Question about Kitchen Ranges
Inoperative left eye dial
Left rear element dial will not engage and send a signal to the element to come on. When turning the dial after pushing it in it feels like an uncoiled spring being wound up and actually springs back a little bit after release.Is there a simple and inexpensive fix to this problem that I can do myself or will I have to have a service tech. We are old folks and don't have a lot of money! We have just sold our residence and need to repair this prior to house inspection. Thank You, Tom
SOURCE: ford escape Rear Suspension With Coil Springs - out of joint?
It is a 4x4. The "yellow" looking item in between/inside the black spring coil seems to be out of its joint. When I compare the left vs the right, the left side is sitting up high, while the right side appears to be settled into place.
Posted on Nov 13, 2008
  • 4 Answers
SOURCE: 99 Astro lift door latch left side inoperative
I slammed the door shut one time and the door wood not open at all. I had to take the inside door handle off and found that the cables simply came off of their post (inside the door) on the outside part of the door handle. More than likely only one cable has come off its post on your van. I hope this helps!
Posted on Jan 03, 2009
  • 226 Answers
SOURCE: passenger side rear brake locked up.
It's probably the emergency brake cable that is stuck. Check that first. When I get a drum brake that is totally frozen up (like been sitting for 40 yrs) I often use 2 or 3 pry bars, WD40 and short handle sledge hammer to pry a little on both sides, liberally keep penetrating oil squirted on the shoes and tap on all sides. Eventually drum will come off, but sometimes it takes like maybe 1/2 hour. Shoes will have to be replaced, but they are probably shot anyway. The drums for the caravans are cheap, so I would not only get them, but the spring kit from the parts house as well.
Posted on Apr 11, 2009
SOURCE: How to repair the left click button on HP Pavilion ZT1135
Hey,
I had the same problem. It is pretty easy to fix. You have one of two options to follow.
1) Push down moderately hard on the left mouse button. After 2 mins or so, and the cap should back on to the button on the bottom
2) if number 1 doesn't work get a needle or pin and lift the left mouse button off. Then just apply very little, not even a drop, maybe half of a drop to the button and apply the cap back on and push down.
Posted on Sep 25, 2009
  • 6468 Answers
SOURCE: Turn signal won't return automatically after a turn
you need to replace the turn signal switch there is a tab on the tip that get pushed by a canceling cam most gm dealers can get it for you i have a couple but i don't ship or take checks
Posted on Apr 13, 2012
2004 Chevrolet Silverado 2500 HD LS crew cab 6.0 4x4 right turn signal activates hazards. What would the steps be to diagnos this problem without purchasing parts that do not fix the problem
Do you know how to test automotive electrical circuit's using a wiring diagram an a DMM - digital multi-meter ? Do you know what a factory diagnostic flow chart is ? This will not set any diagnostic trouble code's in the BCM - body control module . Looking at factory symptom chart , their is no diagnostic trouble chart for your symtoms . Have four choices .
Hazard Lamps Always On
• Hazard Lamps Inoperative
Turn Signal Lamps and/or Indicators Always On or Flashing
• Turn Signal Lamps and/or Indicators Inoperative
Which one would you use to diagnose this problem .
Or would you just view wiring diagrams an wing it ?
Step
Action
Yes
No
Schematic Reference: Exterior Lights Schematics
Connector End View Reference: Lighting Systems Connector End Views or Body Control System Connector End Views in Body Control System.
Did you perform the Lighting Systems Diagnostic System Check?
YES - Go to Step 2
NO - Go to Diagnostic System Check - Lighting Systems
Verify that the turn signal lamps and/or indicators are inoperative.
Do the turn signal lamps and/or indicators operate normally?
YES - Go to Testing for Intermittent Conditions and Poor Connections in Wiring Systems
NO - Go to Step 3
Are only the turn signal indicators in the instrument panel cluster (IPC) inoperative?
YES - Go to Step 4
NO - Go to Step 5
Test the inoperative turn signal supply voltage circuit to the IPC for an open or high resistance. Refer to Circuit Testing and Wiring Repairs in Wiring Systems.
Did you find and correct the condition?
YES - Go to Step 21
NO - Go to Step 13
5
Is only one turn signal lamp inoperative?
Go to Step 6
Go to Step 8
6
Inspect the inoperative bulb/socket for an internal short, poor terminal contact, or an open filament.
Was a problem found?
