Question about KitchenAid Ovens
Electronic control board
I have a kitchen Aid Superba that is about 10-11 years. I have not overly used the oven, as I do not bake alot. The cooktop is working perfectly, however the oven is not heating. When I push the button to turn on the oven, it shows on and there is a clicking noise inside the oven as if its going to turn on however the element does not heat up inside. The clock works. Any suggestions as to what can be happening with the oven and how to repair? Thanks in advance.
  • 347 Answers
If you are hearing a clicking sound, that would be the igniter trying to light the gas, however you said elements not heating up which says it's electric... hmmm. If it's electric, try the broiler and see if the element comes on. It's pretty easy to troubleshoot by process of elimination. By all means do not try and repair it yourself unless you are qualified working with electrical.
Posted on Jun 14, 2017
  • 1314 Answers
SOURCE: kitchen aid wall oven kebs177dssp
call whirlpool tecnical assitance see if they have a kit for it tech knows parts people dont most of time they do beleive or not they want it to work right been working for the factories for years and they doo care
Posted on Dec 29, 2007
  • 10865 Answers
SOURCE: oven will not heat.
Usually, when an oven won't bake, it's because the bake element is burned out. The bake element is the black, pencil- thick tube at the bottom of the oven. When the oven heats, the element glows red. This element has an expected life-span of several years. It may last for only one; it may last for many more. When the element burns out, you need to replace it.
It bakes poorly Here are two instances of when food "bakes poorly:"
  • When the food you're baking is done on top but not on the bottom--or when baking just takes far too long to finish--the bake element may be burned out.
    You may get fooled into thinking it's working, because the oven is hot inside. But many electric ovens use the broil element, too, during the preheat and bake cycles. So the food may be getting heated only by the broil element, which causes poor baking results.
    If the bake element is burned out, replacing it should solve the problem. Otherwise, you need to further troubleshoot the oven's electrical system to locate the defective wire or component.
  • When the temperature is consistent but too high or too low, it could be one of several different things. First check to see if the thermostat sensing bulb has come loose from its holder. It could be lying on the floor of the oven or resting on the heating element. This would cause the oven to not heat correctly.
    If the thermostat bulb is not dislodged, it's likely that the thermostat or sensor is either mis-calibrated or defective.
    Electronic ovens with a digital display use a sensor to monitor oven temperature. To solve temperature problems for these models, you may need to replace the sensor. On some digital-display models, you can calibrate the temperature using the key pad. See your operator's manual for details.
    Ovens without a digital display often use a mechanical system for controlling temperature. On many of these units, you can remove the thermostat knob and adjust the knob itself to more accurately represent the actual setting of the thermostat.
    If, when you remove the knob, there's a screw on the back of it with a small calibration plate, you can loosen the screw, adjust the plate, then tighten the screw again. If the knob isn't adjustable, and the oven temperature is off by more than 30 to 40 degrees, you need to replace the thermostat to solve the problem.
Posted on Jun 02, 2009
  • 1531 Answers
SOURCE: My oven says that it's on (heating up or cleaning,
no i do not think your elements are soundsd more like the main control board has malfunctioned.
Posted on Sep 16, 2009
Testimonial: "Thanks, I'll take a look."
  • 187 Answers
SOURCE: bake element does not heat up
This would be a good candidate, but not necessarily an absolute. Selector switches, loose wires, fuses, and a few other sundries could also be the cuprit. Make sure that the new element that was installed is the correct one for your model. I am assuming that the element was replaced?
If not, by all means, check the element. Elements only last a few years. Just because the plug it plugs into has current, it doesn't mean that the element itself is any good. By far, a burned out element is the most common, easily fixed failures.
Unplug or shut the appliance off at the breaker. Pull the element and visually examine for burnt or rough spots. The elements either pull directly from the housing, or are held in place with a few screws. Bad elements sometimes look totally normal.
If the bottom and top elements are the same( they usually are) a simple check would be taking out the broiler element and then swapping for the bake element. If the broiler element works in the bake position, buy a new element and ask for a refund for the service call.
I can't understand why the service person did not pull the unit and check voltage in the control before making an absolute diagnosis. The circuit board is usually well over 100.00. The unit also sometimes comes with a diagnostic feature that homeowners/techs can use to test the "ERC" without even taking it out of the range.
If you have your owners manual, check the trouble shoot section. If not, Sears has some manuals and repair help/parts online, and Whirlpool is among the best companies in terms of customer supports. I don't know your model, so I can't be too specific with advice. The link for Whirpool has a search engine you can use for your exact model. This link is for most newer models. Among other online resources, Repair Clinic" has parts that you can order online, and they also have diagrams that can help out significantly if you do change the unit out yourself. If it is something cheap like an element, it is helpful to go to an appliance store where you can return the unit a little easier. Thanks for your question, please leave comments if you need further advice.
Posted on Dec 14, 2009
SOURCE: model FEFL78CBC frigidaire oven bottom (bake)
We had the same thing happen and now they came and said it was the clock that needs to be replaced. They said that controls the oven. Even though clock is on and working the function for turning on the oven is not
Posted on Mar 16, 2010
Error 40 on kenmore convection oven
The 40 error code indicates a failure of the cooktop lockout board. The cooktop lockout board is not communicating with the main EOC electronic oven control. This could be a loose wiring harness or either the EOC board or cooktop lockout board is faulty. This type of diagnosis will require using a volt/ohm meter. If you decide to check the harness to the boards you will need to remove the back panel for access.
