Question about Garden
Makita dcs400 my dcs400 just will not start up
  • 7,482 Answers
Hi andy
Make sure you are getting spark at the spark plug, to do this:
Remove your spark plug and check to be sure you are getting a bright blue spark at the spark plug.
You do this by grounding the plug on the head of the engine and pulling the crank rope...watching the plug for spark.
If you are getting a nice blue spark then skip A below and go to B.
A...If you do not get a nice blue spark then you may need to replace the electronic module.
Note: If you have to replace the module be sure to measure the position it is in and be sure to install it in the same position
Normally the clearance is around .10 thousandsands
Also write the measurement down on a piece of paper for later reference, this measurement is critical to starting of the engine later.
B...Also take some fine grit sandpaper (not emery) and lightly sand the flywheel where the magnet is located to clean any rust or corrosion from the magnet area.
You can also try to lightly sand the module metal face to increase the possibility of ignition of the old module before replacement.
Sounds like you have dirt/debris in your caburetor jets,fuel passages or a diaphgram that is becoming non-flexible.
Check/Clean/Replace your Air Filter, a dirty air filter can make your engine run to rich with fuel.
Also be sure to check and clean your spark arrestor in the exaust,if you have one installed on your engine.
Note: ALWAYS USE COMPRESSED AIR TO CLEAN YOUR JETS AND PASSAGES, VERY IMPORTANT.
Note:Before you disassemble the carburetor:
Write down on a piece of paper or take a picture of how the linkage attaches to your carburetor for later reference when you go to reinstall your carburetor.
Mark each piece with a awl, or some kind of instrument that will make an alignment scratch before you disassemble the carburetor into separate pieces.
That way you will know which way it goes back together when you reassemble it.
Sometimes you can get by with priming the carburetor or by using a very small shot of starting fluid and letting it run a few times like that, and it will flush the gunk out of the jets,but most of the time you will need to rebuild the carburetor.
Be sure to check your fuel tank for water and dirt/debris, if there is water/debris then you need to clean your tank.
Check you fuel line condition after a while they will degrade and need replacment.
Check/Clean/Replace your fuel filter if you have one, normally they are located in the fuel tank of chainsaws and weedeaters.
When you remove your fuel lines from the carburetor be sure to make a drawing to how the lines are connected to the carburetor or take a pictue for later reference.
Normally the big line will be the line the fuel filter is connected to inside of the tank.The smaller of the two lines is the return to the fuel tank from the carburetor after it is pumped thru the carburetor by the primer bulb.
Make sure you are using fresh fuel...and oil if your using a two cycle chainsaw or weedeater with the oil to the right mixture...too much oil as it can cause hard starting and excessive smoking.
If the chainsaw/trimmer is over a couple of years old, then I recommend that you buy and install a new carburetor repair kit,because the diaphragm will get hard and that will cause it to be hard to crank.
The diaphgram may look good and flexible, but it can be deceiving and not act as a fuel pump as it should because it has become too hard and will cause hard starting,start and run and shut off, etc.
When you clean your carburetor, I recommend that you use a laquer thinner type cleaner to clean and dissolve the laquer build-up in the float and needle jet passages.
Be sure to remove all plastic and rubber parts before using the laquer thinner because it can dissolve the plastic parts and render them unuseable.
Be sure to use COMPRESSED AIR to blow out all the fuel and air passages.The higher air pressure is needed to blow some of the trash/debris from the fuel or air passages.
Be careful when blowing out the passages, because there are sometimes small rubber type seats in the bottom of some of the passages.
Keep in mind that the float (if you have one) for the carburetor must be level when you go to reassemble the carburetor or follow the instructions you get with the carburetor kit, or you could also ask the parts man that you get your kit from.
When you clean your carburetor and remove the jet screws, you will first need to lightly seat the jet screws.
But before you lightly seat the jet screws count the number of turns it takes to seat the jet screws from their original position.
