Question about Samsung HMX-W200 Waterproof Full HD 1080P Action C... [HMX-W200RN/XAA]
Samsung w200 device will no longer turn on. Screen remains black, even when fully charged. Charging light comes on when plugged into a USB port, but no recognition of the device.
SOURCE: Samsung mp3 player YP-F1 screen diplay won't turn on-even when fully charged
I have samsung yepp YP F1. After full charge, it only appear "loading" and somebody told me to reformat the unit. My question is how do i reformat the unit. thanks - - ronnie
Posted on May 10, 2008
SOURCE: Samsung YP-U3 MP3 Player Problem connection
Found the solution on another site (http://www.everythingusb.com/forums/showthread.php?threadid=11238). To quote user AFHavemann :
"* Plug in the player so the USB bus can see it.
* Once it’s recognized (i.e., the device screen reads "Charging" and "USB Disconnected"), go to the Control Panel and click "System"
* Choose "Hardware" then "Device Manager" tab.
* Look for the name of your device under “Portable Devices” in the list
* If the name of your player is under “MTP Device” then the correct drivers are probably loaded
* Right-click on the name of your device and click "Properties"
* Click “Update Driver”"
Then follow the prompts from there. The computer searches for the driver software, etc., and reinstalls/resets information related to the device, which fixed things such that the computer will now recognize the device. I'm not sure what causes the problem, but this solution seems to reset whatever's gone wrong.
Posted on Nov 17, 2008
SOURCE: my yp-u3 wont connect
no reconoce el dispositivo
Posted on Mar 27, 2009
  • 233 Answers
SOURCE: my mp3 doesnt connect into my usb it just disconnects and starts to charge can you help me
I assume from your description that either you are running a version of Windows older than XP/2000 or you need a special driver. Here is a link for the driver(s) you will need. Just enter your model number and select your version of Windows. Download and run the file and you should be up and running shortly.
Posted on May 30, 2009
  • 400 Answers
SOURCE: my samsung yp-u4mp3 player does not connect with
plz change your USB cable ..one you using is may not be working
Posted on Jun 25, 2009
What ampheres can be used for samsung LN40D550
  • Triple smart USB ports quickly and easily identify yours mobile devices, to provide optimal charging efficiency.
  • Built-in charging circuitry fully protects devices from any short circuiting,over-heating,over-charging,and over-currents.
  • Provides maximum 2.4A charge speed.Three USB ports offers rapidly charging of smartphones,tablets,and other devices.
  • Adopts highlight design with smooth surface, effectively prevent the scratch,to ensure that the beautiful appearance of the product.
  • Strong compatible:Apple and Android Phones and Tablets,Apple iPad Air,iPad 2,iPad 3,iPad Mini,iPhone 6 Plus/6s plus/7/7 plus Samsung/Nexus and More,HTC,Samsung,Motorola Android Phones and External Battery.
AmanStino Car Charger Quick Charger USB 3 0 3 Port with Smart Sense IC...
Feb 25, 2015 | Samsung LN40D550 LCD TV
My Samsung s5 is not charging
try this
SAMSUNG GALAXY S5 - NO POWER, BATTERY, CHARGING AND CHARGER ISSUES alltabshighlighted.jpg
No power, battery, charging and charger issues
This guide contains troubleshooting steps and advice to help resolve issues you may experience when attempting to charge the handset.
After performing each step, please test to see if the issue is resolved.
Symptoms:
  • Battery not charging
  • Battery is not lasting long
  • Phone won't charge
  • Charging error
  • Failure to charge
  • Display remains black or blank
  • No power
  • Boot failure
  • Overheating
Troubleshooting Questions
  • Are you using the correct equipment?Make sure you are using an approved Samsung wall charger and USB charging cable. Other brands of charging accessories may have different voltage parameters and could cause charging issues when used with Samsung devices.
  • Have you charged your phone for longer than 30min? Leave your phone plugged in to the charger for about 30min without powering on. In some cases, it may take slightly longer for your phone to charge.
  • Is the battery icon displayed on the screen when charging? After charging your phone for a little while you should get a battery charging icon appear on the screen which will indicate that your battery is charging properly.
    If the charging icon appears, leave your phone for a little longer before you try to switch your phone on.
    If however, the screen is blank and nothing is displayed, follow the below troubleshooting steps.
