Question about GE Profile JB968 Electric Kitchen Range
Oven turns off on its own
I turn the oven on and after a few minutes it shuts down completely by itself.
MicrowaveSvc
  • 9047 Answers
SOURCE: Won't stay on
The turntable problem is probably a failed motor, but that's a secondary problem.
Sadly, we hear of this over and over.
This is usually due to a defective or loose magnetron causing electrical interference and disruption in the control circuit board.
If your magnetron was recently replaced, it may have loose mounting nuts or bolts or maybe the wire mesh RF gasket was not installed or got pinched.
It may also need a new high-voltage diode and stirrer, and the cavity may be affected.
GE had a campaign (but not a recall, mind you!) covering several models.
Details are in their bulletin at http://207.234.249.73/mwd/ge_mw_mag_kit_bulletin.pdf
Even if your model is not on the list, the same problem can occur, requiring a kit. I just think the difference is that GE has stopped paying for the repairs.
The parts kit (that GE used to pay for) is part # WB27X10489 and is shown here: http://207.234.249.73/mwd/wb27x10489_ge_mag_stir_kit.jpg
If you or someone you know decide to look into it, we have critical information on safety, disassembly and door switches at our site, and our link is at our listing here on FixYa: http://tinyurl.com/yzjozk
There should also be a "mini-manual" hidden inside the unit behind the control panel, which is very helpful when troubleshooting.
You can find helpful exploded view diagrams and order parts by entering your full model number here: http://tinyurl.com/gv383
We're happy to help and we appreciate your thoughtful rating of our answer.
Posted on Apr 08, 2008
MicrowaveSvc
  • 9047 Answers
SOURCE: Oven turns off completely
First of all, yes, the charcoal filter should generally be replaced every 6-12 months, or as otherwise specified in your owner's manual.
If the filter clogs, that will block air flow, which is critical to keeping the magnetron cool and safe.
If the magnetron overheats, its thermostat trips, shutting off power to the oven until it cools back to a safe level.
You can remove the filter, then try the oven a couple of times.
If it works right, then you know it's the filter.
If it still fails, then your fan may be out or the magnetron may just be dying.
Also check and be sure your air filters are clean. They can be washed, while the charcoal types cannot.
You can order new filters here.
Posted on Nov 24, 2008
MicrowaveSvc
  • 9047 Answers
SOURCE: GE XL 1800 adora Microwaves shuts down
It sounds like the magnetron is overheating and opening the thermostat.
This can be caused when the internal cooling fan is not running or by a magnetron that is failing.
When I say internal cooling fan, I do not mean the hood vent exhaust fan which you can turn on and off manually.
I'm instead talking about the internal fan which comes on automatically whenever you microwave.
It is vital that the cooling fan runs, or the magnetron will be destroyed.
If you or someone you know decide to look into it, we have critical safety information and disassembly information at our site, and our link is at our listing here on FixYa.
You can usually find helpful exploded view diagrams and order parts by entering your full model number here.
There should also be a "mini-manual" hidden inside the unit behind the control panel or hidden on the left side behind the grille, which is very helpful when troubleshooting & testing.
Posted on Dec 07, 2008
MicrowaveSvc
  • 9047 Answers
SOURCE: JVM1850BH02 Microwave completely shut down, not working after...
The extreme heat has opened up one of the thermostats / thermal cutouts (TCOs) in the oven.
If it was the bottom TCO or magnetron TCO, you should be able to access them by just removing the control panel.
But if it's the one on top of the cavity, the oven will have to come out of the wall, then you need to pull of the outer cover..
If so, the installation instructions are very handy, and it's best to have two people since the microwave can be heavy and awkward.
You can download GE owner's manuals and installation instructions here.
There should be a "mini-manual" (tech sheet) hidden inside the unit behind the control panel or hidden on the left side behind the grille, which is very helpful when troubleshooting, testing, and locating components.
You should locate and look this over first.
At our Web site, we have a video available showing how to remove a typical over the range control panel assembly in under 5 minutes.
Posted on Dec 15, 2008
heatman101
  • 43501 Answers
SOURCE: GE Profile oven (JTP18) won't shut down. It remains ON.
Here is a tip that I wrote that will expalin what has happened there...
http://www.fixya.com/support/r4404788-electric_oven_problem_oven_will_not_shut
heatman101
Posted on Apr 13, 2010
MICROWAVE OVEN
The thermal overload sensor on the Hi voltage transformer is shutting it down to prevent smoke and potential fire. The transformer is getting hot. It needs to be replaced.
Dec 13, 2016 | Microwave Ovens
After running for a few minutes the picture abruptly shuts off and turns back on for a few minutes then shuts off. This cycle repeats itself over and over.
Make sure the top and back of it are not dirty or obstructed, it sounds like it is overheating and shutting down to protect itself. Or your main power board is going out.
Nov 29, 2015 | Sceptre 32 X320BVHD 32 LCD TV
GE Monogram 30" built-in oven turns itself off after a few seconds.
Likely you need a thermal cutoff replaced near where your heating elements are. It senses the fault and shuts down. You can but an after market thermal cutoff from most any electronic parts supply, and maybe even from an appliance parts supply.
Nov 12, 2013 | GE JTP20 Electric Single Oven
Bosch Axxis WTE86300US turns itself off after ten minutes, won't turn back on for a few minutes after that
I would bet you have a bad sensor. There are a couple of sensors that monitor heat. When it gets too hot they shut it down as a safety precaution. Once it is cool enough it will start up again.
Sep 26, 2012 | Bosch Dryers
I have a Magic Chef microwave MCO160UB. I was cooking on the stove (microwave wasn't on) and the fan came on as it has done before. After a few minutes, it shut off and is now completely dead. I...
If the microwave is above the stove, the heat sensors in the microwave
may turn on fans to cool it even though the microwave itself is not
running. It tries to save its life. It should turn off when the stove is not
heating it.
Aug 29, 2011 | Magic Chef MCO160UB Microwave Oven
E machine monitor turns itself off and on
The same thing happened to me today. I was just sitting in my room then i hear a click and the cpu is on it stays on for a while then cuts off. It then cuts on and off with few seconds in between. It then stays in that way cutting and off for about a minite or two and then cuts off completely. A few minutes later it starts again. Also in the time it its off it will not turn on by pressing the power button. Sometimes it completly boots up by itself and then shuts itself down. If I shut it down manually while its on it'll turn itself on immeditaly after. What's going on! Will the warranty cover it? Do I need a new computer?
Feb 01, 2010 | E-Machines eMachines Monitor E15T4
Microwave shuts down after cooking three or four minutes
Your magnetron is overheating and tripping the thermostat, which interrupts power until it cools.
Since it's less than one year old, it should be fully covered under warranty. I'd suggest contacting the manufacturer to get it fixed free.
You can find your nearest Maytag-authorized servicer here.
Nov 20, 2008 | Maytag MMV1153A Microwave Oven
Shut down after 10 minutes
it is reaching the correct temperature and then switches back on when cools a bit?
Jan 11, 2008 | Smeg SE399X/5 Stainless Steel Electric...
Oven shuts off by itself
When your oven reaches the desired temp. it shuts down then turns back on again after it cools down a couple of degrees and cycles like this during the complete baking cycle. If your ignitor or oven valve is getting weak it would cause this symptom.
Oct 31, 2007 | GE JGRP20 Gas Single Oven
GE Profile JB968 Electric Kitchen Range Logo
20 people viewed this question
Top Kitchen Ranges Experts
Dan Webster
Dan Webster
Ismael Rodriguez...
Mike Carew
Are you a Kitchen Range Expert? Answer questions, earn points and help others
