Question about JVC AV-27530 27" TV
JVC Tv Constant Blue screen
The screen on my tv is constantly blue as if it was in video 1 or 2 but even changing the video to tv and back does not help. It plays VCR tapes if I connect the VCR to the TV. The TV does not seem to be receiving a signal. What can I do to fix this problem? I tried changing the cable cord connecting the tv to the cable outlet on the wall. Nothing helped. I also tried messing around with the menu. That didn't help either.
  • Anonymous Dec 03, 2007
    yes my i am unable to program channel or if i am the only thing that shows is a blue sceen i can change input but when it goes to tv mode it stays a second then quickly to the blue screen why?
If you have the remote control number RM-C203 with your tv than try noise muting in your menu settings mine did the same thing i just put noise muting off and it worked for me
Posted on Nov 01, 2007
Posted on Sep 15, 2008
What is theater pro i hit this button onremote control a black square came on screen
Posted on Jun 15, 2009
    Brigadier General:
  • 6,966 Answers
Hi, To be able to determine if your TV cable tuner is defective or if your connection to your cable provider is the issue, connecting your VCR to your TV bot by using the Video in but by the cable. Use the same cable cord that is now connected from the tv to the cable outlet on the wall. Instead of connecting it to the outlet, plug it to the RF out of your VCR. Set your TV to Ch 3 or 4 and see if you can watch the movie. Just to be sure temporarily remove the video cable connection from VCR to TV. If you can see the VCR movie via Ch 3 or 4 that would mean that the TV tuner is OK and your cable connection (provider) is the issue. If you still can't get any signal then the TV probably has a tuner problem. As this involves opening the back of the TV, it would probably be best to seek the services of a qualified professional (TV technician). Should you prefer to DIY (do it yourself), please post again. Good luck and kind regards.
Posted on Aug 06, 2007
  • Louie  Role
    Louie Role Aug 06, 2007
    Opps, it should read as......
    ...pls connect your VCR to your TV not by using the Video in but by the cable...
4 Suggested Answers
  • 24 Answers
SOURCE: Connection to Dish service
Your t.v is having only RFin , and if you connecting dish receiver , normaly their are two o/p for receiver one is RF and two is for audio out and video out. if your connecting direct RFout to t.v RF in then you have to tune the t.v in all bands. if your receiver do not having RFout facility, then you have to connect AV out to converter and then RFin of t.v. if you having a vcr, then connect AVout of dish receiver to vcr AVin and then vcr RFout to t.v again tune the t.v and pwer on the vcr.
Posted on Jun 25, 2008
SOURCE: Blue Screen
I don't have a solution, but wanting to know if you ever resolved your problem? I'm having the same issue with my JVC 32" model # AV-32D500.
thanks
Posted on Feb 23, 2008
  • 362 Answers
SOURCE: VIDEO INPUTS NOT WORKING ON TV
Make sure TV is set to the AV input, yellow, red and white wire should be connected to color matching input on tv.
When you turn on the PS3 keep your finger on the power pad for 30 seconds and you should get a message from the ps3 about your input choice.
Let me know if this works, If it dosn't I will download the manual for the tv and try to help with it.
Please rate this solution, the only compensation I receive for my time is a good rating from you.
Lone99star
Btw, I’m available to help over the phone in case u need at https://www.6ya.com/expert/jason_77a19afa8d604dee
Posted on Apr 28, 2009
My Samsung LE32N7 does not come on. The blue light under the screen constantly flashes without the tv coming on.
Hi, maybe the TV controller board is blocked, you can reset it, by disconnecting power cable from outlet for about 5 minutes, if that doesn't work, possibly and internal board or component must be repaired of replaced, in such case it's better to contact an authorized Samsung service center or technician to check your TV.
Nov 07, 2017 | Televison & Video
There is a constant blue shadow and yellow bowing from the top of screen. Needs convergence circuit repair = replace convergence IC's, How is this done!!!
Please do us a favor and rate this by cliking the thumps up icon located here >>>>>>
Projection TV sets have two very common problems. One is convergence ( 3D/Warped video) the other is CRT fluid ( Dull Video). Below are more details for both items. Also, complete repair kits with instructions and repair support are avail from site such as www.TvRepairKits.com
Common Problem #1) Convergence has gone out
Projection TV sets need to have all three colors - RED - BLUE - GREEN - lined up correctly on the screen in order for the video to look normal. When its out of alignment the video will look 3D, wavy, distorted, etc. Most of the time you just need to adjust your convergence in the TV menu. If you cannot adjust it in the menu - then your convergence is broken and needs to be repaired.
This is a very common failure on these projection sets and a fairly simple DIY fix. All projection sets including Samsung, RCA, Sony, Philip Magnavox, Panasonic, Pioneer, Akai, GE, JVC, Toshiba, and others at some point will have the same problem.
Common Symptoms include....
  • Screen looks 3D
  • Colors don't line up
  • One or more colors can't be adjusted when using the convergence menu.
  • Screen is bowed or warped.
  • TV shuts off after powering on. Power light will blink. TV may also make a chirping noise.
Here are some pics of convergence problems.