  • Is the charging cable plugged into a USB port? Some charging cables can disconnect from the wall outlet adapter and plug directly into a USB port. However, when plugged into a USB port, the charging process is much slower due to the limited power output of USB ports. Instead, plug the device directly into a wall outlet to speed up the charging process.
  • Is the outlet faulty? Try a different outlet or check for a switch connected to the outlet. If possible, try powering a different device on the same outlet.
  • Does another USB cable, or wall charger work? Charging issues can occur if either the battery or charging cable is damaged. Verify that the charging contacts are clean. If necessary, clean the contacts using a cotton swab and rubbing on isopropyl alcohol.
    If possible, test the charging cable by plugging it into another device and seeing if the device charges. Alternatively, try charging the device with a different cable. This may mean changing out the cable or the adapter on two-piece chargers.
    If charging through a car charging kit, ensure that the car engine is running, and if possible try to charge other devices using other cables, through the same car kit. If none will charge, then it is likely there is a fault with the car charging kit. It is recommended to continue to cross-test devices, cables, and car kits until the problem device can be identified.
    If the device charges when using a different USB cable or wall charger, the issue most likely lies with the charging accessory. In this case, follow the approved charger repair / replacement process.
    Also, if the charger is connected via an extension or other multi-socket adapter, remove this and plug the charger directly into the wall-mounted socket. This will eliminate the possibility of a fault with the adapter.
    If you are still unable to charge your device, continue to the next step.
  • Has the phone experienced any shock or exposure to water? Accidental physical shock to a handset can sometimes cause problems to arise with battery or charger, as these components contain delicate parts, particularly. Damage can occur either to the component itself, or to the component's connection to the motherboard.
    Water exposure can also lead to damage of these components, however due to the slow way in which this type of damage can manifest itself, the cause may not always be readily obvious.
    With any physical damage of this nature, the only recourse is to contact the device manufacturer, and follow their approved repair or replacement process.
^_^
Jul 04, 2014 | Samsung Galaxy Cell Phones
Charging my juke with a usb cord
Fully charge the battery to maximize playing time. However, it is not necessary to fully charge or completely discharge the battery each time. You can charge the battery by connecting the jukebox either to the AC power adapter (fastest) or to a USB port on the computer. The battery icon in the upper right corner of the screen indicates the remaining battery charge.
  1. Connect the USB combo cable to the AC power adapter, and then plug the power adapter into an AC power outlet. Or, you can connect the USB combo cable to a USB port on the computer.
  2. Plug the combo cable into the jukebox. Make sure that the top of the plug (the side with the arrows) is facing the same direction as the front of the jukebox.
    View Picture
  3. If you are charging your jukebox from the computer's USB cable, turn your jukebox off. If your jukebox is on, it cannot charge from the computer's USB cable. Note: If you are charging your jukebox from the AC power adapter, you can leave your jukebox on as it charges, but it will take longer to charge.
  4. If the jukebox is on, the power cord icon appears in the upper right corner of the display. The keypad's backlight turns on while the battery charges, and then turns off when the battery is fully charged.
  5. When your jukebox battery is finished charging, pinch the two side buttons on the plug, and then pull the plug out of the jukebox.
Feb 25, 2012 | Samsung SCH-U470 Juke Cellular Phone
Sro 8120 transonic mp3 keeps cutting out like its going flat when its charging a red light comes on sometimes flashes and the device will only play for a few minutes
Taken from the Quickstart User Manual
LED Light 1 (L1) - is by the earphone socket
LED Light 2 (L2) - is by the USB connector
Charging: Please switch on the player before charging. (Push the on/off switch to 'on' )
When charging the battery for the first time it is recommended that the player is charged about 8 hours. Connect the player to an active USB port using the supplied cable. The computer must remain on during the charging process.
Recharging: Recharge the player will take about 3 to 4 hours. When it's charging, L2 will turn on in red, when it's fully charged, L2 will turn to green light.
When playing music, L1 will shine.
Sep 01, 2011 | Audio Players & Recorders
My sky caddie sg5 wont charge
If you follow these instructions which I think you know how to, it will recharge. If not the rechargeable battery needs to be replaced
To charge the battery, simply follow the steps below:
  1. Gently pull back the rubber cover to gain access to the mini-USB port located at the bottom of the SkyCaddie. Insert the mini-USB connector of the supplied wall charger into the mini-USB slot.
  2. Plug the wall charger into the AC wall outlet. While charging, the charging indicator in the upper left-hand side of the SkyCaddie will show red. The charging indicator will switch to green when fully charged. You may also notice the unit's screen turn on and off periodically.
