Question about Nordic Track C1800 Treadmill
Nordic track c1800
Treadmill makes a metal scraping noise. Tried on all speeds gets louder the longer it runs.
  • 16 Answers
SOURCE: Need to put together a Nordic Track Elite 2900 treadmill.
Type into the serch, icon health and fitness, then click on the customer service, then click onto the manuals and the instructions should be in the owners manual.
Good luck.
Posted on Jun 29, 2009
Gackmaster
  • 12 Answers
SOURCE: I have a Nordic Track EXP1000i Treadmill. The
I know it's been months, but, if you still have this problem try this: 1. remove the philips screws holding the motor/belt/electronics cover on: you can lay the whole thing on it's side and remove them from the bottom. there's two in the front and two on the sides.
2. Obviously, unplug the unit! before doing anything. lay the unit back on it's feet (normal position)
3. Find the incline motor assembly. it will be int he middle of everything. black tube thingy.
4. take a cordless drill with a flat head screw driver bit, and turn the incline motor CCW. until the bed is flat.
5. what what I have read, you should shop for a new incline sensor. these fail before the motor does.
Posted on Jan 26, 2010
Gackmaster
  • 12 Answers
SOURCE: I have a Nordic Track EXP 1000X treadmill and the
Probably 85% of the time, it's the sensor.
1. remove the screws from the bottom of the enclosure case. 2 or 3 in the front and 1 on each side
lay it back down, and power it up, and actuate your incline. watch the end of the motor, to see if the shaft is moving. It probably IS turning but only a little bit. NOT enough. In this case I'd say it is the sensor.
2. Unplug the unit of course.
3. the incline motor is in the middle of the pack,..you'll see a black tube looking thing sticking up.
4. on the bottom side of this, you will see,..or feel for a black square sensor attached to bottom of the motor casing.
5. follow the wires and unplug this.
6. pry it off with a screw driver. Remove incline assembly, if you cannot reach it.
7. replace sensor and try it again.
if the MOTOR does NOT turn when using the incline buttons, the problem backs up to possibly a bad control board. or a bad motor on your incliner, however, i'd say that's the last thing to go.
Order of failure: 1. sensor 2. control board 3. motor.
good luck
  • 34 Answers
SOURCE: Nordic Track Ifit Treadmill has power but walking pad not working
If everything on the display console is working correctly then we know it is either a problem with the wires from the console to the controller or the controller itself. In most cases this means you need a new controller. To verify, take off the motor hood and find the green circuit board called the motor controller. With the power on go into manual mode and push the speed up button to a slow speed. If you see an LED light with "spd ctrl" next to it flickering but the belt still does not move then we know the problem is with the controller sending the signal to the walking belt, in which you should check the wires that go to the motor. If they are connected correctly then we know a new controller is in order. If you do not see a flickering light then it means the speed signal never got there and the problem will be with the wires going from the console to the controller. This is called an upright wire harness.
Posted on Aug 18, 2010
SOURCE: our belt is slipping on our nordic track c1900
I have the same unit. First, remove the hood. Then, the motor has an adjustment screw on the belt side of the motor. Loosen the nut a little, adjust the motor up or down to make the belt as tight as you can by hand, then re-tighten the nut. This always fixes mine.
Posted on Jan 03, 2011
Hi, on my c1800 im seeing jug ' in my time display and ever so often the machine is beeping but no response to get started.
Try this website, please:
http://www.livestrong.com/article/410922-the-controls-are-not-working-on-a-nordictrack-treadmill/
Jan 13, 2013 | Nordic Track Exercise & Fitness
I need the allen wrench to tighten my c1800 treadmill belt
Normally the number 6 mms .
However you must see your owner manual.
If you do not have it.
download for free from: www.fitness.manualsonline.com
God bless you
Jan 04, 2013 | Nordic Track C1800 Treadmill
Plastic under the treadmill belt is bent/warped
Dear sIR:
You must replace this parts, go to www.fitnessrepairparts.com or
www.treadmillpartszone.com
sincerely. God bless you.
ernesto cuadra
managua, nicaragua. c.a
Mar 11, 2012 | Nordic Track Nordictrack Exp1000 Treadmill...