Oct 15, 2017 | Kenmore Ovens
Kitchen aid oven
if you put your volt meter leads across the bake element you should be getting 240 volts when its in the bake cycle.
Its sounds like the control board is bad.i suggest you call a local repairman...
Aug 07, 2008 | KitchenAid Architect Series KEBC107KSS...
Why the cooling fan does not work on one the upper over of KEBS278
First check that the fan itself has not failed. If the fan and wiring are ok, your EOC (electronic oven control) has failed. This is NLA (no longer availabe). The Whirlpool part number is 3187895. This can be rebuilt: See:
Aug 24, 2014 | KitchenAid Kitchen Aid KEBS277SWH Double...
Kitchen Aid Superba double oven
f5e1 is a door locking error. try shutting off power for a minimum of 2 minutes to reset the control board. If you still get the error replace the latch. Here is the part to order.
Jun 19, 2013 | KitchenAid Architect Series KEMC308KSS...
I have a 5 year old Kitchen Aid duel fuel slide-in range. I have used clean twice since I got it. I tried to start clean today and it all went fine until I noticed after about 30 minutes that it was not...
Hi Cynthia
F5 error code normally means control board or clock failure. It means you will have to have a new control board and clock fitted.
Dec 18, 2010 | Ovens
Kitchen aid wall oven Model YKEBS2780B1 SHOWS
Hello,4 Digit Failure Code F0 - E0 Analog to Digital Failure Disconnect for 30 seconds - if display re-appears - replace control F1 - E1 Safety flip flop Replace Electronic Range Control/Clock(ERC) F2 - E0 Shorted keypad Replace Electronic Range Control/Clock(ERC) F3 - E0 Oven temperature sensor or oven temperature sensor fuse opened Replace oven temperature sensor or fuse F3 - E1 Oven temperature sensor shorted Replace oven temperature sensor F3 - E2 Oven too hot Replace oven temperature sensor F3 - E3 Clean temp too hot Replace oven temperature sensor F5 - E0 F5 - E1 and E2 Check door/latch switch Replace component 2 Digit Failure Code F0 or F1 or F5 Failed transistor Replace Electronic Range Control/Clock(ERC) F2 - E0 Oven temp too high 1. Test operation of door lock on self-clean models
2. Test relay contact operation
3. High resistance in oven temperature sensor F3
May 26, 2010 | Ovens
Kitchen Aid Oven - Superba Selectra- receive
Here is what Kitchen Aid says about F4:
F4 Meat probe shorted
1. Disconnect meat probe and measure probe resistance (78kω at 60° F [15.6° C],
37kω at 90° F [32.2° C]).
2. If resistance is not valid replace probe.
3. Insert probe and check for a firm connection between probe and jack (in oven cavity).
4. Check connection between jack and harness (in rear of oven).
It sounds like the probe jack may be bad or the wiring between the jack and the control board above.
May 10, 2010 | KitchenAid Architect Series KEMC308KSS...
Our Superba (what a joke) Model KEMS308 / KEMS378 has the exact same temperature probe problem where the plug where the probe is inserted is supposedly getting dirty BECAUSE THERE ISN'T A COVER OVER IT...
Common Problem, design defect allows moisture or corrosion on terminals, to cause this problem. Two ways of repairing this. 1: Plug probe in, hang probe out the door, input 160 degree probe temp, turn convection bake to 450 degrees and let it bake for a while. Turn unit off, unplug probe and test to see if the problem is resolved. If it is moisture, the high heat bakes out the moisture and resolves the issue. We have also had some luck with a hair dryer blowing on the probe receptacle to dry out the receptacle. 2: You can pull the entire unit out of the wal with the power off at the circuit breaker, remove the backing panel, and disconnect the wiring to the probe. Some units you have to remove a side panel instead. You won't be able to use the probe in the future if you do this, and you do have to insulate the wires terminals or plug. As always, if you don't know what you are doing with electricity, call a technician to do this repair, it is better to be safe. Also as an aside, I work on all brands of ovens and we find that the Kitchen Aid models have the fewest repairs and the greatest reliability, everybody has design defects and most of the other brands have deliberately built in these defects for faster replacement. The only advice on the Kitchen Aid units that I recommend is that when you do replace it that you buy a separate oven and seperate microwave oven. Most microwave ovens are only lasting 8 to 15 years before major repairs, yet the ovens last 30 to 40 years. Good Luck, Appliance Specialists
Jan 03, 2010 | KitchenAid Architect® KEMS378S Electric...
Kitchen Aid microwave door -- outer glass
Lisa, I do not have a solution, but have the same problem. My KA superba micro has been used about 10 times. While it was off, and while no one was home, the outer glass in the door shattered. I suspect this may be a defect.
Jun 19, 2009 | KitchenAid Architect Series KEMC308KSS...
Kitchen Aid Superba Double Oven
Remove the oven from the wall. Remove the rear panel.
The upper and lower ovens have a non-resettable thermal fuse that has blown.
Use a VOM to verify which fuse. After repair use Easy Off, not self clean.
May 24, 2009 | Jenn-Air Electric Double Oven
Ovens Logo
43 people viewed this question
Top KitchenAid Ovens Experts
Dan Webster
Dan Webster
Are you a KitchenAid Oven Expert? Answer questions, earn points and help others
