Question about Craftsman Garden
How to level deck on Craftsman model# 917257620 riding mower
  • 6 Answers
SOURCE: how to install mower deck belt on a lt1000 craftsman riding mower
The manual will cover it.
http://www.disruptit.com/manuals/L0104168.pdf
Posted on Apr 06, 2009
  • 6 Answers
SOURCE: Craftsman riding mower loose belts need tighting
http://www.disruptit.com/manuals/L0403195.pdf
Here ya go.
rockitman187
  • 2559 Answers
SOURCE: i need a manual to show me how to adjust the belt
Here is a link to the manual
Please rate this a fixya.
Posted on May 15, 2009
wadembly
  • 489 Answers
SOURCE: Craftsman riding mower blades will not engage
maybe the safty switch under seat might be starting to go out if that switch doesn't work the blades wont come on at all for safety
Posted on Jun 28, 2009
  • 40 Answers
SOURCE: My craftsman 15.5HP kohler riding mower turns over
Try cleaning or better yet, replacing the spark plug. Depending on age and how your tractor was maintained, there are other possible causes.
  • Gummed up fuel system
  • dirty fuel filter
  • defective or misaligned armature/magneto (part that causes your plug to spark, igniting the air/fuel mixture, thus starting the engine)
  • throttle linkage/cable problems
  • low oil level. Some Kohler engines use a low oil shut down sensor which won't allow the engine to run or start to avoid internal damage.
  • Mechanical engine problems
I hope you find this solution helpful. Please rate it thanks for using Fixya!
Posted on Nov 05, 2009
Left side is scalping especially when turning
Stephen Bent/damage blade or spindle, check your deck for support link pin missing, damaged or rusted out brackets, blade spindle loose/mount damages or rusted out, missing deck support spring,wheel/roller if equipped, damaged blades, Recheck tire pressure and front steering axles for bent/damage, etc.
When measuring deck for level, measure at blade tips not the deck on a flat level surface. Check the attached links,instruction and guides, Good luck
"I hope this helped you out, if so let me know by pressing the helpful button. Check out some of my other posts if you need more tips and info."
Lawn Mower Quality of Cuts Problems and Solutions
How to Adjust the Deck Height on Husqvarna
Craftsman Riding Lawn Mower cutting uneven
cutting uneven chopping up ground Craftsman Riding Mower
Jun 06, 2016 | Husqvarna Garden
How do I level deck
Park your mower on a level surface and loosen the bolts that hold the mower deck up on both sides. There are some good YouTube videos that show you how. https://www.youtube.com/watch?v=cQQXtcMzbGA
Feb 11, 2015 | Craftsman 17.5 hp 42 in. Deck Lawn Tractor...
Model # 917257620 need a diagram on how to put the deck belt on!!!
From the lower motor pulley moving back to inbetween the two smaller inside forward pulleys, around the back of the pulleys and out to the front of the larger blade pulleys. Around the blade pulleys to the back and across the back of the deck to the other pulley.
It is easier to visualize it that way, but putting it on start with wrapping it around the blade pulleys and then go to the back side of the smaller idler and tension pulleys and then inbetween them to the motor pulley.
Let me know how it goes, but that should get you going.
Aug 02, 2011 | Craftsman 20 Hp 42" Deck Lawn Tractor
My Craftsman 42" lawn tractor
I would suggest checking your owner's manual. There is a leveling process and my Craftsman wasn't leveled at the factory. Once I leveled mine, it cut fine. If you can't find it in your manual, google leveling craftsman mower deck.
May 14, 2011 | Craftsman 21 Hp 42" Deck, Ys 4500 Lawn...
How do i level the mowing deck on a 38 inch deck
I can provide with a link to instructions for leveling a Craftsman Lawn Tractor 42" deck:
www.searspartsdirect.com
Type in Model # for your tractor (if it is a Craftsman)...if not use the model # for a certain Sears 42" tractor which is: 917.272672
There will be an option on the right side of the page to download (for free) an operators MANUAL and inside that are detailed directions for leveling a riding mower's deck.
Jul 05, 2010 | Garden
20 hp 42 in. Deck Lawn Tractor - CA Model: can you give me a diagram for a craftsman mower de...
i have a 16.5 hp with a 42 deck for some reason one blade cuts alot lower then the other is there a way to adjust thanks
May 17, 2010 | Craftsman 20 hp 42 in. Deck Lawn Tractor -...
Uneven grass cutting
I have seen dull blades, blades not installed right and an un-level deck cause that.
Hope this helps.
Sep 21, 2009 | Craftsman 17.5 hp 42 in. Deck Lawn Tractor...
Its not mowing evenly
You need to level the deck. On most mowers you level the deck from side to side evenly but have the front of the deck 1/4" lower than the back.
Aug 19, 2009 | Craftsman 20 hp 42 in. Deck Lawn Tractor -...
Leveling the deck
You can go to this link and look at page 24 It is the same for almost all mowers.
Please take time to rate this fixya
May 12, 2009 | Craftsman 20 hp 42 in. Deck Lawn Tractor -...
Garden Logo
27 people viewed this question
Top Craftsman Garden Experts
Wade Mobley
Wade Mobley
Dean Gruber
Roland W VanLue
Roland W VanLue
Are you a Craftsman Garden Expert? Answer questions, earn points and help others
