Question about Refrigerators
Troubleshooting kenmore refrigerator
Model # 795.69974.902 light in the fridge will not come on when door is opened. The bulb is not burned out.
peyton32034
  • 410 Answers
SOURCE: Kenmore refrigerator light does not work
there is a tab in the bottom of the light socket that can get bent so that it wont touch the base of the new bulb. unplug your refrig and use a small screw driver and bend the tab back out a little bit so that it will contact the new bulb...
Posted on Dec 12, 2007
hapndnvegas
  • 35 Answers
SOURCE: How to reset fridge light - Kitchenaid side by side
this may or may not help. Most SMART devices forget their SMART functions when your unplug them and wait a few seconds then plug them back in this should reset it!!
Posted on Apr 13, 2008
22yooper
  • 828 Answers
SOURCE: Kenmore cold spot refrigerator freezer
I would look to the condenser where the heat is removed from the refrigeration system for your problem. Check and make sure the condenser fan operates, check the compressor for operation. If the condenser is plugged with dust it will cause the compressor to cycle on its thermal overload protector. Normally in back there is a removable panel to access the condenser and compressor area. make sure you reinstall the cover after you are done. It is critical to proper operation and cooling of the system.
Posted on Jun 01, 2008
SOURCE: Right Door is making loud popping noise
replace the door cam assy. and door stop.
Posted on Nov 05, 2008
jumptrout51
  • 3361 Answers
SOURCE: Can't find replacement light bulb:refrigerator model ET18DKXWW00.
Your problem may be in the bulb receptacle or the light switch.
If you have a voltmeter, let me know and I will tell you how to check it.
Posted on Mar 04, 2009
Why don't the lights come on on either side?
  1. How To Fix Refrigerator Light That's Not Working ' Fridge ...
    www.partselect.com/Repair/Refrigerator/Light-Not-Working/
    Troubleshoot the common reasons why the refrigerator light won't turn on. Checking the bulbs or lamps, inspecting the light socket for damage or discoloring.
Jul 10, 2015 | Kenmore Refrigerators
Lights in my kenmore refrigerator, freezer on bottom, burned out. I purchased two 60w bulbs and replaced them. I plugged in the refrigerator and the lights were on. Then a couple of minutes later,
Hello Sharon;
My name is Peter. I am a retired field service refrigeration technician.
You can not put normal house hold appliance bulbs in appliances. There are special bulbs for refrigerators, clothes dryers and close washers.
The bulbs are usually available in the local market and marked; "Refrigerator" and Freezer".
You may have a bad door switch. But, I am more prone to go with the wrong service bulb.
Your Friend,
Peter, Baltimore, Maryland, USA
Nov 16, 2014 | Kenmore Refrigerators
Kenmore sidexside light burned out. replaced bulb, won't light.
There is a plastic switch that works the light in the door jam. Unplugg the fridge before popping this plastic switch out. I would order one first but if your light fixture is in good shape and not burn on the inside and the wires look good it is most likely the door switch. The door switch is just like an on off switch for any light its just spring loaded to turn on when the door opens. good luck
Aug 15, 2010 | Kenmore 55612 / 55614 / 5561 / 655619 Side...
The four refrigerator lights on my Viking VCBB363 refrigerator do not come on when the door opens. One of the 40W, cylindrical bulbs is black, and obviously burned out. Do I just need to replace it? Unless...
They are not wired in series. Replace the bulb burned out and check the door switch of unit. If that is not working neither will any of the bulbs.
Sep 12, 2017 | Refrigerators
Light socket burning out
Due to not screwing bulbs in tight enough , and/or too high wattage lite bulbs ( 40 watt recommended ) .
Jul 31, 2009 | Kenmore 55612 / 55614 / 5561 / 655619 Side...
Whirlpool gold refridgerator light not working and is making funny noise
I had the same problem. Model Number GS5SHAXNL00 Light wouldn't work on the fridge side and the led's wouldn't light up. Ended up being a blown circuit path on the control board.
All I did was soder a wire between the 2 points that path was connecting and *BINGO* the lights are back on!
Hope this helps someone. To find the burned out spot just look for a little black smudge on the white plastic case when you remove the board.
Feb 16, 2008 | Whirlpool Gold White-on-White 21.9 cu. ft....
Fridge bulb burns out in fridge side
check to see if the light is turning off when you close the refrig door. its possible the door is out of adjustment and is not hitting the light switch properly when the door closes
Dec 12, 2007 | Kenmore 53642 / 53644 Side by Side...
795.77573600
I just saved my fridge / home too, smelled what I thought to be an electrical fire when I opened the Trio doors, immediately looked at the bulbs as a probable cause, and sure enough, the base of the bulb sockets were burned-brown and the plastic housing was to hot to touch without a hot-mit.
Unscrewed the bulbs and set aside out of children's reach and combustable materials.
I'm filing a complaint and service repair today. 8/3/08
Sean-Jon
Nov 07, 2007 | Kenmore 73502 / 73504 / 73509 Bottom...
Refrigerators Logo
35 people viewed this question
Top Refrigerators Experts
Charles T Nevin
Charles T Nevin
John Tripp
John Tripp