Go to Step 18
Go to Step 7
7
Test for an open, high resistance, or short to ground in the turn signal lamp supply voltage circuit. Refer to Circuit Testing and Wiring Repairs in Wiring Systems.
Go to Step 21
Go to Step 16
8
Inspect the IGN E fuse and the FLASHER fuse.
Is either fuse open?
Go to Step 11
Go to Step 9
9
Test for an open or high resistance in the following circuits:
• The turn/hazard flasher battery positive supply voltage
• The turn/hazard flasher ground
• The turn signal switch ignition 1 supply voltage
Go to Step 21
Go to Step 10
10
Disconnect the multifunction switch, turn signal switch.
Test the multifunction turn signal switch for continuity between the multifunction turn signal switch ignition 1 voltage input terminal and the turn signal flasher signal output terminal in each respective position. Refer to Circuit Testing in Wiring Systems.
Is continuity present?
Go to Step 12
Go to Step 14
11
Test the following circuits for a short to ground:
• The multifunction turn signal switch ignition 1 voltage
• The turn/hazard flasher supply voltage
• The left turn signal switch signal
• The right turn signal switch signal
• The left turn signal lamps supply voltage
• The right turn signal lamps supply voltage
• The trailer left rear turn/stop lamp supply voltage
• The trailer right rear turn/stop lamp supply voltage
Go to Step 21
Go to Step 14
12
Test the following circuits for an open or high resistance:
Go to Step 21
Go to Step 15
13
Inspect for poor connections at the IPC. Refer to Testing for Intermittent Conditions and Poor Connections and Connector Repairs in Wiring Systems.
Go to Step 21
Go to Step 17
14
Inspect for poor connections at the multifunction turn signal switch. Refer to Testing for Intermittent Conditions and Poor Connections and Connector Repairs in Wiring Systems.
Go to Step 21
Go to Step 19
15
Inspect for poor connections at the turn signal/hazard flasher module. Refer to Testing for Intermittent Conditions and Poor Connections and Connector Repairs in Wiring Systems.
Go to Step 21
Go to Step 20
16
Repair the ground circuit of the inoperative lamp. Refer to Wiring Repairs in Wiring Systems.
Did you complete the repair?
Go to Step 21
17
Important: Perform the set up procedure for the IPC.
Replace the IPC. Refer to Instrument Cluster Replacement in Instrument Panel, Gages, and Console.
Go to Step 21
18
Replace or repair the inoperative bulb/socket.
Go to Step 21
19
Replace the multifunction turn signal switch. Refer to Turn Signal Multifunction Switch Replacement in Steering Wheel and Column.
Go to Step 21
20
Replace the turn signal/hazard flasher module.
Go to Step 21
21
Operate the system in order to verify the repair.
Did you correct the condition?
System OK
Go to Step 3
Jan 06, 2018 | Chevrolet Silverado 2500HD Cars & Trucks
2007 Ford Explorer flasher relay
There is no flasher relay , all done electronically by the smart junction box (computer )
The smart junction box (SJB) monitors the multifunction switch position by sending multiple voltage reference signals to the multifunction switch. When the multifunction switch is in the LH or RH TURN positions, or the hazard lamp switch is engaged, that input signal is routed to ground.
When the SJB receives an input from the multifunction switch indicating a request for a turn signal or hazard lamps, the SJB then supplies voltage to the appropriate turn lamps.
Your best bet would be to take it to a qualified repair shop or dealer .
Do you know what DTC'S are ?
Smart Junction Box (SJB) Diagnostic Trouble Code (DTC) Chart DTC Description Action B1499 Lamp Turn Signal Left Circuit Failure Go To Pinpoint Test M . B1502 Lamp Turn Signal Left Circuit Short to Ground Go To Pinpoint Test M . B1503 Lamp Turn Signal Right Circuit Failure Go To Pinpoint Test M . B1506 Lamp Turn Signal Right Circuit Short to Ground Go To Pinpoint Test M . B2048 Left Rear Turn Lamp Circuit Short to Ground For Mountaineer, Go To Pinpoint Test M .
For Explorer or Explorer Sport Trac, REFER to Stoplamps in this section. B2049 Left Rear Turn Lamp Circuit Open For Mountaineer, Go To Pinpoint Test M .
For Explorer or Explorer Sport Trac, REFER to Stoplamps in this section. B2050 Right Rear Turn Lamp Circuit Short to Ground For Mountaineer, Go To Pinpoint Test M .
