memory cards, controllers, and cheat devices. Some of these products are poorly manufactured and may result in damage to your system. If one of these products is attached to your system, remove it and try resetting the AC Adapter again (see above)
4:Check any accessories that connect to the Nintendo GameCube Controller ports or the USB ports of the Wii -- whether licensed or not -- for physical damage. Physical damage, such as frayed wiring or a cracked housing can cause the system to shut down. Remove any damaged products and try resetting the AC Adapter again (see above).
5:Make sure the Wii has good ventilation. Avoid operating the Wii while it's on carpeting or inside an enclosed space. If you have the Wii placed in a vertical position , make sure the vent on the bottom is lined up properly with the hole in the plastic stand and no foreign material is obstructing that hole.
6:Check the vents on the back and side of the Wii for dust build up. The system will shut down if it cannot vent properly to prevent overheating. If there is a build-up, remove it using a vacuum cleaner with a soft brush attachment.
7:Make sure that your wall outlet works. To check it, try plugging a lamp into the same outlet where your system was plugged in. Turn the lamp on to verify the outlet works. Also, make sure you are not using an outlet that is operated from a wall switch. If you do, make sure the wall switch is in the ON position.
8:Make sure the AC adapter is attached properly. Firmly plug your AC adapter into the back of the Wii (the port is labeled 12V IN) and into a working wall outlet (not a power strip or surge protector).
9:Once plugged in, check the power light on the Power button to see if the system is receiving power
If that didn't help , then replace your Wii with new one if you still have the guarantee .
If this solution is helpful please click a thumbs-up rating below.
Best regards .
Mar 23, 2010 | Nintendo Wii Console
Hooked up Wii console to TOSHIBA TV.....nothing.
Hello :
Best regards .
rate please !
WII
Hello :
It must be a power problem .
read this please :
9:Once plugged in, check the power light on the Power button to see if the system is receiving power.
best regards .
rate please !
Wellf irst it would not load certain games and not
1. Try plugging something else into the socket to ensure the socket itself is working.
2. Changing the fuse in your Wii power adapter, blown fuses are very common and this could be it.
3. If number 2 doesn't work try and get a hold of a replacement power adapter as the problem could be a break in the wire. If you need a new adapter you can go here NDSL games console, ds games console, NDSL games console_Video games Console_www.goldenbridge.hk
Wii ROCK BAND DRUMS WONT CONNECT. They were working.
is there a sync button on the drum set? if so, hit the sync button on the drums and then hit the sync button on the Wii. This will attempt to re-sync the signal of the drum to the Wii console. This has to be done for any new device that gets added to the Wii. Every so often, the Wii will lose connection with the device and has a hard time reconnecting. Sometimes this connection just has to be reset by resyncing the devices. If that doesn't work, you may have a bum product and have to buy a new one. Walmart has a replacement plan starting around 5 bucks depending on the product where, should your product fail within a year, you can order a new one on their site free of charge and have it shipped to the store for pickup. I recommend this for any high price console peripheral. So basically, my advice is to try and re-sync the drum set to your wii via the sync switches on the 2 devices. If that doesn't work, consider replacing. I hope this helps.
Mar 28, 2009 | Nintendo Rock Band for Wii
Broken wii
Check the disc. If there is no visible scratches then it is the console. It is a very common problem. Unplug all the cables and put the Wii in a different possition. For some reason, when you plug it back in about 30 min later it works! UNLESS you have a bad laser diode which I have repaired also. Then you need a new laser. I hope this helps you out.
Aug 17, 2008 | Nintendo Wii Console
HELP PLEASE!!!!!!!
I've had this same problem. Remove the batteries from the remotes. Then disconnct the power cord from the back of the Wii and disconnect the power cord from the wall. Let it sit for 5 min. Double check that the sensor bar is plugged into the Wii and check the cord for any breaks that might stop the signal. After you are sure that the sensor bar is connected and the 5 min. have gone by plug it all back in, install your batteries and re-sync it.
Mar 28, 2008 | Nintendo Wii Console
THQ Udraw Studio for Nintendo Wii Logo
49 people viewed this question
Top THQ Video Game Consoles & Games Experts
Jimmer_9
Level 1 Expert
James Wishart
Sandeep Kumar
Are you a THQ Video Game Console and Game Expert? Answer questions, earn points and help others