The battery will charge, even with the SkyCaddie turned off. A full battery charge may take 4 hours. Once fully charged, expect 36 holes of continuous play.
Warning!Always connect the cable to the SkyCaddie first before connecting to AC power or PC USB.
Jul 16, 2011 | GPS
How will be i identify it is fully charged battery i charged for 45 minites.But the battery will not be fully charged. please send me the solution for this problems
If using usb charger use usb port on back of desktop, not data port in front, also most laptops do not have fully powered usb ports due to battery consumption. The wall charger, or a usb charger plugged into a usb/ac adapter (like included with ipods and kindles or sold seperately) is your best bet for reliable charge.
Charging unit should have a light on it.
When charger is plugged into power source and not helicopter, the light will show you {#1} what it looks like when battery is fully charged. Typically this is steady on, and usually red. (sometimes green) When you connect helicopter to charger, the light will change (usually goes dark) to signify it is charging {#2}. When light comes on fully (or completely returns to #1) then charging is done. (Note: charging using a laptop usb or a front side data port usb can take several hours.) Watch the light on charging unit when you unplug helicopter, if it gets brighter, helicopter is not charged, plug it back in. Make sure to let battery cool for 10 minutes after every charge and 10 minutes after every flight, and never run battery all the way down. As soon as you can't maintain altitude, land and power off. Fully draining a Li/Po battery weakens it's ability to hold a charge and can ruin it.
If all else fails, replacement batteries are available from Amazon and many others, they are cheap (around 5$) and very easy to install with no soldering and just a small screwdriver.
Hope this helps
r
Dec 31, 2010 | SYMA Toys industrial Syma S032 Ready to...
Charging
USB Cable Make sure that the USB cable is properly plugged in and use the original cable that came with your player. Try a USB plug o the back of the computer. These plugs have more power available.
Computer in Hibernation mode Make sure the computer isn't entering hibernation or sleep mode while the device is connected. The computer must be ON in order to charge your player. Check you screensaver and power settings.
USB Port 2.0 Make sure the player is connected to a USB 2.0 port (1.1 occasionally causes charging problems).
Battery Make sure the battery is fully charged. It takes approximately 3 hours to fully charge the battery.
Latest firmware Depending on what Sansa player you have, make sure it's up to date with the latest firmware.
AC charger (optional) AC chargers (sold separately) have a 500-1000 milliamp max output, which provides much better charging ability than a USB port. These accessories are available on our online store.
Next try and reset the player. Resetting the player: 1. Slide and hold the Power switch up for approximately 20 seconds. 2. Release the Power switch. 3. To turn the player on, slide the Power switch up then release instantly.
Once it is back working, go to the SanDisk support site and get the updater program and update your firmware.
Jul 15, 2010 | SanDisk Sansa View 8GB MP3 Player - Black
Garmin Nuvi 255W
No, it may take a little longer if you are charging through the USB port. I normally have mine plugged in while driving, it charges and is in use too. To use GPS with USB. First turn the GPS on (without USB plugged in). Press Battery symbol on screen for about 10 seconds, a test screen will come on. Plug in the USB (bottom of screen shows USB connected). Tap EXIT to return to maps. You can now use it while USB is charging Make sure you turn GPS off before removing the USB cable
Apr 08, 2009 | Garmin nuvi 255W GPS Receiver
Stupid blackberry
This is an issue with your device and the charging port it needs to be seen at a repair center.
Mar 14, 2009 | RIM BlackBerry 7250
LG Secret charging
Dr Know, doesn't know what he's talking about. I have a LG KF750 and have experienced the same problem.
Solution - Really jam the cable into the socket! The connection is pretty rubbish. The phone charging icon will (with some force and wiggling) appear on screen. Then carefully put it down and don't touch it!
USB charges very slowly, if charging from a dead flat battery it may take a good 20mins of charging to boot up.
P.S. the red camera light is not supposed to come on when charging. Keep wiggling the cable and the light will go off when the phone charging icon appears.
Dec 16, 2008 | LG Secret ? KF750 Cellular Phone
Samsung HMX-W200 Waterproof Full HD 1080P Action C... [HMX-W200RN/XAA] Logo
21 people viewed this question
Top Samsung Cameras Experts
Kazim ERGUNEY
Kazim ERGUNEY
Are you a Samsung Camera Expert? Answer questions, earn points and help others
