Question about Stoves FARM1100DF Dual Fuel (Electric and Gas) Kitchen Range
Oven Electric Oven switches itself on and off warming to a low temperature and I can't stop it. It has a five button programmer with (L - R) bell, warm pan, crossed out pan, minus and plus symbols. All other functions seem OK. Can you help me stop this please ?
  • 1462 Answers
SOURCE: Fan oven stays warm
is the fan working when oven is staying warm? possible fault if you don't have an earth trip is a short to earth on the neutral side of the element
Posted on Mar 26, 2007
  • 183 Answers
SOURCE: The cooker stays warm when mains cooker switch is on.
Either teh grill element or the oven heating element is fault or the thermostat or grill regulator, locate which element is warm, if the grill then it is most likely the regulator, if it is the oven it is the thermostat. Engineer
Posted on Jul 28, 2007
  • 7 Answers
SOURCE: Oven cuts out after about 15 minutes
most common fault is the cooling fan is failing to come on, whreas the fan will be okay ( check windings with ohmn meter ) it will normally have a ceramic 10k resitor in series with the live which goes open circiut
Posted on Jan 07, 2008
  • 3 Answers
SOURCE: can not control oven temperature
sounds like thermostat issue, unless it has been like it since you took ownership of it or someone worked on it just prior to the fault then it could be due to a short between the switched live and permanent live which would result in the thermostat not controlling temperature, this short can also appear through wear as the contacts in the thermostat may have stuck as mine wouldn't get hot i shorted the permanent live and the switched live the element got hot so i looked at the thermostat and the gap had got too big and the contacts wouldn't close i adjusted the gap and the oven now works for how long i don't know but i wouldn't recommend fixing yourself in this way unless you know what you were doing and just have it replaced
Posted on Mar 27, 2010
BarrettDenCo
  • 1772 Answers
SOURCE: I have a model 33 electric oven and the oven
wew
ewe
Hello,Sorry to read about your problem
Their is a 80% chance you heat element is defective. and 10% your control knob is defective
I have tried to help you. Please help me by vote/rate the response. Thanks If you live in the Denver Area. I can help you out.
4 Thumbs - Very Helpful
3 Thumbs - Helpful
2 Thumbs - Somewhat Helpful
1 Thumb - Not Helpful
Posted on Dec 26, 2010
Oven Switching Off
I have a few questions. Does the oven reach the set temperature? How do you get it to go back on? and if you do not set the time do you have the same problem?
Dec 06, 2007 | Electrolux EOB6632 Electric Single Oven
How do i fix the timer for delayed start
Strangely in all of this, u don't tell the oven when to start - it works it out itself!
First u need to set the length of cooking time, eg 2hrs.
Press the cooktime button(2nd one along), THEN use the +/- buttons to set the display to 2.00.
THEN press the readytime button (3rd one), and use the +/- buttons to set the end time.eg 1730hrs
The display should then revert to the present time.
THEN turn the oven control to the required temperature.
The oven will switch on at 1530 hrs.
If u were to press the cooktime button ONCE WHILST the oven was on - it will display the cooktime remaining.
AT 1730, the oven will switch off and the alarm will sound
To switch off the alarm, press the minuteminder button - first one - looks like a bell, THEN
REMEMBER to cancel the programme by pressing buttons 2 and 3 TOGETHER, otherwise it will do it again tomorrow!
HOPE THIS HELPS
I would suggest first.trying it when you're at home all the time the oven is on.
Sep 08, 2014 | Belling XOU592 / XOU593 Electric Double...
I have a Belling 335 everything still works apart from the actual oven part? What could this be and is it fixable??
check your timer,if it has a programm set(by accident)the oven will not work until this has been cleared,if your not to sure then switch cooker off at the cookers main switch on the wall.leave for a few mins and switch back on this should clear any set programm,good luck.
Nov 13, 2012 | Belling 335 Electric Kitchen Range
My kenmore W&R locked to start the cleaning process and never turned on, but now won't open. It's been 4 hours.
Verify that the Whirlpool oven is connected to its power source. The oven may sometimes lock down if experiencing a power surge or similar electrical problems. Additionally, check that a fuse hasn't been blown in your home's fuse box. Some older homes may not have the proper wiring to support a high-powered appliance such as a Whirlpool oven. If you are not sure if your wiring is sufficient, consult a local electrician.
  • Check to see if the Whirlpool oven's Control Lock has been turned on, a safety mechanism designed to lock the oven and disable its keypad and display controls. A padlock symbol will be displayed in the corner of the Whirlpool oven's front display panel if it is locked. The oven will not unlock itself on its own even if it is disconnected from its power source. To disable, press and hold the "3" button on the keypad for five seconds until the padlock icon disappears.
  • See if the Whirlpool oven is engaged in its self-cleaning cycle. During the self-cleaning process, the stove will lock its front door and will flash "OVEN LOCKED" on its front display. This is to prevent users from accidentally opening the oven and burning themselves during the high-heat segment in the cleaning process. If you must open the oven, first stop the process by pressing and holding the "OFF/CANCEL" button on the stove's control panel. If the oven remains locked, wait for the internal temperatures to decrease. The locking mechanism is temperature controlled and will not unlock until internal temperatures have cooled.
  • Contact Whirlpool's service department if your Whirlpool oven remains locked and you cannot troubleshoot it or open it. All Whirlpool self-cleaning ovens are covered for five years after the original purchase date. Call the warranty team for assistance by dialing toll-free (800) 253-1301 in the United States, or (800) 807-6777 in Canada. Be prepared to give the oven's model number and purchase date
  • Dec 11, 2011 | Kenmore 33464 / 33465 / 33469 Gas Single...
    Bottom oven only heats to a low temperature
    If your electric oven is taking too long to heat or just not heating up right,then check out this tip that will give more detail about your problem.
    Oven Problems Electric Oven is Heating Slowly or Poorly
    heatman101
    Jan 03, 2011 | Belling XOU592 / XOU593 Electric Double...
    I have lost my manual for a Simpson Appolo Atlas Stove
    call manufactuerer and ask if you can order one or try to do so online
    Dec 22, 2009 | Stoves EC500DOA Electric Kitchen Range
    Belling XOU 252 Oven suddenly stopped working
    Yes ,I would say that without doubt the element has gone
    Elements can go without any warning at all.
    Dec 13, 2008 | Belling XOU252 Electric Single Oven
    Stoves FARM1100DF Dual Fuel (Electric and Gas) Kitchen Range Logo
    19 people viewed this question
    Top Stoves Kitchen Ranges Experts
    Paul Carew
    Oloyede Monsuru
    Tony Houde
    Tony Houde
    Are you a Stoves Kitchen Range Expert? Answer questions, earn points and help others
