Question about Vision Fitness T9250 Deluxe Folding Treadmill
T9250 vision fitness treadmill E7 speed error
Treadmill shows E7 speed error on led screen and doesnot respond to any operation
2 Suggested Answers
ercupa190
  • 12223 Answers
SOURCE: I have a vision fitness treadmill T9250 and now the console display isn't working properly. Some of the
Dear Sir:
Please see the diagram attached from REED switch, adjust, clean, and tight the connector wires very well.
2) change the batteries by new ones, use the best.clean the contact batteries.
3) tight the ribbon cable from keypad .+ tight the connector from display board vs lower board.
4) after you fix it RUN THE sofware calibration for diagnose, troubleshooting, See my personal tips for help
sincerely. God bless you
Posted on May 03, 2012
I have a bh fitness treadmill model number G6414v and its got an e-02 and e-07 error on screen . What do I do
I don't know what this has to do with washing machines???
On your BH F1 treadmill here are their listed errors.
E1
Possible cable fault.
Connect the wire well between top
controller and bottom controller
E2
Burst clash.
Operating with incorrect voltage; Connect
the motor wire again.
E3
No speed sensor signal
Replace the sensor light on the bottom
controller or speed sensor.
E5
Possible motor overload.
Lubricate the belt.
E7
Safety key.
Insert the safety key.
Here is the manual, page 12 is the troubleshooting and error codes in English.
http://www.bhfitness.hu/shop_ordered/69670/pic/english-manual/G6414U_Monitor_manual_v2-3226.pdf
Jul 26, 2016 | Exercise & Fitness
My Vision Fitness T9250 treadmill. Can hear a low noise when no one is on it but gets much louder when anyone is on it and operating...any ideas where to start looking for repairs?
Try to open and separate the motor carefully from treadmill chasis, turn the motor shaft with hand if it not easily turn or you hear a unsual sound try to open the motor and add a lubricant to motor bearing, and turn the motor on if its still noise replace all the bearings with new one
Dec 14, 2014 | Vision Fitness T9250 Simple Folding...
E4 coming up on my screen display , what is this and how do I fix it so it will work again ....
What device are you talking about your stereo ATV a computer or a cell phone?
Most manufacturers have a support site on the Internet and given the error code and the model number they'll give you a solution
Nov 25, 2014 | Vision Fitness T9250 Deluxe Folding...
Getting E2 error on my vision fitness t9250 treadmill
68a1477a-4453-48c8-9f94-cd15c6c6fea7.giffollow this steps and fix it. God bless you
This is probably a faulty speed sensor or the speed sensor is not plugged in properly. Its also possibly a faulty motor control board or lower board. The error codes will differ between makes and models but could be e1.
See the diagram attached.
Oct 13, 2013 | Exercise & Fitness
My vision treadmill T9800HRT when start shows speed stall and error 7
please see the 2 alternatives for error 7.God bless you
E7- 1) Alternative Elevation Motor
1)Cause: Elevation Motor not moving Solution:Check Elevation Motor connection
2)Cause: Elevation Elevation Motor screw binding Solution: Clean screw and lubricate
3)Cause: Elevation Motor Motor out of Range Solution: Check motor out of elevation
4)Cause: E-Motor Potentiometer: Solution: Replace Elevation Motor
2)Alternative:
Display Doesn't Light Up: a)Cause: On/Off switch Solution: Test unit is turned on b)Cause: Insufficient Power Source Solution: Plug dedicated120V, 20Amp Outlet
c) Cause: Line Cord Damaged Solution: Replace Line Cord
d)Cause: Fuse Solution: Check Fuse on MCB
Sep 20, 2013 | Vision Fitness 2011 Vision T9800 Hrt...
My vision treadmill T9800 HRT when start shows speed stall and error 7
please see the 2 alternatives for error 7. God bless you
2)Alternative:
Dear Sir:
Apr 30, 2012 | Vision Fitness T9250 Deluxe Folding...
I turned on my treadmill after a long hiatus :) and got an error message and a beep. The errors were E4, E9 and a few others. It is a Vision Fitness T9400HRT model. Any idea how to fix?
E4: Solution 1. Check power to the treadmill, as insufficient voltage to the treadmill can cause this error to reoccur. Check the power socket that the tread is plugged into. Eliminate any extension cords or surge protectors (plug the tread directly into a functional power source). Make sure the circuit is not overloaded. Make sure the circuit is NON-GFI. 2. Calibrate (See engineering mode for specific treadmill). 3. If calibrations do not hold, replace upper console. Note: Usually simultaneous with an E6. E6: Solution 1. Check the elevation plug connection at the lower board. 2. Check ALL large data cable connection at the lower and upper boards. 3. Calibrate (See engineering mode for specific treadmill) 4. Test/change large data cable (use large data cable information provided in the data cable portion of this Guide). 5. Replace elevation motor E7/E9: Solution 1. Certain lower boards have an LED that flashes when the magnet on the roller passes the sensor. Adjust sensor position if LED does not flash. See lower board basic troubleshooting for lower boards with the LED. 2. Unplug RPM sensor at the lower board. Check continuity. Treadmill will operate without sensor but cannot Autocalibrate. Calibrate manually. 3. Replace RPM sensor TREADMILL.TROUBLESHOOTING. AUTO CALIBRATION STEP 1 ENTER ENGINEERING MODE • With the SAFETY KEY in place, hold the “ELEVATION UP” and “SPEED DOWN” buttons for 5 seconds. “DGA3” will appear in the profile window and “EHG1” will appear in the function window. • You are now in ENGINEERING MODE STEP 2 ENTER AUTO CALIBRATIONS • Press the “ELEVATION UP” or “SPEED UP” to “EHG4”. • Press “SELECT”. STEP 3 • Press “START”. The treadmill will calibrate itself. This will take about 3 to 5 minutes. When AUTO is complete, “END” will appear in the window. Wait 10 to 15 seconds and the treadmill will reset itself to “P1”. STEP 4 • Press “START” to test the treadmill
May 04, 2010 | Exercise & Fitness
Vision Fitness T9250 Deluxe Folding Treadmill Logo
54 people viewed this question
Top Vision Fitness Exercise & Fitness Experts
Andrew Taylor
Andrew Taylor
rattack1511
Level 1 Expert
ray gallant
Are you a Vision Fitness Exercise and Fitnes Expert? Answer questions, earn points and help others