For Explorer or Explorer Sport Trac, REFER to Stoplamps in this section. B2051 Right Rear Turn Lamp Circuit Open For Mountaineer, Go To Pinpoint Test M .
For Explorer or Explorer Sport Trac, REFER to Stoplamps in this section. B2071 Hazard Switch Signal Short to Ground If the hazard lamps are inoperative, Go To Pinpoint Test N .
If the hazard lamps are always on, Go To Pinpoint Test O . B2281 Right Turn Switch Short to Ground Go To Pinpoint Test L . B2282 Left Turn Switch Short to Ground Go To Pinpoint Test L . All other DTCs - REFER to Section 419-10 .
Apr 22, 2017 | Ford Cars & Trucks
99 windstar driver side turn signal not working left rear flashes fast
computer glitch do not know if you got last answer so here we go again
You have a right front or rear turn signal/parking light bulb blown.
turn on flashers it might help locate which one .
Remove the lens cover push and twist to remove blown bulb
replace with 1157 2 element bulb
install reverse order
Hope this helps Mike
Jan 18, 2016 | Cars & Trucks
Brake light on driver side isn't working tried changing fuse and bulb and still no luck ?
Sometimes the housing the bulb is in has gone bad try cleaning out the prongs where the bulb goes in it that does not work replace the fixture the bulb goes in had the some thing happen to my trailblazer hope this helps
Jul 31, 2015 | 2006 Chevrolet Chevrolet Cobalt LS
Have a 2009 chevy cobalt. the left turn tail light even though not fused will not blink, and the left indicator light flickers too fast. the right though is working perfectly
Buy a two pack of turn signal bulbs. Change the front and rear left bulbs and try it out. If you're lucky, you're done and got away cheap. If not, start chasing electrons. Not an overly complicated circuit, the signal is quick flashing because you have an inoperative lamp.
Mar 14, 2015 | 2009 Chevrolet Cobalt
Left bleaker and break light not working. Turn signal works bleaks faster than right side.
Has the vehicle been in an accident on the left rear side. First check the bulb to be sure it is not defective, trade it out with the side that works properly to test. If the bulb works well then My thought are you may have a shorted wire. The turn signal flasher works by heat build up within the flasher the heat is caused by the load of the bulbs, the load heats the metal spring causing it to open the circuit then as quickly as it cools down the circuit closes again lighting the bulbs.
There is also a possibility of a defect in the turn signal mechanism on the steering column. The turn signal switch on many models does three different things on many models that use the same bulb element / or bulb for brake and turn on rear of vehicle. It controls the circuit for brake light by sending power both left and right side rear when turn signal is in neutral position then when turn signal is in left turn the switch cancels brake light power to left side rear and supplies flasher power to left side while maintaining brake light supply to the right side rear, and so on opposite when the right turn is chosen on turn signal switch. The turn signal indicators on the dash normally run off the same circuit as front turn signal bulb only which is also controlled by turn signal switch. Front has turn signals but no brake light.
I think there is an additional load on the left side rear turn circuit and it could be either a wire that is shorted or the turn signal switch if the same bulb element is used for both functions.
Often times if trailer lighting is connected the flasher will also blink a little faster because of the extra load of additional bulbs.
Feb 15, 2015 | Cars & Trucks
Only right turn signal works. The left side has failure on front and rear lights and the left indicator fails to light illuminate as well. I have changed front and rear bulbs but the problem still...
Ok, there is only a few things that could cause this. They include:
handlebar directional switch on inoperative side not functioning.
broken or disconnected wire in the directional switch circuit
a possible combination of causes found in problem #1.
module malfunction.
You need to test the left turn signal switch to make sure it has voltage going to it and when you press the switch, 12 volts is going to the turn signal cancelling unit. This 12 volt pulse from the switch is what tells the module to turn the left turn signals on. Without the pulse, the module doesn't know you've pressed the switch. You may need a wiring diagram to trace this out. Sorry but I don't have one for that year model.
Good Luck
Steve
Nov 16, 2010 | Harley Davidson FXDI Dyna Super Glide...
My left rear turn signal is out on my 2006 Malibu. The bulb is good, but I replaced it anyway since I had the assembly apart. The left front flasher works fine as well. Before I try and replace any...
Stop lamp an hazard lights work ?
