Aquacycle rex L151N
I am renting a home in Italy with a washing machine in German. I don't know what the letters on the program dial mean. This is the first machine I have had here with letters.
  • 183 Answers
SOURCE: Zanussi Aquacycle 1200
Pump jammed or filter blocked, check filter if not blocked remove pump and replace if faulty. Regards Advisor
Posted on Aug 30, 2007
  • 209 Answers
SOURCE: zanussi washing machine.
i am a recently retired engineer of 20 years, and i have found that generally the numbers and letters are the same throughout, so the number 2 on one machine is the same as the number 2 on another make, so this rule applies for letters also, just remember what you used on your old machine and you cant go far wrong hope this helps
Posted on Sep 19, 2007
  • 1294 Answers
SOURCE: Zanussi aquacycle 1050 not turning on
First try another gadget, a lamp or something on the wall plug, to see if the point is live. Then check your washer plug, could be that the fuse in the plug has blown, check out your washer wire....
Posted on Jan 06, 2008
barkencoa
  • 3463 Answers
SOURCE: Zanussi Aquacycle 1050. My washing machine seemed to stop spinnin
Locate the filter at the botton front right of washer, behind a drop down cover.
Unscrew anti- clockwise to remove and clean.
If still no go, then you need to check the brushes in the motor.
Hope this helps.
Posted on Dec 31, 2009
SOURCE: zanussi electolux aquacycle 1200 w/mc wont spin
Try new bushes and make sure where bushes run is clean and free from carbon H
Posted on Mar 04, 2010
English language manual
If your machine is a Bosch (which it appears to be from the number) go to this site for a free user manual http://www.bosch-home.co.uk/customer-service/download-instruction-manuals.html
Dec 09, 2013 | Bosch Washing Machines
I have a approx 11 year old GE WBSE2090A0WW, it will (on light wash) automatically fill, agitate, spin, fill again...then stop. It will continue if I manually advance the dial to spin, then it will drain,...
Do you have a check valve in your drain line to the municipal sewer ? It can prevent backups that are quite unpleasant.
Is your laundry room drain properly vented ? (I know mine is not but so far so good.) New homes built by reputable contractors should meet all codes but there are lots of renos done by homeowners who don't know or don't care.
My front loader has a filter that must be manually cleaned from time to time. The main symptom is very slow filling.
Sep 17, 2012 | GE Washing Machines
Dishwasher not working.... when i close the dishwasher and turn it on i can not hear any water running and there is a pool of water at the bottom that will not drain
Hello, How long has your dishwasher been do this? Have you washed dish's in it? Also, these German made dishwasher run on less than 2 1/2 gallons of water. These German manufactured dishwasher machines run really quite. Because of the German water conservancies laws. They limit the amount of water dishwasher and washing machine can use. Also, there is no storage hot water system in there homes, it on demand hot water. You can't hear the motor running and about the only thing one can hear is maybe the water washing the dishes.
Now, the water at the bottom of the dishwasher, if the drain isn't connected up under is the sink drain and trap area or the garbage disposable in the sink. but some place lower on the drain pipe. You will not have a spiffing effect on the the bottom of the dishwasher, it the same with washing machines. One the discharge pump starts sucking air, it will not drain the dishwasher. The siffen effect works if the water is below the outlet for the drain. Example: Home owner have the new washing running and continue fill with water. Why, because the drain pipe end is below the the bottom of the washing machine tub. It fill up with water and siffen action continues emptying the tube will it still filling. One heck of a water bill.
GB...stewbison
Aug 25, 2011 | Bosch 18 in. SRS45E02 / SRS45E08 Exxcel...
Need a free download user manual for a zanussi aquacycle 1200
You will need the model number to get an exact match, but there are 10 different aquacycle 1200 manuals you can download from here:
http://www.manualshark.org/s/zanussi+aquacycle+1200+washing+machine+instruction++manual/
Jun 28, 2011 | Zanussi Washing Machines
Accidently chose german instead of english while setting up my Kodak C195......can't read german so don't know how to correct I want ENGLISH, provide step by step instructions.....newbie here!!!
Ok this may get alittle confusing but here goes. if you remember where the settings button is you can look for one of these words Sprache; Zunge they mean language in german or you can scroll down to Reset Alle Kamera Einstellungen which means Reset settings to default. this should do it
Jun 15, 2011 | Cameras
I need instructions for zanussi aquacycle 1400 XC
My washing machine dials won't light up and strait but the power is switched on
Jul 03, 2009 | Zanussi F1245W Front Load Washer
What numbers do i need to fax to carsoli, italy from south carolina
This should do it:
* first dial the US long distance code 011
* then the country code (Italy-39)
* then the area code
* then the number
For example:
* If the Italian phone number is 0577-555-555, dial the following:
011-39-0577-555-555
*please rate me :)
Mar 15, 2009 | Brother IntelliFax-2820 Laser Fax
Jan 06, 2008 | Zanussi FJS1225W Front Load Washer
Zanussi washing machine.
Sep 19, 2007 | Washing Machines
Washing Machines Logo
75 people viewed this question
Top Washing Machines Experts
Gerry Harvey
Gerry Harvey