69189a5.pngSOLUTION #1
For more more examples and find a fix using this link on Fixya http://www.fixya.com/support/r2861467-solution_video_looking_whiteish_dull
Common Problem #2) CRT Fluid is Cloudy
Projection TV tubes have a liquid coolant that is used to keep them from overheating. After many years the coolant in the blue and green tubes will become cloudy and cause the screen to look dull, red/orange, etc. You may even see halos around images.
Picture of a set that needs the fluid changed.
TV set after fluid change
69189a5.pngSOLUTION
You can see some more examples and find a fix using this link on Fixya http://www.fixya.com/support/r2861467-solution_video_looking_whiteish_dull
May 22, 2011 | Hitachi 43F300 43" Rear Projection...
My JVC model AV27330 has a constant blue screen. I can go thru Video 1, video 2, video 3 and then says chn 04 but should be 03 - when I push channel button down channel 105 shows or the other way channel...
You need to use the original remote and call up the customer menu; select auto program or channel program and see if reprogramming will help.
If no JVC remote you have only one other choice----connect a DVD or VCR to one of the video inputs and see if the set functions that way.
SD TECH
Aug 09, 2010 | JVC AV-27530 27" TV
Phillips Magnavox constant blue screen
This is a common problem. Its called a convergence failure.
Symptoms:
  • Screen Looks 3D
  • Colors wont align
  • Video may look distorted
Problem #2 CRT Fluid has clouded over. Symtoms
  • Dull looking video
  • White looking video
  • Halos around objects
  • Red/Orange looking video
You can see some examples and find a fix here...
bb0cf99.pnghttp://www.fixya.com/support/r2861467-solution_video_looking_whiteish_dull
Feb 18, 2010 | Philips Magnavox 50ML8105D 50" HDTV DLP TV
Jvc av-48wp74 48 in widescreen green projector problem
Projection TV sets have two very common problems listed below.
These sets need to have all three colors - RED - BLUE - GREEN - lined up correctly on the screen in order for the picture to look normal. This is called convergence.
When its out of alignment the video will look 3-D, wavy, distorted, etc. Most of the time you just need to adjust your convergence in the menu. If you cannot adjust it in the menu - then your convergence is broken and needs to be repaired. Convergence problems are very common on all Projection TV sets including Sony, Samsung,JVC,Philip Magnavox,Panasonic,Akai,Pioneer, Hitachi,Mitsubishi,Zenith and others.
You can get more information and a DIY convergenece repair kit with instructions from the link below.
Here are some of the most common problems with these sets...
*Screen Looks 3-D
*Colors wont align
*Screen may look distorted or warped
*No Audio/Video - TV Shuts down - May also make a constant chirping sound
Problem #2 - Another common problem is dull or washed out video.
Your set may have one or more of the following symptoms....
*Dull looking picture
*White looking picture
*Halos around objects
*Red/Orange looking picture
bb0cf99.pngYou can see some more examples and find a fix using this link on Fixya http://www.fixya.com/support/r2861467-solution_video_looking_whiteish_dull
Jul 27, 2009 | JVC AV-48WP74 48" Rear Projection...
Blue ghosting all over the screen TV screen stays dark blue whether turned on or off. Indicator light keeps flashing green when TV turned on.
The most likely cause is shorted convergence chips and possibly a few pico fuses.
When its out of alignment the video will look 3-D, wavy, distorted, etc. Most of the time you just need to adjust your convergence in the menu. If you cannot adjust it in the menu - then your convergence is broken and needs to be repaired. Convergence problems are very common on all Projection TV sets including Sony,Samsung,JVC,Philip Magnavox,Panasonic,Akai,Pioneer2_bing.gif Hitachi,Mitsubishi,Zenith and others.
You can get a convergenece repair kit with instructions from the links below.
Yours may have one or more of the following symptoms...
*Screen Looks 3-D
*Colors wont align
Problem #2
You can see some more examples and find a fix herebb0cf99.png http://www.fixya.com/support/r2861467-solution_video_looking_whiteish_dull
Feb 26, 2009 | Sony Grand WEGA KF-50WE620 Television
Green Background with red wavy lines
*Screen Looks 3-D
*Colors wont align
Jan 11, 2009 | JVC AV-56WP74 56" Rear Projection...
Horizontal Lines and Blue Tint on my Sony KDP 57XBR2
ok,your porblem is very simple,reheat or resolder the main board your tv.
Oct 22, 2007 | Sony Grand WEGA KDP-57XBR2 57" Rear...
Apex 32" TV - Blue Screen & Channels keeping running/changing
blue screen indicares that there is a problem in blue cathode circuit. please check 1 blue video output supply. 2 blue video ckt defective 3 signal from chroma ic to blue cathode missing. 4 loose connector 5 crt base loose. 6 chroma ic defective. I think sound will be ok .
Sep 22, 2007 | Apex Digital PF3230 32" TV
JVC AV-27530 27" TV Logo
5,535 people viewed this question
Top JVC Televison & Video Experts
Jaime Hernandez
Steve Allison
Steve Allison
Are you a JVC Televison and Video Expert? Answer questions, earn points and help others
