EA - Electronic Arts The Sims?  for Windows
Problem for EA - Electronic Arts The Sims? (Deluxe Edition) for...
Im having problemx installibg sims deluxe edition
By mz_bridg_ett on Mar 13, 2009
need help to install sims
Best Solution
posted on Mar 13, 2009
Very Helpful)
MATRIX_MMX
Rank: Guru
Rating: 89%, 81 votes
Dear mz_bridg_ett,First of all you need to check that your computer hardware/ the entire computer meets the specifications of the game. you will be looking at things like
CPU speed -- the higher the number in MHz you have the better
RAM speed -- this is your computers' memory, the bigger the number in MB/ GB and MHz the better
HDD size -- this is your hard disk drive, bigger the number in GB the better. . . . typical size is 120-500Gb and will be enough for the game . . . . . . more than enough even with Windows (EWWW YUCK!! ) installed on it.
GPU speed-- this is your graphics disply, and like the rest, the bigger the number the better, best to check out your specifications before you attempt to play the game.... ideally you want a direct x 9.0c card or better still direct x 10 when in windows (YUCK) go to start>run>command>dxdiag ... this will check that for you
Right with that lot done, open your CD drive, and put the install disc into the drive, and it should start to run automatically. . . . if not go to my computer and find the CD drive letter and double click it. . . . . if you are a smarty pants like me, then you can go to start>run>command>X:\autorun.exe...........substitute value "X" for your drive letter, you can also type....start>run>command>X:\setup.exe..... for Vista (awwww ewww awful) then you need to go start>all programs>accessories>command prompt> command.com...... then follow the above for other version of windows.
game should start to load, ask you where you want to install it, and then for the password/ product key of the game, which you can find on the back of the manual or on the reverse inside of the CD case.
enter the code then hit ok
When this is done, itll ask you to enter the game disk/ play disk if you dont have to reboot your computer, but i always reboot first anyway.
enter the play disk and run it like you did before with the install disk, unless you are one of the many masses that add shortcuts on your menu and systems to start up your programs/ warez.
if this doesnt work, try cleaning the disk, try installing it to different locations, even get diagnostic tools to check your computer. . . .
definitely try all above before feeding the game disks to the dog.
I hope this is the fixya for you
yours sincerely
Oz
Was this helpful?
Yes
No
1 person thought this was helpful
Popular Solutions for EA - Electronic Arts The Sims?
Questions and Unsolved Problems for EA - Electronic Arts The Sims?
Do you recommend EA - Electronic Arts The Sims? (Deluxe Edition) for Windows?
Answer
Answer
When ever i put the CD in it works but then it gets to 7% and it stops working saying... (More)
Answer
have exactly the same issue and I have installed expansion packs in the correct order as per... (More)
Answer
i've had this sims game for a long time but i've never been able to install it.....it just doesnt... (More)
Answer
when i put in my disk of sims delux edition a pop up comes up saying "files on disk" with... (More)
Describe your problem:
Select a Category:
Ask our Experts
Solve Your Problem Now!
Chat Live with an Expert
Chat Now
Browse popular Problems
More Common Problems
Most Common Problems for:
For EA - Electronic Arts The Sims?...:
Top Computer Game Experts
Rank: Guru Guru
Solutions: 557
Experience: Experienced a lot in computer troubleshooting. Knowledgeable about cellular phones.
Ask Me
Find more Computer Game Experts
Chat Now
X
Continue
When the original poster rates a solution that was given to his own problem, that rating is locked!
X
Are you sure the solution content is Inappropriate?
Tech buddies can communicate directly to answer questions. Become a Tech Buddy and have direct access to your favorite expert for FREE!
Insert Link
Insert Image
Insert You-Tube clip
Insert List
Insert List
Spell Check
What is this?
Select