How to activate my ifit
I will try to help you, the feature of software is the same. you can do it, activate your ifit. Nordic Track C2050 ACTIVATE IFIT -The Nordic Track C2050 is a treadmill that was targeted toward the budget-minded fitness enthusiast. It is a model of treadmill that is no longer being manufactured by the company. When it was still being manufactured, it developed a reputation for being an entry-level treadmill that featured a console that was easy to read because of its brightness. 1. Incline Change
o The Nordic Track C2050 allows users to change the incline of the treadmill with a simple touch of a button. This treadmill features both increase and decrease buttons for the incline. The incline of the machine will change by .5 percent every time the buttons are pressed. With each press on the incline buttons, the machine will take a moment to actually reach the incline setting that was just selected.
Capacity of Weight
o Users who are larger than or weigh more than the average person will be pleased with the added capacity of weight that the Nordic Track C2050 allows. Unlike most treadmills in its economy class that only allow a weight limit of 200 to 250 pounds, this model lets users who weigh as much as 300 pounds use the machine safely. Larger people can get the benefits of a cardiovascular workout on this treadmill without worrying about damaging it.
Heart Rate Measurement
o This Nordic Track model allows users to measure their heart rate. All the machine requires is for users to place their feet on its foot rails and grasp the metal contacts with their hands. The Nordic Track C2050 then works to determine your pulse, and the symbol of a heart will eventually show up in the display. After a couple of dashes show up, your heart rate will be displayed. Users who want to be certain of getting an accurate reading should ensure their hands are clean when gripping the metal contacts.
E.CUADRA
MANAGUA, NICARAGUA. C.A.
Oct 22, 2011 | Nordic Track NordicTrack Treadmill, A2550
The incline motor makes a noise near (but not at) the lowest elevation when rising or lowering. The noise is somewhat metal-on-metal and only lasts 1 second or less. Is this a concern? Is there anything...
Incline Motor
Treadmill manufactures publish user's guides that contain running deck incline operation procedures and warnings. Typical guides include weight limits and conditions for use. Most treadmills are designed to manage up to 250 pounds of weight. Operating the incline with excessive weight on the deck or cycling through numerous incline setting in succession can tax the incline motor. In time, the normal sound of the incline motor may become louder when the feature is used inappropriately.
Jul 25, 2011 | Nordic Track NordicTrack Treadmill, A2550
The belt is tracking to the right side. I tried to adjust it using the hex key, but that seemed to make it worse. Also, when running, the seems to stop or jar under my feet. The motor makes a whining...
It sounds like you have a bad bearing. If you are not familiar with repairing/replacing bearings on a treadmill, I suggest you contact NordicTrak and have a tech come out and repair it.
Jan 06, 2011 | Nordic Track NordicTrack A2750 PRO...
We have a Nordictack A2350 treadmill and it has a load ticking noise in the motor ? The motor runs fine but the noise is getting louder ?
as I said earlier when an engine is noisy, the problem is in the bearings and other times they seem to be the motor bearings when they are actually front roller bearings. check that and if necessary should be changed
Sep 11, 2010 | Nordic Track NordicTrack Treadmill, A2550
I have a Nordic Track treadmill C1800. When first
You have 1,2 or maybe 3 problems. 1st is you need to remove the cover over the motor. The belt that the motor turns may be slipping. You need to loosen the bolt that keeps the tension on the drive belt. Push down to tighten manually and then tighten bolt. While your in there you should check the drive belt for wear. If you have used the treadmill a lot it may need replacement. $20 from readmilldocter.com The walking belt if badly worn can be replaced for like $99 but probably is fine. put all back together and tighten tension. Should be able to lift walking belt 3 to 4 inches from center sides. Any less and its too tight. Its probably better to just replace the drive belt anyway. This should work. Do not over tighten ever. This is the cause of most problems.
Jan 18, 2010 | Exercise & Fitness
Nordic Track C1800 Treadmill Logo
35 people viewed this question
Top Nordic Track Exercise & Fitness Experts
Matt Olenzek
Matt Olenzek
Ross Metcalfe
Ross Metcalfe
Electro Med Services...
Are you a Nordic Track Exercise and Fitnes Expert? Answer questions, earn points and help others
