Question about Canon PowerShot A540 Digital Camera
Fill flash How do you activate it?
    One Above All:
    The expert with highest point at the last day of the past 12 weeks.
    Top Expert:
  • Canon Master
  • 102,366 Answers
Press cursor-up (marked with a lightning bolt) to cycle through the various flash modes. For fill flash, select the lightning bolt without the letter "A" to force the flash to fire. See page 8 of the Basic Camera User Guide http://gdlp01.c-wss.com/gds/2/0900001192/01/PSA540_530CUGba-EN.pdf
Posted on Apr 26, 2013
How can i use flash in s6100 camerah
Isn't that a Nikon camera? Nikon Coolpix S6100?
It has a built-in flash, you can activate it using the information provided in the camera manual. Nikon COOLPIX S6100
You can use it as primary source of ligth when shooting indoors or doing night portraits. You can also use it as a fill light. Read the manual.
Oct 15, 2014 | Canon Cameras
Light flashes 7 times then pauses and blinks 7 times again, and keeps repeating
Temperature problem with water. Incoming water when filled should be no less then 1/2 inch below heater. If not, possible water valve. Incoming water temp. min after fill. 120 degrees. Missaligned door. One of door switches not activating. Bad circulation motor. Not throwing water over heater. Tech.sheet behind bottom panel. Will tell you. Shorted heater. When bottom panel is removed. Look for signs of water leaks. Hard water deposits on floor.
Mar 28, 2011 | Kenmore 24 in. 17032 Built-in Dishwasher
Hello, the flash don't work with the shutter in all mode P A ... and the image are under exposed : there is no flash light on the photo. Thanks for your help, José , in FRANCE
My experience with these power shots is the flash capacitor unit witch draws current from the battery, Fills up then activates the flash is what your primary issue is.
654137e.jpg its ether that or the flash bulb itself without further look I would not be able to pinpoint it. If you value this camera you might want to take it to a camera shop.
please do be considerate and leave ratings or feedback before you leave, Thanks
Oct 15, 2010 | Canon PowerShot A630 Digital Camera
Front load machine getting F 02 flashing on screen machine has stopped working??? Help
That code means the aquastop has activated. This means that you have a leak on the machine which is filling the tray underneath with water and stopping the machine from working. Probably a job for an engineer.
Jun 07, 2009 | Whirlpool Washing Machines
Hotpoint FDW60 flashing eco light
if the eco light is flashing, this indicates that saftey float switch has activated in the base of the dishwasher usually caused by a leak, a polystyrene float activates a microswitch which cuts of the water inlet supply
Mar 28, 2009 | Hotpoint 24 in. FDW60 Free-standing...
ALO1 flashing. Its as if the dishwasher is draining all the time. Won't reset even when turned off at the wall. Debbie
AL01 is activated when the dishwasher develops a leak and the internal water tray has filled with water. This activates the pump to drain water from the dishwasher. The tray needs emptying manually however and the source of the leak needs to be traced. Probably best to get an engineer in to do that.
Feb 28, 2009 | Hotpoint 24 in. FDW60 Free-standing...
Only works on 30 degrees
If it is a hot and cold fill m/c.then make sure that you have water present at both valves.
Nov 28, 2008 | Bosch Axxis WFL 2060 Front Load Washer
Dishlex dishwasher global 300. Dishwasher continues to drain with ECO light flashing. Service manual says it is due to an incorrect fill level or fill line.
Some diswashers have a sump in the bottom with a float switch. If the water level overflows the float will activate the switch which will kill the machine and run the drain pump continuously.
Jul 01, 2008 | Dishwashers
Eco button keeps flashing, cycle not starting
If its a dishlex global then flood switch is activated.soak water up from flood pan middle front underneath.then it will restart.but you will probably find its leaking or over filling.hope this helps.
Mar 07, 2008 | Dishwashers
Hotpoint few12, machine not filling
the timer, electronic or mechanical is not advancing to the fill contact. if mechanical the cam contact may be burnt. if electronic the gated triac [solid state relay] is burned up [replace]
Sep 05, 2007 | Hotpoint First Edition FEW12 Front Load...
Canon PowerShot A540 Digital Camera Logo
146 people viewed this question
Top Canon Cameras Experts
TC CAMERA REPAIR.Com...
old marine
old marine
Are you a Canon Camera Expert? Answer questions, earn points and help others
