Question about Nespresso Aeroccino Automatic Milk Frother
Froth fizzles Recently the milk froths up just fine, but immediately begins to disintegrate - it just fizzles into liquid. Any ideas?
SOURCE: not making froth
Had the same problem, but called Nespresso. Their tech suggested the following: 1) always leave off the base - will stay on even if button not pressed 2) invert the Aerocinno for 24-48 hours to "reset" the thermostat in the device. I began leaving the base plugged in, but immediately after using and cleaning (don't get ANY water in the bottom of the machine!), I invert the Aeroccino and leave it that way. My machine began making great froth with any tyoe of milk, and continues to do so a month later -
Sounded crazy to me initially, but it works.....Never returned the device, and no need to do so now - Good luck!
Posted on Oct 24, 2008
  • 21 Answers
SOURCE: My Nespresso milk frother did not come with
they make one that has the option of frothing milk hot or cold. Blue light is cold. Red light is hot. The red light will always heat the milk. To get to the blue light, you need to hit the button twice.( First will go to red)
Posted on May 08, 2010
SOURCE: It just stopped making froth.
The milk frother must be extremely clean at it"s base. Hold frother up to the light and carefully examine the base for any type of filmy stuff.
Use a teatowel (dishcloth) or clean rag to polish the base and the problem will be fixed.
Posted on Dec 18, 2010
SOURCE: My Aeroccino doesn't froth the
We had the same problem and it could be that you need new whisks. If you phone Nespresso they will send you out new ones (one of each).
Betteboo
Posted on Feb 21, 2011
SOURCE: the milk doesnt heat up
We had the same problem with burn marks on the bottom and flashing red light etc. Now we just rinse the container out with cold water each time we use it - do not dry, just leave it wet and then add your milk. Heats up perfectly each time. The water lubricates the base of the container, preventing burning. Nice hot coffee every time now. Hope this works for you too!
Posted on Apr 26, 2011
Froth
If you are getting steam out of the wand I suggest you practice and work ha and to learn how to froth up the milk. The machine does not froth up, it is the operator who does. You basically need to keep the wand just below the milk level and keep moving very slowly up and down always trying to stay below the milk level. If the container is wide you may need to swirl as you moving.
Mar 14, 2013 | Saeco Coffee Makers & Espresso Machines
My nespresso machine won't froth the milk
Brand of milk definitely matters... Here in Canada I used Sealtest 1% when I first used it and the froth was thick light and luxurious. Then one week picked up Neilsen 1% and found it produced absolutely ZERO froth. Back to Sealtest...back to froth. Milk brand matters....but don't know why.
Jan 14, 2012 | Nespresso Aeroccino Automatic Milk Frother
Why won't my starbucks serina froth milk. Just stopped doing this all of a sudden. I descaled, the little hole in wand isn't blocked. The milk heats but no froth.
This problem developed on my Sirena machine about a week ago. Stopped frothing milk, but still produced lots of steam. In fact, it was splattering milk everywhere, just not producing foam. Cleaned the steam wand (including air intake) and descaled the machine (even though its only 3 months old) to no avail. Called Saeco customer support (1-800-933-7876) and the very helpful rep immediately identified the problem. Inside the Panarello steam wand is a removable plastic tube. The tip of this tube should protrude about 1/8" beyond the end of the steam wand. Mine was not. Using the eraser end of a pencil, I pushed the inner tube downward into position and, voila, I now have froth again.
Nov 23, 2009 | Saeco Starbucks Sirena Espresso Machine
Aeroccino deosn't make froth
Our aeroccino worked fine for 2 years and suddenly it didn't made foam anymore. We tried the "inverting trick" without much success. We contacted Nespresso and they suggested switching from regular fresh milk (we used 2%) to UHT milk (harder to find in US) and to use it cold and freshly opened. So we tried that and it works.
Hope this solution works for you too
Aug 08, 2009 | Nespresso Aeroccino Automatic Milk Frother
Seaco Odea Go
You can not adjust the amount of this.
/Mirran
Aug 17, 2008 | Saeco Odea Go
Too much froth
Does this happen after you make several froths or the first time you start the machine? Try removing the panarello and froth milk that way then see if this is happening too without the panarello. I found that panarellos are great as a "quick learning to froth?- but they do have the tendency to froth milk too much without heating it up ( to the temperature that you like).
Jun 09, 2008 | Saeco Magic De Luxe Espresso Machine
Gaggia Coffee
Hello, I have been experienceing the same problem since I bought this thing. I used to have the classic Gaggia until it died after 15 years. however, when I went to this one it just didn't function the same.I was having water leaks come from the group assy so I replaced the group valve assy which I saw a diffrence and it functioned properly for a few days, then It was acting up again. No steam to froth and water bypassing the group assy... I then removed the valve assy again and saw it was somewhat clogged of mineral deposits.I cleaned it and after a few days once again it wasn't frothing as it should. Yesterday I completely tore this thing apart but couldn't figure out how to remove the steam valve assy. Does anyone have any ideas?? I removed the 2 screws and it won't move. OH BEFORE I FORGET!!! It was working fine the other day and while I was in the middle of frothing, it suddenly went to half pressure.... ANY IDEAS?? Thank you in advance....
Apr 09, 2007 | Gaggia Coffee In White, White MDF...
Nespresso Aeroccino Automatic Milk Frother Logo
Top Nespresso Coffee Makers & Espresso Machines Experts
Joseph Hoffmann
Kolbrun...
Jay Finke
Jay Finke
Are you a Nespresso Coffee Maker and Espresso Machine Expert? Answer questions, earn points and help others
