Question about Kenmore Washing Machines
5d error code kenmore he2plus
5d error message on my kenmore he2 plus front loader washing machine??? Was able to open washer and get clothes. No water and clothes seemed to be normally spun.
  • Taffy stein Apr 29, 2013
    Thank you. I can't believe how smelly and gross that was. Also amazed I fixed it:)
  • Anonymous Nov 09, 2015
    Some silly things tend to be so 'complicated' !!
    President:
  • Kenmore Master
  • 662 Answers
Here's a video prem mathew suggested as a solution to your problem from YouTube:
Kenmore He2 washing machine washer drain problem fixed
Posted on Apr 30, 2013
5 Suggested Answers
  • 7 Answers
SOURCE: regarding the kenmore he2 plus front loader
There is a strainer on the drain pump that is clogged. The manual does not mention this at all, it merely states the drain hose is kinked or clogged.
Under the front door there is a panel that is the width of the machine and is held in place by two screws, one on either side.
When you remove that you will see the pump and the the strainer attached to it. Unscrew the strainer (put a small pan under it to catch excess water) and remove to remove the junk accumulated.
Also, attached to the panel is another manual that refers to the error codes you are seeing.
Posted on Jan 05, 2010
SOURCE: My Kenmore HE2 Plus Front Load washer won't drain...
We have the exact same washing machine, and the same problem. we will need to lift the front of your washer up and undo the bolts to the front cover. you will see a white round turn nob, this is the filter unscrew it (you kight plug your nose) and empty all contents, replace, screw the front plate back on and you are good to go!
Hope this helps, i wish someone would of helped us!!
good luck
Posted on Jan 31, 2009
  • 220 Answers
SOURCE: f21 code on kenmore he2 plus
Clean the filter in the pump behind the bottom panel,but remember it's full of water,If it's on a pedestal you can take the pump loose from the mounting pull it out a little and put a small pail or bucket under it before you open the trap.if it isn't on a pedestal it's a bit more challenging unless your in a basement with a floor drain. Open it very slowly and let the water drain a little at a time don't take it all the way out or you'll be in for a flood....good luck
Posted on Sep 03, 2009
  • 5 Answers
SOURCE: Kenmore HE2 front load washer. All cycle lights flashing plus spin and clothes clean lights on.
I'm sure this is probably too late, but hopefully it will help some else. I just had the same problem. First, unplug the power. Then take the lower front panel off and grabbed a bucket. Place the bucket under the large "plug" on your right. This is the drain. Slowly unscrew the drain plug, Hold your nose as it will probably smell. Allow the water and such to drain into the bucket. When you see the blob of wet lint drop into the bucket you will know why the machine refused to work. Make sure you clean the drain plug and screw it back in tightly. Put the lower panel back on and reconnect the power. I hope this resolves your issue.
Posted on Oct 10, 2009
How to fix code 5d
The 5d error on most front-load washers is a Suds error. This can be caused by using too much detergent, a non-high efficiency washer detergent, foreign objects in the pump filter, or a problem with the pump or water pressure switch.
First look in the window of the machine while it's running, do you see a lot of suds? If so, remove the clothing from the machine. Then run the washer while it's empty without additional detergent. You may need to do this a few times to rinse the excess detergent. Then try washing the removed clothes again without adding more detergent to clean them.
Next, open the washer and look for the pump filter. Remove any foreign objects. Look at the impeller and the pump and make sure that nothing is in that section of the washer.
To check if the pressure switch is sending faulty information to the main control of the washer, unplug the washer. Remove the top and find the pressure switch (probably on the left rear of the machine). Remove the hose from the bottom of the switch and blow into it. If the hose is clear, then the pressure switch should be replaced first.
If you add a comment with the model number of the HE2 Plus washer, I will be able to provide the parts diagram showing the pump and filter. I'll also be able to point to replacement parts. Most Kenmore appliance parts diagrams are available at searspartsdirect.com .
I hope this helps.
Jul 25, 2016 | Kenmore Washing Machines
F-24 error code so I ran a clean washer cycle, and the laundry room is now flooded.
what's f24 code? - Kenmore Elite HE3 Washing Machine ...
https://www.ifixit.com/Answers/View/85549/what's+f24+code
iFixitAug 21, 2015 - Aiman, The F24 error code indicates a water temperature sensor reading that is ... The Kenmore Elite HE3 is a washing machine by Kenmore.
F24 Error Code on My Kenmore Washer ' eHow
www.ehow.com > Home
F24 Error Code on My Kenmore Washer. Kenmore washing machines have several high-tech features, such as a stain treatment option, reduced energy and ...
Kenmore HE2 Plus Front Load Washer F24 error code ...
www.fixya.com > ... > HE2 > Kenmore HE2 Plus Front Load Washer
...error code F24 I have a Kenmore HE2T washer and I keep getting an F24 error on it.. I have no idea what is means can't find the manual help!!! The "F24" error ...
I have a Kenmore HE2T error code F24 - Fixya
www.fixya.com/support/t3608391-kenmore_he2t_error_code_f24
Dec 9, 2009 - Posted on Dec 09, 2009.
Dec 06, 2015 | Kenmore HE2 Plus Front Load Washer
Kenmore HE2Plus White Front Loader. Drain pump seems weak, wet clothes, and f-21 flashing..???
Hello & Welcome to FixYa
F21 error code is displayed when the washer is unable to drain, press PAUSE/CANCEL button twice to clear the display. After this please check the drain hose and drain pump filter for any blockages and make sure it is not clogged with foreign particles. You can also check the drain pump to verify that its working. Please get back to me if you have any other questions.
Kevin
Mar 07, 2011 | Kenmore HE2 Plus Front Load Washer
Error codes
Kenmre HE2 Plus front loader has a F 28 error. Whats the problem and how do I fix it?
Jan 19, 2010 | Kenmore HE2 Plus Front Load Washer
Kenmore front load washer (HE2Plus)
check to see if you still have a warranty on the washer other than that check the inner door seal if worn or crimped try to fix or replace it
Dec 16, 2009 | Kenmore HE2 Plus Front Load Washer
Kenmore front load HE2 plus
I have a F01 error message on my Kenmore He2t washer. I tried to add clothes to a wash and restart and continue to get the message. Please help
Jun 14, 2008 | Kenmore 46462 Front Load Washer
Washing Machines Logo
568 people viewed this question
Sal De
fordexpert
Jim Goldsmith
Jim Goldsmith
