Well the starter won't cause the rough running or stalling problems.
You would need to know if the starter has full battery power when it will not crank without being jumped off another battery.
It could be that the battery voltage drops low enough to affect the computer memory, and after the engine starts the computer has to re-learn the settings.
SOURCE: rough idle stalls at low rpm's
hello first check your idle with the car running foot on brake see were your rpm reading is if your below 500rpm check your label underhood for your curb idle setting second see if theres a adjustment screw you can increase were your gas cable lever rest against your set screw underhood if you feel confident enough remove your iac motor idle air control valve if the bore were the end of the pintle extracts out to close has varnish builup our carbon it will stick creating vacuum leak type senario causing stalling rough idle sometimes even no start conditions good luck
SOURCE: 1991 honda accord - runs rough and stalls on start up.
Did you set the ignition timing after you installed the dist.? If yes, I'd say you got a bad distributor(the one you just put in) since all the codes you're getting are directly for sensors located within the distributor.
SOURCE: Car dies while driving, now it won't start sometimes
Could be a fuel pump that is going bad. Some times when fuel pumps go bad they cavitate and pump not just gas but also air. If you get too much air in the line and not enough gas the car won't start. Have a mechanic check your fuel line pressure.
SOURCE: 2003 honda accord starter may be going out at
Hi
Replace the copper contacts inside the starter motor, it connects the current to the rotor once the bendix drive gear is engaged with the ring gear.
Regards
Phillip
SOURCE: My 2000 Honda Odyssey EX has intermittent start problems
Probably when the dealer is testing it is fine because the problem is intermittent. There may be a dead spot in the starter so when it hits that spot it acts up but other times its not on that spot its fine. Replace your starter and you will probably get rid of the problem.
