Question about Garden
Qualcast Please can you advise me how /where to refit the flat metal deadmans lever spring inside the switch housing of a qualcast concorde 32 lawnmower. Thank You
5 Suggested Answers
rockitman187
  • 2559 Answers
SOURCE: JCB LS45 lawnmower - 2 stroke or unleaded petrol??
JCB LS45 specs Manufacturer: JCB
Blade Length in cm: 42 cm
Blade Width in cm: 40 - 44 cm
Cutting Width in cm: 42 cm
Electric Start: with Electric Start
Grass Collection Bin: Back
Horse Power: 3.5 hp
Mowing System: Rotary
Power Supply: Petrol 2 Stroke
Type: Walk behind mower
Posted on Apr 04, 2009
  • 6 Answers
SOURCE: what oil and petrol do i use for my qualcast
is it a two cycle or 4cycle do you mix your gas and oil or is it stright gas.
Posted on Jul 08, 2009
  • 16 Answers
SOURCE: Please advise on where to puchase replacement
Hi howardandjan, You call it "old Qualcast punch" if it's called Qualcast punch it's not that old, it was originally called Suffolk punch (after the horse) and came in 14" and 17" cuts, the 30s (30cm approx 12") was originally called suffolk colt. when Qualcast took over just about all the british cylinder mowers Atco,suffolk,webb etc they started swapping names about but you should be able to get parts from any good mower shop try winchester garden machinery in hampshire always found them helpful
Posted on Aug 31, 2009
SD Tech
  • 14553 Answers
SOURCE: how do I replace the on/off switch on my qualcast concorde 30 lawn mower?
Does the new switch have wires connected to it that are same color and switch is identical?
Posted on Jun 15, 2012
Finding a linkage diagram for a american yard pro mdl#hwsp2525b from mower handle to briggs & stratton mdl#12c802-0816-03 engine
1 cable goes to the deadman's handle to a silver spring loaded lever on the mower that the spring is stretched when handle is against upper mower handle. The other cable if equipped goes to carb for speed control.
Jun 07, 2016 | American Yard Products Garden
Why wont my classic kitchenaid mixer switch off
Good Morning,
There is a spring inside your mixer attached to the speed control switch and speed control arm, the spring can sometimes get caught on the slide bar that is just below it inside the mixer. The other reason is that the speed control switch plate in the rear of the machine (that the spring attaches to) vibrates the three speed adjustment screws out or in and the spring will pull the speed switch (control arm that you use to control mixing speed when using the mixer) back to the stir position after you try to turn the mixer off.
If it is a spring problem you will have to do a full tear down to get at the spring and either free it or replace it. If it is a problem with the adjustment screws on the speed plate, that can be handled at the rear of the machine and is twice as easy to get at but sometimes much more frustrating to adjust. There are "YouTube" videos on the internet that will walk you through the process of adjusting your speed control plate just Google "adjusting speed on kitchenaid mixer" I hope this helps. please let us know if it does and if you have other questions just post them here and we will "FixYa"
Sep 11, 2014 | KitchenAid K45SS Classic Stand Mixer
I need a repair manual for a Qualcast 32/Concorde lawnmower, any advice please.
go please to www.repairmanualdownloads.com
God bless you.
Jun 27, 2012 | Cars & Trucks
How do I replace the on/off switch on my qualcast concorde 30 lawn mower?
Jun 14, 2012 | Garden
The forward/reverse lever on my shoprider cooper is loose. How can I repair it?
hi, you need to take the tiller apart and refit the spring ... this does happen, a picture will help and i can advise you what to do ...
Regards
Rob
www.gewizrepairs.co.uk
Jun 09, 2012 | Shoprider Cooper Scooter in Red
I need the size of the poly v belt for a qualcast 4000 lawnmower.
Most time you don't have to get original parts like belts from the manufacturer. Suggest you go to a reputable lawn and tractor supply store where they can easily measure the belt and give you a comparable one for your machine. Hope this helps!
Mar 26, 2012 | Computers & Internet
Can't remember how to keep my Qualcast Suffolk running!
There is a video on u tube and a wed site the old lawnmowers club .
Jan 10, 2018 | Garden
Craftsman LT1000 ridign mower engine dies after 15 min-deadman on
There are several things that could be going on, but what you said in your description about the dead man switch in the seat may need your attention first. The switch it self could also be bad. After you rule this out the next thing I would check is the fuel shut off solenoid located on the carb when you turn the key on to run you should hear a click and feel it in the solenoid. After this you may have a fuel pump issue or a coil issue. but from what you I have described I believethe first 2 itmes I mentioned should fix your problem
Oct 08, 2009 | Craftsman 20 hp 42 in. Deck Lawn Tractor -...
Garden Logo
23 people viewed this question
Top Garden Experts
Dennis Key
Dennis Key
roeb
john h
