Question about Kitchen Ranges
Inoperative left eye dial on range top
Left eye burner dial will not engage and send signal to the burner eye to come on and I presume if it came on it might not turn off.After pushing the dial in and then turning it,it feels like an uncoiled spring being wound up and will slightly turn back a little upon release of the dial. Is there a relatively easy fix as well as inexpensive repair to this that I may be able to do myself. We have just sold this residence and need to repair this dial prior to inspection. Thank You, Tom
SOURCE: ceramic/glass top stove
Lift the ceramic top and look at the burnner to see if it is bad or not.
You only have to take 2 screws in the front of the ceramic top at the bottom, just open the oven door and look at the corners.
Don't forget to unplug the stove first
Posted on May 10, 2008
  • 360 Answers
SOURCE: kenmore glass top range left front large burner out
check the burner socket, it is likely that contact is being lost where the burner connects to the hardwired portion of the system (the socket). It is not unusual for the socket to "burn up" when there is a poor connection to the burner resulting in the burner being replaced and the new burner not working or working intermittently.
Please take the time to rate this solution
Posted on Jan 29, 2009
  • 109 Answers
SOURCE: left turn signal not working proper
Turn signals flashing is the confirmation of alarm system being on.I thought both sides flashed but if alarm is faulty guess that's messed up too. Try starting from stratch with alarm,disarm it[disconnect neg wire at battery]then reconnect wire and when that sets off alarm turn it off in normal way.That should get things back on track.Plus,try replacing the flasher unit,don't know why this works but I've heard of it.
Posted on Mar 28, 2010
SOURCE: Surface burner on electric smooth top range not
I have a GE Spectra smooth stove top and it has two burners in one, The problem is that the inside burner is not working. I need to find out how I can get into the stove to see how to fix it. Does anyone else have this problem and how did you fix it?
Posted on Mar 31, 2010
MicrowaveSvc
  • 9047 Answers
SOURCE: I have a Samsung Induction
"SE" error means you have a shorted membrane keypad.
There should be a "mini-manual" (tech sheet) hidden inside the unit behind the control panel or in the back cover, which is very helpful when troubleshooting, testing, and locating components.
You can find helpful exploded view diagrams and order parts by entering your full model number here.
Posted on Jan 29, 2011
Left front range top burner temerture control issues
Good Morning Friend,
I understand that you are having trouble with the left front burner on your Frigidaire range, model# FEF355. I see that the burner heats up to a glowing red hot temperature, no matter what you set the dial to. I suggest resetting your appliance, by either unplugging it or shutting the power off at your homes circuit breaker, for 3-5 minutes.
When power is restored, the first thing you will need to do is set the clock. You will do this by pressing the "Clock" button, then within 5 seconds press and hold the up or down arrows until the correct time of day appears.
Once you have set the time, turn on the left front burner, on the lowest setting. If the burner is still glowing red hot, I suggest contacting your local authorized technician for further assistance. They will be able to diagnose your range and determine what is causing the burner to glow red hot on all settings. Hope this is helpful.
-Best Regards-
WP
May 15, 2014 | Frigidaire FEF355 Electric Kitchen Range
Front left burner not working. how do i replace it
Open the oven door and remove some screw under the tp and raise up the top. I have a page with a bunch of videos and one of them shows how to replace the eyes. I think it is the third from the top: HERE
Feb 10, 2010 | GE Spectra JBP78 Electric Kitchen Range
Surface burner on electric smooth top range not heating. When turned on, the left rear burner does not light up at the dial or on the surface. How can we determine if replacement is necessary or there is a...
Jan 24, 2010 | Kenmore Kitchen Ranges
Frigidaire smooth top electric stone eye stuck on high!
Yes,the switch controlling the burner is bad and must be replaced.
Oct 31, 2009 | GE Kitchen Ranges
Kenmore glass top range left front large burner out
Jan 29, 2009 | Kenmore 95002 / 95004 Electric Kitchen...
Left front burner remains on high.
change the left control, it's not controlling the power in the burner
Jan 18, 2008 | Hotpoint RB787 Electric Kitchen Range
Problem with left front eye
This sounds dangerous! you can lift the top of the stove to access the burners source of electricity. Unplug one of the hot wires to the bad eye and conpletely cover it with electrical tape. NOTE: This is a temporary fix. consult Maytag Support @ 1-800-688-9900 For a better long term solution! Have a great day, Alan
Dec 25, 2006 | Maytag MER6772 Gemini Electric Kitchen...
Kitchen Ranges Logo
Top Kitchen Ranges Experts
Dan Webster
Dan Webster
paulcarew
Are you a Kitchen Range Expert? Answer questions, earn points and help others
