Question about Compaq Presario S6000NX (DQ178A#ABA) PC Desktop
Factory restore tring to restore to factory setting asking for password never put one in. don't know what to do?
    Brigadier General:
  • Compaq Master
  • 3,400 Answers
If you are the only user of the computer.change your account set a password then do what you like.
Posted on Apr 26, 2013
3 Suggested Answers
christykraj
  • 107 Answers
SOURCE: I want to restore my
Try admin or just hit enter. If not remove the battery from the mother board for 5 minutes and see whether it helps. If you haven't entered a password on BIOS there shouldn't be any problem. Also try deleting if you have any other users accounts on the system.
Good Luck!
Posted on Jun 09, 2011
SOURCE: f10 function key has password i didn't set ?
Since this came to me as a desktop question I will give you that set of instructions. you will need to power off the machine and unplug it. Remove the side panel of the computer (or top panel depending on the model). When you look at the motherboard you will see a CR2032 battery that powers the BIOS chip to allow it to retain it's settings such as password, date, and time. There may also be a jumper on the board (a little plastic square with copper in it) to reset the BIOS. You will be looking in the same general area of the battery for this jumper and it should be labeled CMOS or Reset.
If the jumper is present you will need to use it to reset the BIOS. If using the jumper doesn't reset the password then you will need to remove the Battery I previously mentioned and let the computer sit without power or battery for several minutes.
If this still does not remove your password (or if you would like to try this first) you can try to use a manufacturer override password. On a Compaq system the override should be Compaq. That does have a capitals C and the password is case sensitive.
Best of luck!
Posted on Nov 14, 2011
How do i restore the emachine
Remove any DVDs or CDs from the optical drives and then unplug all peripheral devices except for the keyboard and mouse.
Click the "Windows" button and then type "eMachines recovery management" into the search box. Click on "eMachines recovery management" in the results list and then click the "Restore" tab.
Click "Password Settings" and then type a new password into the text box.
Click "OK" and then click "Restore System to Factory Default".
Type the recovery password into the "Password" text box and then click "OK". Click "Next" To start the recovery process.
Click "Finish" and then wait for your computer to restart.
This procedure could take several minutes. Once your computer has restarted, you'll be prompted to create a new user account, enter the date and time and set up the internet settings.
or if you are running XP
If you set your machine back to eMachines factory settings, it might help you for a short while but if you don't have effective virus protection your problems will return in short order.
You should get rid of this virus with an effective virus remover.
You can run Bitdefender's free online scan which doesn't need to be downloaded http://www.bitdefender.com/scan8/ie.html
If you know when you got the virus, you can do a system restore to a time before the virus was on your system. This article tells you how to run it from safe mode http://bertk.mvps.org/html/safemode.html
Your best protection in general is a complete internet security suite such as Bitdefender or Norton internet security 2009.
More information here http://www.ask-the-computer-doc.com/comp...
If you need to totally rebuild your system and you don't have a recovery disk, contact eMachines to get one.
You might also try a Windows repair install if you have the operating system disk. Follow the directions here for XP http://www.michaelstevenstech.com/XPrepa...
Source(s):
hope this helps
Sep 16, 2012 | E-Machines eMachines Desktop PC
Need to reset my ipod touch to factory settings
1. Plug your iPod 4G into your computer with its dock connector USB cable.
2. Install the most recent version of iTunes and open iTunes. Wait a moment for your iPod to appear in the side bar.
3. Click on your iPod in the side bar and select "Restore." A pop-up window will ask if you're sure you want to clear your iPod and restore to factory settings. Click "Continue" and enter your password, if prompted.
4. Leave the iPod untouched and on a flat surface while it restores to original settings. It's important that you don't try to disconnect or use the iPod while it's restoring. You'll see a progress bar either on the iPod or your computer that indicates how far along the process is.
5. Select your new syncing settings (automatic sync or manual) when prompted after the restore is complete.
Aug 07, 2012 | DisegnoShop Computers & Internet
Reset my desktop backc to the original settings
Source(s):
hope this helps
Aug 01, 2012 | E-Machines eMachines Desktop PC
I was tring to put it in , but stil show power on password need help
If there is a 'power on' password that means that the computer has a 'boot password' set in the BIOS. You will need to press either F2, Del, ESC, or, rarely, another key to enter the BIOS on computer startup and remove the boot password.
If you do not know the BIOS or boot passwords then there isn't too much you can do other than flashing the BIOS which may, or may not, reset the CMOS settings back to the factory default.
Jul 04, 2012 | HP Computers & Internet
I have a ZX4931-31e gateway all-in-one. i did a system restore back to factory settings. when it rebooted i was asked to log in and i don't know what the reset administrator password is? i tried...
Have you tried a blank password for the administrator. Just press enter when administrator pops up. If that does not work, try administrator. That should solve your problem.
Thanks for using FixYa!
Aug 02, 2011 | Gateway ZX493131e Notebook
I want to restore my acer aspire 4315 to factory settings but it is asking for a empowering technology password but I don't have can you help ?
well good news maybe on start up press the alt +f10 or ctrl+ f10 and this will put it through to factory restore and hopefully it will not ask for youre password finger crossed if you do get in it then write the restore disks for next time using epowering tech it uses 2 dvds on mine and mine is the 7730 gud luck
just done some research and the default is 000000 try that out
i had sometime on my hands re download it from herehttp://www.acer.co.uk/acer/service.do?La... let me know if this does it if not ill keep trying im bored lol
before you do it just check the model i have entered is the same as yours ?
good luck
my guess is its the framework you need
May 15, 2011 | Acer Computers & Internet
How do i reset my pc to factory settings
my friends
go to setting in your mobile go to restore setting or go to factory setting enter the phone password which you have to set or already remember if you don't know your password then enter 1234 or 0000or123456789
okay thanks!
May 02, 2011 | Computers & Internet
Locked out of my blackberry curve 8520 smartphone
If you are locked out you can enter the wrong password several times and the phone will restore to factory settings. The downside to this is you lose everything unless you used the backberry server and saved!
Mar 02, 2010 | RIM BlackBerry Curve 8520 Smartphone
Compaq Presario S6000NX (DQ178A#ABA) PC Desktop Logo
43 people viewed this question
Top Compaq Computers & Internet Experts
pankaj rautela
pankaj rautela
Alun Cox
Are you a Compaq Computer and Internet Expert? Answer questions, earn points and help others
