033-545 Get 033-545 error when trying to FAX
Mfc-7840w /Cc3 205 03031f04
Your fax machine can work independently from your operating system. Print the document and try to manually fax from the fax machine. See if there is an error message on the fax when you try. Then if it doesn't work , post the new error from the fax machine.
May 23, 2014 | Computers & Internet
Error Code R.3.1
YOUR PROBLEM IS CAUSED BY STATIC ON THE PHONELINE NOT YOUR FAX. BOTH MACHINES TRY TO SLOW DOWN TO UNDERSTAND INTERNATIONALMESSAGE OF FAX COMMUNICATION THEY MUST UNDERSTAND 95% OF MESSAGE OR THEY WILL DISCONNECT YOU CAN TRY NEW PHONECORD 1.00 AT DOLLAR STORE ORCALL YOUR PHONE CO.
Apr 09, 2010 | Muratec F65 Plain Paper Thermal transfer...
Remote fax error when sending a fax
Does it only happen going to one certain fax destination or every destination? There are some things to try on the Lexmark web site.
Go to www.lexmark.com and click Support->Technical Support. Type in 4270 in the 'Search by Model' box. Type in 'Remote fax error' in the 'Search the Knowledgebase' box. There is a topic called 'Problems Sending a Fax to Specific Fax Machines' that has some good general tips.
Steve
Feb 26, 2009 | Lexmark X4270 All-In-One InkJet Printer
Hi, Remote Fax Error being displayed
Set the DRPD in the settings to 9600 and then try send a fax ...
Jan 29, 2009 | Dell 924 All-in-One InkJet Printer
Error message 421*
error 421:
A handshaking error has occurred at some point in the process from the fax that originated the fax.
* Try the fax at a different time when telephone line conditions have improved.
In some cases this error can occur if the other fax machine is using a fax format incompatible with the HP fax.
- you can try to set the FAX SPEED to SLOW
- ERROR CORRECTION MODE to OFF
you can locate this on ADVANCE FAX SET-UP...
Aug 13, 2008 | HP OfficeJet 6210 All-In-One InkJet...
Sending error
I try sending a fax then the paper goes through it makes a loud beep and the message says theres been an error try again this happens all the time no matter who I fax. then it prints out error confirmation stating Mode G3 send error
Jul 29, 2008 | HP 1040 Plain Paper Inkjet Fax
What happens if you dial the remote fax number as a voice call on another phone? Does that number pick up? Does it give you the modem handshake noise? If not, the remote side has a problem.
Can you fax other numbers? What happens when you dial your own fax line from another phone? If your fax does not pick up and talk to you, your fax may have a problem.
Jul 24, 2008 | Dell 962 Photo All-In-One InkJet Printer
Can't recieve a fax
i have fax L100 ,i can send a fax but i cant recevie a fax error is communication error (003F)
Oct 24, 2007 | Canon FAX L-120 Plain Paper Laser
Fax Error Codes
ERROR 346 The remote machine has failed to respond to a fax command from the local machine because the connection was interrupted. These errors can occur if the phone lines in the area are old or if noise is present (static on the phone line). Other reasons could be power outages and other power-related problems.
Sep 11, 2007 | HP Officejet 7210 All-In-One InkJet...
95 people viewed this question
k24674
jasbo
jasbo