Be sure to mark the turns down on a piece of paper.
That way when you put the jets back in, you know to lightly seat them first and then turn them back out to their original position before you started.
Note:
The little spring inside of the carburetor goes under the float arm.
That is where your fuel inlet needle/float valve is located...on the arm at the end.
Normally there is a small indention in the carburetor base and a small protrusion on the underneath of the float arm where the spring will be in the right postion for installation.
The spring will set in the indention and you will install the float arm with the needle/float valve and float rod into position over top of the spring,you will push down until it is in position and then you can tighten the screw that holds the float arm assembly in position.
Once you have your carburetor cleaned/rebuilt that should solve your problem.
Please take time to rate me
Bud
Posted on Apr 27, 2013
Hi. I have a makita 08070 hammer. when I will start this the power light is work but machine not work
Australia Drill Battery offers a complete and comprehensive product line of high quality MAKITA power tool batteries. Our MAKITA drill batteries are designed to be fully compatible with the original cordless tools. http://www.drill-battery.com.au/batteryshop.php/makita_power-tool-battery.html
May 09, 2017 | Makita Drills
Can i bypass the switch on a makita skill saw
OMG, absolutely NOT!
I know a guy without 3 fingers due to one of those on a construction site. He said he never felt a thing.
Buy a new switch.
  • Makita Canada Inc. www.makita.ca Makita Canada: The best in class for cordless power tool technology. A leader in power tool technology for the professional.
  • Makita Saw Parts ' Great Selection ' Great Prices ... www.ereplacementparts.com/makita-saw-parts-c-97_98.html Fix your Makita Saw today with parts, diagrams, accessories and repair advice from eReplacement Parts! Worldwide shipping, no hassle returns.
  • images of makita saw parts bing.com/images th?id=oip.m79ac54922c7af758ce5909fe9cde9163o0&w=87&h=105&c=7&rs=1&qlt=90&pid=3.1&rm=2th?id=oip.m8226e4e7540d1403e6b34f0609fee8ado0&w=87&h=105&c=7&rs=1&qlt=90&pid=3.1&rm=2th?id=oip.mc9c1b6c779ab4de644cda35842865ffbo0&w=87&h=105&c=7&rs=1&qlt=90&pid=3.1&rm=2th?id=oip.mfb5ac75b7411568957f4d7028521f0b4o0&w=80&h=105&c=7&rs=1&qlt=90&pid=3.1&rm=2th?id=oip.mdd935730eb9fe8614bf23952794b8ca9o0&w=87&h=105&c=7&rs=1&qlt=90&pid=3.1&rm=2th?id=oip.md1140885e7ec8b5124cabfe71fdb3085o0&w=87&h=105&c=7&rs=1&qlt=90&pid=3.1&rm=2 See more images of makita saw parts
  • Makita Power Tool Parts - Makita Parts - eReplacementParts www.ereplacementparts.com/makita-parts-c-97.html We have the genuine Makita parts and tool repair help you need to get your power tools running like new again.
  • Makita Parts - Tool Replacement Parts ' Tool Parts Direct www.toolpartsdirect.com > Brands Makita Tool Parts - Shop Makita parts online at Tool Parts Direct. Over 38,000 Makita replacement parts and schematics available.
  • Related searches for makita saw parts
  • Makita Tool Parts :: Makita Saws - Tool Parts Canada ... www.toolpartscanada.com/makita-tool-parts/makita-saws-page-3.html Please choose your tool from Makita Benchtop line below view parts breakdown
  • Makita Saw Parts ' Sears PartsDirect www.searspartsdirect.com > All Brands > Makita Parts Shop the best selection of Makita saws repair parts and accessories at Sears PartsDirect. Find replacement parts for any Makita saws repair project.