The body control module (BCM) is responsible for controlling the turn signals and hazard lamps. When the turn signal switch is placed in either the left turn or right turn position, the BCM receives a signal from the turn signal switch. The BCM then sends an on-off voltage signal to either the left or right turn signals and their instrument panel cluster (IPC) indicator. When the hazard switch is pressed, the BCM receives a signal from the hazard switch. The BCM then will send an on-off voltage signal to all the turn signal lamps. All the turn signal lamps will flash including both IPC turn signal indicators.
Repair an open, high resistance, or short to ground in the inoperative turn signal supply voltage circuit. Refer to Circuit Testing and Wiring Repairs .
May 16, 2017 | 2006 Chevrolet Malibu
Saturn Turn Signal / Dome Light Issues
The interior lamps system consists of 2 main features. Illuminated entry and a battery saver feature that will turn the interior lights off after 20 minutes if they are left On with all doors closed and the ignition Off. The body control module (BCM) controls both of these functions. Battery power is supplied by the BCM through CKT 1732 to the following lamps:
• The dome lamp
• The map lamps
• The rear reading lamps
• The rear dome lamp
• The cargo lamp
• The glove compartment lamp
• The courtesy lamps
• The sunshade lamps
The BCM also controls the ground circuit side of the dome lamp and reading lamps for illuminated entry. The dome lamp and reading lamp will remain on for 20 seconds after the ignition key is removed and the last door is closed. In addition, if the vehicle is equipped with remote keyless entry (RKE), the dome and reading lamps will turn On and stay on for 20 seconds after an UNLOCK signal is received from the keyless entry transmitter.
The reading lamps, dome lamp and map lamps can be turned On at any time by moving the appropriate switch to the On position.
The rear dome lamp is fed battery voltage through CKT 1732 from the BCM, through the liftgate ajar switch, and is grounded through CKT 650 to the rear ground splice pack. The rear dome lamp will turn on when the liftgate is opened. The cargo lamp is fed battery voltage through CKT 1732 from the BCM, through CKT 744 and grounded through the decklid ajar switch.
The courtesy lamps are fed battery power through CKT 1732 and are grounded through CKT 745-- left front, CKT 747--left rear, CKT 748--right rear, CKT 746--right front. These circuits will ground through the door jamb switches. The courtesy lamp will be illuminated when the affected door is opened. For example, when the right rear door is opened, the right rear door courtesy lamp will turn on.
Not a fuse problem , if the BCM had blown fuse other thing's wouldn't be working as well . . Probably wiring or BCM . Using factory diagnostic,s instead of guessing as to what the problem is , is the proper way .
Interior Lamps Diagnosis
Symptom
Procedure
Important: Before proceeding with these diagnostics, check for DTCs. If DTCs are present, complete the associated diagnostics. If the condition still exists, return to this chart.
All of the interior lamps are inoperative when any door is opened.
Chart 1
The dome lamp is inoperative in the ON position, but OK in the door position. The map lamps operate normally.
The dome lamp switch is faulty. Replace the dome lamp switch.
The dome lamp is inoperative in the DOOR position, but is OK in the ON position.
Chart 2
The dome lamp is inoperative in any position and both reading lamps are inoperative.
Disconnect the dome lamp connector (BLK 3-way).
Check for voltage at terminal "C" CKT 1732 ORN wire.
If OK, the dome/map lamp is faulty. If no voltage is present, there is an OPEN in CKT 1732.
Either the right or the left sunshade mirror lamp is inoperative.
Chart 3
Either the right or the left rear reading lamp is inoperative in the ON or the DOOR position.
Chart 4
The rear reading lamp is inoperative in the ON or the DOOR position.
Chart 5
Battery rundown protection is shorted to ground - B1482.
B1482
The left rear reading lamp is inoperative in the ON or the DOOR position.
Chart 6
Dec 12, 2017 | 1998 Saturn SL
Does not work...displays "EE" only when pluged in.
Try contacting Bravetti/ Shark for manual or perform a european search for the manual. EE might equate to temperature sensor damaged by overheating thus the signal is being send to the microprocessor as inoperative in the firmware.
This design had no safety features for cutting off the heating element if kettle boiled dry - so if you left the kettle on without water the temperature sensor would overheat and become inoperative.
I hope this assist.
Jan 02, 2008 | Bravetti EK119H Electric Kettle
Kitchen Ranges Logo
21 people viewed this question
Top Kitchen Ranges Experts
Dan Webster
Dan Webster
Paul Carew
Are you a Kitchen Range Expert? Answer questions, earn points and help others
