Question about Sharp Multi-System Mini Component System Shelf System
My cd changer does not come out
My cd plate does not come out
    Top Expert:
  • Sharp Master
  • 45,552 Answers
The problem is most likely a broken rubber drive belt . Open up the unit and look for a small rubber belt broken
Posted on Apr 26, 2013
Peugeot 307 Audio
Anything is possible with a bit of fore thought ,take old one out then try to fit the new one the wiring plugs should be the same for two of them but the third one will work the changer so leave that disconnected
Nov 29, 2011 | Blaupunkt IDC-A09 5-Disc CD Changer
2005 subaru outback ll bean edition, center console or "bezel" is one plate with 6 cd changer, heat, etc.. all on same face. 6 cd changer will not work , i have 6 cd's stuck in there, just...
Is car automatic? dont matter, open arm rest and take out every screw u see, dont be scared move foward. pull up on shifter plistic beseil, then to ashtray,2 screws under, coffee thing gotta go.comon guys? can ya get gas in it? its looks like it will brake,just give it a quick ****...
Jan 04, 2011 | 2005 Subaru Outback
Cd changer
don't e-mail me again YOU ARE to expensive for the time spent finding the solution
Jul 22, 2009 | Sony Car Audio & Video
The face plate does not light up
check your gas connections on your stove
Apr 25, 2009 | Pioneer KEH-P7800 CD Changer
CD Changer in RX330 Lexus 2004 shows error 4
I just fixed my 2005 RX330 CD changer jam, and saved $800-1000. It was easy, if you first spend $6 at:
http://www.carstereohelp.com
Here you will find pics and instructions on how to remove the stereo/changer. Mine was a Pioneer, and the stereo came out in 5 minutes. I could not find instructions how to take it apart, so I experimented a little. The secret was to take the top lid off the changer - 9 little screws, and a piece of black tape. Under the lid, I found my problem - a CD had been inserted too soon (the WAIT sign actually means what it says!), and I just lifted it off the top plate. Under the plate I could see 2 more CDs, in the 6 slot holder, but they seemed to be free and not jammed. So without reassembling the stereo, I plugged it back in. The changer cycled, I hit eject twice to get the other CDs out, and all is well.
Mar 21, 2009 | Car Audio & Video
Nakamichi MB-70 CD player - cannot get cd to eject
Having just removed three discs from an identical unit which also jammed, I will say how easy that was. I do not know if the unit will now function when reinstalled in the vehicle.
Remove the unit from its mounts, remove the outer "frame" (if fitted), remove the two #2 phillips pan head screws from the sides holding the face to the chassis, remove the four #0 phillips screws (black, flat head) from the top and bottom of the face plate.
Slide the face plate off and carefully handle it while tethered by its ribbon wire.
Turing the unit upside down, peer into the opening and observe the disc, gently press the carriage away from the top of the unit (now the bottom, as it is inverted) and allow the disc to be freed, simply pull the disc out.
If there are multiple discs stuck inside, oberve the large metal gear just inside, carefully rotate the gear to actuate the loading mechanism as needed to release addtional discs.
Feb 23, 2009 | Nakamichi MB-70 6-disc In-dash Musicbank...
CD changer will not accept CD's
I got the ERROR 3 on my Lexus RX330 2004 CD changer, and fixed this problem myself. My CD changer now works fine for more than one month after the repair, and hopefully will continue to work in the future )))) First, I opened top cover of changer ( about 8 screws ). Next step is most difficult - need to detach 4 tiny springs on top corners that hold metal top plate and keep them in the same place not allowing them to fall down (detach the spring, then hook the top with paper clip as to not let the bottom come detached and lose the spring inside). I used paper clips for holding the springs on the coners of the metal frame. Next need to take the metal plate out and then all plastic CD trays with CDs, the plastic trays may jam a little when being lifted out, but they will come out. Take all CDs and don't use them in the changer anymore. Seems the CD changer doesn't like CD-R's. So, use original CDs. Actually I an going to record new CD's using good blank media from good manufactures, will try to see whats gonna happen. So, take out all plastic CD trays keep them in order and facing the right way. After removing all CDs put all things back. Do everything very gently because all parts very precise and easy to break. The cd changer showed "Error 3" for the rest of the evening but then next day was fine and has been working fine since then. I think the computer had to be reset overnight to clear that error. If you have any questions, do not hesitate to PM me.
Oct 08, 2008 | 2005 Lexus RX330
Sharp Multi-System Mini Component System Shelf System Logo
66 people viewed this question
Top Sharp Audio Players & Recorders Experts
 Grubhead
Grubhead
Are you a Sharp Audio Player and Recorder Expert? Answer questions, earn points and help others