  • Makita - Authorized Factory Service Centers www.makitatools.com/en-us/Modules/Service/ServiceCenters.aspx Makita Authorized Service Centers meet our high-quality ... Genuine quality Makita replacement parts; Most tools repaired within 3 days; Maximum Repair Cost Program;
  • Makita Saw Parts ' eBay 9k= www.ebay.com/bhp/makita-saw-parts Find great deals on eBay for Makita Saw Parts in Corded Circular Saws. Shop with confidence.
  • PARTS - Makita UK https://www.makitauk.com/shop/parts Parts . Ask Makita ' Find a dealer. Part search Search for tool drawing: Filter: 1 - 2 - 3 - 4 ... Contact Makita! 01908 211678. Monday - Friday 8am to 5:30pm.
  • Makita Tool Parts - Tool Parts Canada - Parts that makes ... www.toolpartscanada.com/makita-tool-parts.html Please Choose Makita category Below Which Matches Your Tool
  • Jun 20, 2016 | Makita Saws
    My makita dbc4010 petrol strimmer was working then not used for 3 months now it wont start,plus now theres no spark
    Parts: http://www.ereplacementparts.com/makita-dbc4010-brush-clearing-saw-parts-c-97_16558_10177.html?gclid=CKyA0JLti80CFQetaQodzw0DaQ Use fresh gas and oil, 2 stroke 40:1. Clean/replace air filter and spark plug.
    Sep 25, 2015 | Makita Garden
    Volvo v40gdi sometimes won't start but starts fine from cold when trying to start it chokes and struggles if I remove air filter assembly it starts fine,
    To troubleshoot the issue, click the link below:
    Car Repair Diagram
    http://technoanswers.blogspot.com/2013/03/car-repair-diagram.html
    HOT/WARM START ISSUE
    Its a hot start issue.
    Can be related to low fuel pressure or problem with crank sensor.
    Also it can be weak battery or starter.
    But possibilities are to be inspected to confirm what exactly it is.------
    To troubleshoot and confirm the issue,i suggest you refer few solved help links with similar types of problem like yours:------
    Click the link below:------
    1991 Toyota Trecel: Engine Starts fine but dies when gets Warm?
    http://whatisbyme.blogspot.in/2012/05/1991-toyota-trecel-engine-starts-fine.html
    1994 Toyota Pickup: Starts fine but dies in few seconds?
    http://howtobyme.blogspot.in/2012/05/1994-toyota-pickup-starts-fine-but-dies.html
    1995 Lexus LS400: Running Hot?
    http://whatisbyme.blogspot.in/2012/05/1995-lexus-ls400-running-hot.html
    2002 Toyota Camry: Puff of Blue or White Smoke while Starting?
    http://whatisbyme.blogspot.in/2012/05/2002-toyota-camry-puff-of-blue-or-white.html
    Multiple problems on car: Car runs hot, A/C blows hot and car starts surging?
    http://schematicsdiagram.blogspot.in/2012/04/multiple-problems-on-car-car-runs-hotac.html
    Delay starting on Toyota Prius?
    http://schematicsdiagram.blogspot.in/2012/02/delay-starting-on-toyota-prius.html
    Honda car will not start intermittently?
    http://technoanswers.blogspot.in/2012/02/honda-car-will-not-start-intermittently.html
    Vehicle Starts, Runs and Loses Power
    http://whoisbyme.blogspot.in/2012/07/vehicle-startsruns-and-loses-power.html
    Intermittent starting issues on Volvo 760?
    http://schematicsdiagram.blogspot.in/2012/02/intermittent-starting-issues-on-volvo.html
    Car starts and cuts off immediately?
    http://repairhelpcenter.blogspot.com/2012/01/car-starts-and-cuts-off-immediately.html
    Car won't start when cold?
    http://schematicsdiagram.blogspot.com/2011/12/car-wont-start-when-cold.html
    These details will help.
    Thanks.
    Mar 14, 2013 | Cars & Trucks
    Garden Logo
    93 people viewed this question
    Top Garden Experts
    Dennis Key
    Dennis Key
    roeb
    john h
