Question about Garden
New primer bulb but engine won't prime
Troy Bilt mower will start cold only if I spray gasoline or starter fluid into the carburetor. Once it starts, it runs fine and will restart OK. I put a new primer bulb on it but it doesn't help. What else could be wrong with it?
    Top Expert:
  • Garden Master
  • 50,592 Answers
Remove and clean the carby. clean out the main jet. ensure that there is nothing stopping the primer circuit from working. There are two valves under the primer bulb and a spring. when you push in the bulb fuel is squirted into the manifold When you take your finger off the bulb the spring pushes it out and new fuel is drawn past a valve to fill under the bulb. Pushing in again closes that valve and opens a second valve which allows the fuel into the manifold again
Posted on Apr 26, 2013
highspeedsan
  • 61 Answers
SOURCE: 6.75 B and S push mower wont start.
Check the kill switch. It may be stuck in the off position.
Posted on Apr 26, 2009
#1 Taper
  • 1041 Answers
SOURCE: troy bilt mower won't stay running to cut lawn
You may want to check the gas cap to see if it clogged with dirt. If the gas cap is clear, you more than likely have a carburetor problem. If you need tips on carb. cleaning, feel free to ask.
Jim
Posted on May 30, 2009
  • 11 Answers
SOURCE: Craftsman 7.0 HP Briggs & Stratton mower stalling
Check the muffler, if the muffler is clogged it could cause overheating of the engine, and could keep the engine from getting the necessary fuel-gas mixture.
Posted on Aug 12, 2009
digritz
  • 530 Answers
SOURCE: troy bilt lawnmower not starting
In most cases it's not enough to just dump the gas out of the float bowl. The problem is that the gas has turned to varnish and varnish is sticky. It will put a nice coating over all the the interior of the carb. The only way to clean it is to dismantle it completely. This means removing the float bowl and float. Along with the needle.The important thing is that both the float and needle move freely and both the high and low idle screws are clean. Depending on the type of fuel filter you may also need to remove and clean it as well. If it is not an inline filter it most likely is located inside the tank. As long as your careful not to tear the float bowl gasket you shouldn't require a rebuild kit for the carb.
Hope this helps.
Posted on Sep 16, 2009
Testimonial: "WOW! Thanks for the taking the time to put in all the detail.As soon as I get a chance, I'll take it back apart.Again thanks for your time Appreciat!"
SOURCE: My lawnmower won't start
my lawn mower has a new battery but will not start
Posted on Nov 02, 2009
Primer bulb not pumping fuel into carb, pull it out, no splits etc. Once I get fuel in it starts and runs fine??
Probably a valve in the priming system is stuck. It allows fuel to flow into the bulb from the tank, the valve should close then and allow the bulb pressure to spray into the carburetor. Could also be the opening into the carburetor from the prime bulb is blocked.
Mar 27, 2015 | Garden
My troy bilt lawn mower does not want to start like it loses priming. Can I reprime manually
if it has a bulb pump it about 20 times if not you could spray a little starting fluid in the air filter or take filter off and poor a little gas in the carb
Aug 03, 2013 | Troy Bilt 5.5hp Self Propelled Mower
Primer bulb
hello take the old bulb and go to your local mower repair shop,,
Feb 01, 2012 | Troy Bilt Tiller/Edger 26cc, Model No....
Hi, I have a Craftsman lawnmower, sel propelled, over 10 years old. It doesn't seem to start unless I spray gasoline into the carburetor. Also, it will only keep runnning if I continue to spray into...
the Primer bulb most likely has a crack in it. If it does then there won't be sufficient suction to draw in the fuel. Also, if you remove the carburetor, separate the upper and lower halves so you can get to the fuel bowl, check that the float needle isn't sticking inside the hole. Look for dirt and other contaminates.
Do you by chance have the model # of the mower? It will be in the following format: XXX.XXXXXXX The model # sticker is usually located on the deck behind the engine. And what HP is the Engine? (It should be a Briggs and Stratton.
May 27, 2011 | Garden
We have a troy bilt snow blower 1 yr old and we are trying to start it. When we try to prime it, the primer bulb does not seem to be moving any fuel. It just sounds like air. It will not start. We have...
Are there two tubes connected to the back of the primer bulb?
If it is connected, then the primer bulb itself could be cracked, allowing air to enter, but not fuel.
See if you can gently pry or possibly unscrew the bulb for replacement. They are readily available.
Gary
Dec 10, 2010 | Troy Bilt 5.5hp Self Propelled Mower
How do you prime a troy bilt 675 pressure washer
if you dont see a primer bulb then you must start it in choke mode after running out of fuel
May 31, 2010 | Garden
! have a Troy built mower with a Honda engine, it quit running and will not start. I changed the spark plug, it ran for about one hour. Now the mower will not start.
Hello. If the gas has been sitting all winter, remove it with a siphoning bulb and put in brand new gas, not even gas that you have been storing all winter. Also, change your air filter. Finally get a can of starter fluid and a helper. While one person squirts a bit of starter fluid into the air intake [near the air filter] the other person starts it and use more squirts of starter fluid to keep it running. Joe
Apr 09, 2010 | Troy Bilt 5.5hp Self Propelled Mower
My Troy Bilt Self Prop. Z-start won't keep running. I clean All, replace Filter and Plug, have clean gas and lubed all. It Starts for 2 seconds and then cuts off. What do you think it could be? Thanks....
I had the same problem, Tilt the lawnmower on it's side air filter facing up and remove air filter cover and air filter then remove the fuel bowl underneath the carb; then clean the fuel bowl with some gas and a clean rag. For the next step be sure to aim blower tip at target then look away before pressing trigger, this will prevent gasoline form getting into your eyes.Take an air compressor and carefully clean out the carb where the flap is and the tube where the fuel float that would rest inside fuel bowl is. Leave on side install everything back except for air filter and cover. Then pour a little gas in the carb to prime it, lay the lawnmower back on all 4 wheels and try to start.
Aug 02, 2009 | Troy Bilt 5.5hp Self Propelled Mower
Clean air filter and replace spark plug. If it is wet when you pull it out let it sit and dry out before putting new one in.
Jun 23, 2009 | Troy Bilt 5.5hp Self Propelled Mower
Troy Bilt TB 465SS Pony 4 cycle weed trimmer won't start
Sounds like you need to take the carb. apart and clean it. I like to use a Den Tek Brush, (used for cleaning teeth), to clean the small ports in carb. they work great for this job. Make sure to either clean or replace the small screen in thcarb. as well.
Jim
May 24, 2009 | Troy Bilt Tb70ss Gas Trimmer
Garden Logo
174 people viewed this question
Top Garden Experts
Dennis Key
Dennis Key
roeb
john h
