Question about Lamber L21EK Commercial Upright Dishwasher
Dish Soap & Machine Sanitizer for Lamber L21
Trying to find out what best soap to use to wash our glasses better and a machine sanitizer to wash clean the washer itself
    Problem Solver:
  • 25 Answers
Http://www.eurodib.com/pages/8
Posted on Dec 29, 2013
My Samsung model #WA4H7000AW/A2 seems to always need an additional rinse to get rid of soap left behind. Is this a common complaint ?
Here are some questions that may help.
1) Is the water hot enough? Since the soap "melts" better at higher temperatures, cooler water can leave a soap film.
2) Are the dishes clean before you run the machine? We like to used the dishwasher to "sanitize" the dishes, so we rinse them really good before washing them, to get off caked food residue.
3) Try changing washer soap, try powder if you used liquid, or visa-versa, and try less quantity and see if any of those help.
God bless your efforts.
Dec 19, 2016 | Samsung Washing Machines
Hobart dish machine. We were told by Ecolab tech that we need to rinse off all presoak, soaps and sanitizers before passing through the maching as they cause foaming/excess suds. I do not find that info...
That's true. excess of foam can cause poor wash pressure and poor final rinse.
Operation manual , pag.24. (F17791Rv02-06.pdf)
DO NOT exceed chemical manufacturer's recommended concentrations for detergent, sanitizer, rinse aid or lime scale remover.
Mar 13, 2015 | Hobart Dishwashers
Blinking light
The issue is the dispensing unit you have is a sanitizer dispenser, not a soap dispenser. The adapter collar on the bottle is the issue. Soap dispensers use a GRY collar, sannitizers use an LBL collar. There should be a sticker on the dispensing unit that says "LBL" or "GRY". Try removing the collar from a sanitizer bottle and place it on your soap bottle......should work fine. In short, make sure your letter code on the bottle mathces the letter code on the dispenser.
Jan 30, 2014 | GoJo Purell 2720-12: TFX ? Touch Free...
Soap remains on the dishes after the wash cycle is complete.
Check that the holes in the spray arms haven't blocked up and the filters in the bottom are clean. The arms may not be rotating. To check this, when the machine is washing, open the door, turn all the spray arms to face the same direction, shut the door and leave running for about 30 seconds. Open the door again and look at the position of the spray arms. They should have moved.
Nov 25, 2013 | Samsung DMT400RHS Builtin Dishwasher
Front end loader
are you using the correct detergent and not to much for this machine-try cleaning out the drain trap and filter-wipe down the door seal and tub with a bleach or oxy type cleaner -run the sanitizer cycle with a quarter cup of powdered dishwasher soap,and finally leave the door open between loads-this ain't your momma's washer-these things can be a pain in the booter-cheers Denny
Oct 26, 2013 | Samsung Washing Machines
To clean can I 1) hose it down with a dishwasher
This isn't recommended, meat tends to get in a lot of the nooks and crannies in a slicer machine. It's best to first unplug the machine, then take it a part in order to properly clean it. If your not sure how to take the machine apart, consult the user's manual for further understand how to do it. Once taken apart, some sort of stainless steal cleaner followed by a sanitizing soap should be used to clean it. Sanitizer is very important especially when dealing with meat products. Once a sanitizer is applied it is recommend that you let the slicer air dry for 4-6 hours before using it again to ensure the sanitizer has fully dissipated.
May 18, 2011 | Berkel 827E Gravity Feed Deli Meat Slicer
Shortly after I turn on the sanitizer on the machine, it turns itself off (the whole machine). Does it need to be cleaned?? What type of solution do I clean the boards in??
Remove the plaques and using an old tooth brush clean with mild soap and water.. Rinse thoroughly, towel dry and finish drying them with blow drier. The interior of the unit and it's filter should also be cleaned. Depending on what type filer it uses (Aluminum mesh or soft mesh plastic) they too and can be washed with mild soap and water, rinsed and thoroughly dried. Any other type filter material may need to be replaced. Clean the interior with canned compressed air with a straw nozzle and a dry paper towel.
Of course, before you do any of the above, unplug the unit.
Mar 02, 2011 | Ecoquest Breeze AT Living Air Purifier
I have purchased a business - with a Hobart LXi - and no manual. I can't figure out what soap etc to use - or how it gets into the dishwasher!
Contact your local chemical supplier such as EcoLab or AutoChlor to purchase the proper chemicals. Use ONLY commercal dish washing chemicals. Residential detergents like Cascade do not dissolve fast enough and WILL, in time, cause you trouble if used in the LXi.
There should be three colored plastic tubes at the rear of your machine. Red is to be put in a container of liquid detergent, Blue is for rinse aid, and white/clear is for sanitizer. Your chemical salesman should be able to show you how it's done at no charge.
You may also want to register here http://www.hobartservice.com/Manuals/ then download the manuals for the LXi dish machine.
All the best.
Nov 28, 2009 | Hobart LXiGC Dishwasher
I have a three year old Hobart. I am not sure
Look on the top edge of the door to find the data plate. It sounds like an SR24, if the leds are on the left of two temp gauges. If your sanitizer pump has a tired silicone tube that is flattened from use, it will not draw chemical. if you have an air bubble in the sense board at the back, it will think you have run out. If you have changed the type of chemical or diluted it, the board will need recalibrating to suit. Put some sanitizer in a small vessel with the pickup tube and monitor the amount delivered. Usually one is looking for 50 ppm solution of bleach and rinse water.( test with litmus paper) If you have an SR24H with a booster, you don't need bleach sanitizer and holding the sanitizer button will turn the sense off.
Jun 16, 2009 | Hobart 24 in. LXIH-3 Built-in Dishwasher
Lamber L21EK Commercial Upright Dishwasher Logo
139 people viewed this question
Top Lamber Dishwashers Experts
Are you a Lamber Dishwasher Expert? Answer questions, earn points and help others
