Question about Garden
Bolens bl110 I recently purchases a Bolens weedeater and used it yesterday for the first time. Today, when I began using it, I found that the speed of the weedeater head comes to a stop when attempting to cut down the weeds. Is there a solution to this?
mickey813
  • 472 Answers
SOURCE: bolens 13am662f163 wont move.
sounds like the varabel speed pulley is locked up ck that
Posted on Oct 15, 2009
SOURCE: The cutting head on my
The clutch is fouled with assembly grease. Separate the boom from the powerhead, then use a T20 screwdriver insert into the clutch drum. Remove spark plug and insert a small length of rope to hold piston, now remove screw in clutch hub. Slide off clutch hub and clean with soap and water. If excessive grease is on end of boom drive shaft remove the excess but leave a little. the rubber clutch shoe works by stretching with faster engine rpms.
Posted on Sep 13, 2010
woobie dog
  • 1273 Answers
SOURCE: how to remove the head
It should pull straight off.
--W/D--
Posted on Jan 25, 2011
vincob
  • 718 Answers
SOURCE: need assistance on how to
Go to smalleng.com or check out U tube..
Posted on Apr 19, 2011
SOURCE: how to replace line on
Help
Posted on Apr 26, 2011
The head on my Bolens BL110 weed eater is slipping
Check the drive shaft. Within the drive tube there is a tightly sprung drive shaft, check where this connects to the head of the cutting attachment, it could have a worn drive.
http://www.ereplacementparts.com/mtd-bl110-41ad110g965-trimmer-parts-c-20039_20040_143532.html
Apr 10, 2016 | Garden
Bolens bl110 weedeater runs until I try to cut
Adjust carb. Initial adjustment is 1 full turn out on both low and high side. If it still fall on it's face, turn the low side out and additional 1/4 turn.
Sep 24, 2014 | Garden
Show me how to adjust the carburetor on a bolens bl110
Bolens trimmer sputters and stalls and only runs on half choke? Here's how to fix it.
Look on the top of the carburetor and you will see 2 black screws that are mostly round with a flat side recessed in the aluminum housing. They are flat on top and have no notches to insert a screwdriver. The trick is to turn these two screws 1/4 turn counterclockwise. I have a set of precision pliers and used the fine tipped needle nose to turn them.
The other option is to try and notch the top of them enough so you can use a flat blade screwdriver. You can grind down the surrounding aluminum with a Dremel tool so you can access them better.
You can see in the picture that I scratched across the top of the screws as a reference to see how far I was turning them.
Jun 28, 2014 | Makita DCS51018 18" 45cc Chain Saw 2 Cycle
I have a Bolens BL110 starts fine but dose'nt rev at all
Mar 17, 2013 | Garden
I have a Bolens BL110 Trimmer - it starts just fine, but won't rev up completely. Suggesstions?
Could be blocked spark arrestor or carboned up in the exhaust port.
May 06, 2012 | Garden
My pull string came out and will not retract on my Bolens BL110 2 cycle gas trimmer. How do I fix this?
the coiled rewind spring ends are bent back in a hook. the hook usually breaks so springdoes not wind up. some times you can re bend but steel is very brittle and keeks breaking and must be replaced
Jul 17, 2010 | Mtd Garden
Garden Logo
Top Garden Experts
Dennis Key
Dennis Key
john h
