Question about Toshiba D-R2 DVD Recorder
Toshiba d-r2 When ever i turn on power for toshiba d-r2...it says error 7071...and wont let me do anything...it stays frozen with that error
  • 58 Answers
If it's 7071, shut the unit off by holding the power button until the time is displayed (instead of the error code). Unplug the unit. When you open the case, you will see a white plastic piece at the front of the dvd drive near the silver plastic hinge on the face of the unit's dvd opening. The white plastic piece slips in the groove of the hinge to stop the units dvd door from being opened while the drive is engaged. Push the white plastic piece in toward the dvd drive; sometimes the mechanism gets sticky. Plug the unit back in and press the power button. This may solve the problem Hope this helps.
Posted on Aug 06, 2007
SOURCE:
Why wont my toshiba MEU202 MP3 player turn on?
Is unit receiving power? If it is then you have a hassle with the PS.
Jul 31, 2015 | Toshiba Audio Players & Recorders
Want to turn off Auto-restart function of haier split ac
I do not know anything about this but from a manual I have seen its tied in with Timer and Sleep functions there are a lot of instruction manuals ou on the web but you description is to generic you need a model number of which there are a lot.
HSU-09LEK13/R2(DB)
HSU-12LEK13/R2(DB)
HSU-18LEK13/R2(DB)
HSU-24LEK13/R2(DB)
HSU-09LEK03/R2(DB)
HSU-12LEK03/R2(DB)
HSU-12CKAS(R2DB)
HSU-18CKAS(R2DB)
HSU-12HKAG(R2DB)
HSU-18HKAG(R2DB)
Just a sample look for a number on the device which may be under a cover.
As its software controlled they do need to reset themselves as to how long this takes varies from machine to machine.
Hope this helps
Apr 05, 2012 | Heating & Cooling
Fault code ER 7071 on Toshiba HDD drive model
TENGO UN TOSHIBA DVD RECORDER Y EN LA PANTALLA TIENE UN ERROR ER7071, COMO PUEDO ARREGLARLO?
Oct 04, 2009 | Toshiba RD-XS32 DVD Recorder
I was shutting down my toshiba laptop, its now frozen.
If nothing else works remove the battery, leave it for 5 mins then replace it and it will start as normal. Yyou will get an error message usually saying it was not shut down correctly and it may do a system scan but unless there is a real problem with it that will restart it. Ive had to do that twice with mine in the last year.
Jun 15, 2009 | Toshiba Satellite A135-S4427 Notebook
Frozen screen, wont turn off
hit the reset button on the bottom with the power on...it will reset ..
Feb 25, 2009 | Tomtom ONE GPS Receiver
Toshiba satellite x205-s9800 - Frozen boot screen
hi,
try this one
take out the battery and take out the Ac adapter now press and hold the power button for 15 sec this will release any static charge residing in your laptop.
now try start your laptop with battery in.
Further Queries are welcome
Jan 21, 2009 | Toshiba Satellite P205-S6287 Notebook PC
My laptop has been on ''preparing to hibernate'' for hours. frozen
Simply, disconnect the power cord, remove the battery, then hook it back up again. I wouldn't do this though if you unsaved stuff running though.
Nov 13, 2008 | Toshiba Satellite A205-S4617 Notebook
ER7071
es liegt bei diesem fehler an dem dvdlaufwerk
bei mir war es ein loses kabel und eine blokade im dvdlaufwerk
nachdem ich es gesäubert hatte und wieder zud´sammengebaut läuft dvd-recorder ohne probleme
Jul 26, 2008 | Toshiba RDXS54 DVD Recorder/HDD Recorder
Problem with DVD-RW's
I had a very similar problem with my Toshiba D-R2. I found two firmware updates on the Toshiba website. One was called 1314.iso and the other was called 1416.iso. All the instructions are there for how to burn a CD and install it on your DVD recorder. It solved my problems - hope it works for you.
Jul 28, 2007 | Toshiba D-R2 DVD Recorder
Tray won't open
i think this may be the same problem as on the rd85dt where the disk tray wont close, there is a small microswitch under the corner of the dvd flap, the microswitch is broken and simply needs replacing
Jan 15, 2007 | Toshiba D-R2 DVD Recorder
Toshiba D-R2 DVD Recorder Logo
369 people viewed this question
Top Toshiba Televison & Video Experts
Jaime Hernandez
Steve Allison
Steve Allison
Are you a Toshiba Televison and Video Expert? Answer questions, earn points and help others
