How do you know it goes into gear if it won't move ?
Can you put it in gear and move the car with the engine off ?
Touch? lmao. I did put it in gear with car off (after you enlightened me of course) and I don't know what this means but in reverse I was able to push it forward
If the clutch is working, and the trans is in any gear, you should not be able to move the car. So if you can, either the clutch is not engaging the flywheel, or the main shaft is broke inside the transmission.
You may be able to pull the starter or take the inspection plate off the bottom of the bell housing and verify the clutch is against the flywheel.
Thank you
SOURCE: gearbox spinning,with clutch depressed,gearbox crunching.
needs a new clutch ,pressure plate dragging caused by worn springs
SOURCE: My Clutch won't engage into gear. Need advice!
Did you check the clutch reservoir under the hood mounted on the firewall, driver side? Make sure level is up where it should be. If it's real low, you may have to bleed the system to get the air out. If you need to add fluid, use brake fluid.
SOURCE: clutch clicks into gear but theres no movement
This can be difficult to answer properly without a bit of knowledge on operation. If you can get it into gear with the motor running then clutch should be working.With that said, on to why it doesn't move acn be several things. Axle dislodged from transmission or broken CV joint, input shaft to clutch ana pressure plate damaged in some way,differential damage, shifter broken off internaly or broken cable, < should be able to feel this >. inspect axles to confirm they are not damaged or dislodged, inspect shifter to confirm it is operating like it should, < have someone move shifter and watch arm on transmission to confirm it is operating > at this point if you haven't found anything to have failed then would suggest having it looked at by someone who can tell you what cause is. I am not implying that the clutch has no damage to it,but other reasons can be cause. There is an inspection plate on bottom side of bell housing that can be removed to inspect for damage, < where engine and transmission connect>.
SOURCE: clutch pedal goes to the floor
you nead a new clutch as it sound like it has fel to bits ,, from age or hard driving
SOURCE: toyota supra turbo 1990, manual (7mgte engine) Clutch problem
You ever think about replacing your rubber clutch line with a hard line or just replacing the rubber line
