Question about Baby Gear
Kingston portacot side does not lock into place keeps collapsing
3 Suggested Answers
  • 223 Answers
SOURCE: it keeps collapsing
You might be lucky, call Dorel uk & explain it to them,
Posted on Aug 21, 2010
SmartAlec
  • 171 Answers
SOURCE: The telescopic wand on my Miele S5281 keeps collapsing, how can I fix it so it locks in place.
Hi There,
You can get a button repair kit and it should fix your problem which is normally a loose spring. In Australia VacuumSpot sell these over the net.
Posted on Jun 14, 2012
Hi There,
Jun 12, 2012 | Miele S5281 Callisto Bagged Canister...
Memory card unlocker
Micro SD (secure data) cards store information such as Word, image and video files.
Kingston microSD cards are used in many settings, such as schools, businesses and government offices, to protect data.
Some Kingston microSD cards are locked for added protection.
In the locked position, you cannot add or delete data from a microSD card.
You will need to unlock your Kingston microSD card in order to save data on it or delete data from it.
Remove the Kingston microSD card from whatever device it is kept in, whether it's a storage case, a digital camera or a GPS.
Find the small plastic switch on your Kingston microSD card.
If you are looking at the microSD card with the arrow pointing away from you, the switch will be on the right side of the card.
Flip the switch on the card to the unlocked position.
This will enable you to store and remove files on your Kingston microSD card.
http://www.kingston.com/flash/securedigital.asp
Jan 24, 2012 | Kingston 1 GB microSD Card with USB 20...
I don't know how to set up my travel lite crib bassinet
You're not alone. If you do every step perfectly then it's a breeze. Most of us are human and don't... This frequently results in a major pain.
Most travel cribs print the directions on the pad that lines the bottom of the crib. Unfortunately, this still isn't much help. I'm going to assume that you're like most of us- you've read the directions and you still can't get the thing to cooperate!
I fought with my Graco travel crib many times before I discovered a few secrets:
- Follow the directions precisely, even if a step seems a bit odd.
- If you get going on it and mess up (or it just won't stay up), give it up and start over again from step 1.
- Before you start, make sure that it's completely collapsed. It may look like it is, when it isn't. Here's how you check:
There should be at least one handle near the middle of each top pole that can be squeezed (longer sides sometimes have two). Feel your way across the top pole until you find each lever and squeeze it. This will collapse the pole into two (or more) sections.
Make certain that the poles remain collapsed as you pull the center handle (center of crib where matress will go) towards the sky and squish the whole thing together like you're putting it back in the box (or carrying case.) Now we're ready to start!
1) Gently begin to unfold/open the crib as you hang onto the handle in the center.
2) Continue to hold the center handle with one hand. With the other hand, lift each top pole until it locks into one "solid" pole. NOTE: This is trickier than it sounds! If the center handle drops even half-way down then you won't be able to get all poles to lock and you'll have to start over again.
3) Only after all four top poles have been locked, can you push down the center handle. This will spread the bottom into one flat piece and finish locking everything in place.
Good News!: It's all downhill from here!
4) Put a sheet on the "mattress", if desired.
Otherwise, just unfold it and place it in the bottom of the crib. There are some strange little velcro tabs on the sides of the mattress. These fit down the slits in the bottom of the crib and attach to the underside. This step is important as it keeps the mattress in place and helps to reduce the risk of suffocation.
5) Finally, assemble the canopy, locate all the little snaps on the side, and snap on the accessories.
Whew! Take a deep breath... you did it!
Congratulations on your baby! Enjoy!
Jun 24, 2010 | Graco Travel Lite 9001 Crib
It keeps collapsing
Apr 16, 2010 | Quinny Buzz Three Wheel Stroller
One side won't lock after collapsing and moving to new location.
I went thru that too. Try unlocking all other sides and lock the problem side first....I had to literally grab it with both hands and pull up hard to get it to lock. It happens from time to time and sometimes I have to pull up on it a couple times to get it to lock.
Aug 05, 2009 | Graco 9445DOH Crib
Fold and lock stroller
The handle twists after you press the red tab on handle, there should be a red little flap than is the way to hold collapsed. A bag???? buy a hockey duffel.
May 18, 2009 | Graco Quattro Tour Deluxe Travel System -...
Can't get evenflo babygo pack and play support bars to lock
Pull center floor up, then lock all top rails, then push down on center floor.
Jan 16, 2009 | Baby Gear
Installation
please give me kingston pen drive driver
Aug 05, 2008 | Kingston (DTIU3/2GB) 2 GB USB Hard Drive
My Kingsto Mini Sd
unlock it on side bar then formatt it
Jan 16, 2008 | Kingston flash memory card - 256 MB -...
Baby Gear Logo
24 people viewed this question
Top Baby Gear Experts
Jennifer Rock
Jennifer Rock
Douglas Dinnebeil
Douglas Dinnebeil
Are you a Baby Gear Expert? Answer questions, earn points and help others
