Question about Whirlpool Washing Machines
WHIRLPOOL AWOE 9120 F36 fault code??
WHIRLPOOL AWOE 9120 Fault code F26 keeps coming up would appreciate some indication what this could relate to please. Thanks in advance
MakikiChris
  • 84 Answers
SOURCE: Indesit washer/dryer widl 126s
Hi gmarf....to reset your machine to cancel those symptoms, Unplug your machine from the Wall Outlet for a minimum of 1 minute. Upon restoring power, it should be reset and ready-to-go.....If you have any further questions or issues please update your post....good luck my friend
Posted on Aug 12, 2007
the dr
  • 447 Answers
SOURCE: Whirlpool washer Cabrio WTW6600SB1
Its the Rotor Position Sensor very easy solution!!!chat with me online and ill step you through it save up to $65 (my in-home rate in florida is $75!!!!!!!)
Posted on Sep 27, 2007
bigg t
  • 640 Answers
SOURCE: Whirlpool oven fault f03 shown
f03 error is a sensor error.you could have taken an ohm reading on the thermistor to see if it was bad.if you replaces the t-mistor then the only other component responsible is the board.make sure all the connections on the board are clean and tight before you replace it.
Posted on Sep 29, 2007
SOURCE: fault code
E90 indicates a communications error between the user interface board (control panel) and the main circuit board. If you take the top off the machine (power off first!), then stand in front of it and look at the front left you'll see the main board and a blue multi-stranded cable coming out of it and going into the control panel. 99 times out 100 this is the culprit, if there's a poor connection at either end then this generates E90. You need to remove the control panel (screws behind soap drawer and plastic clips along the top), disconnect the blue cable, give the connector a bit of a squeeze with your pliers to tighten the connection, do the same to the other end on the main board, refit everything and away you go....hope this helps...yes I used to work for them
Posted on Jan 06, 2008
jsrock516
  • 5911 Answers
SOURCE: Fault code C1
"C1" is known as an Instantaneous Current Limit Error. This will occur when the Motor Controller detects a current spike of 26 amps or greater at the motor windings. Overloading the washer, excessive water and/or excessive suds can cause this problem.
The manufacturer recommends the following:
- Wash smaller loads and use the correct detergent (HE only for Calypso machines). NOTE: Make sure the HE detergent is not double or triple concentrated as this will also cause suds problems.
- Check for objects under the nunate plate. This is the wash plate. Sometimes clothing can get stuck under the plate and cause the motor to bind up. To remove the nunate plate, follow these instructions:
1. UNPLUG THE WASHER.
2. Open the washer top. Look along the front seam of the washer where the top meets the front. There are a couple of retaining clips (about 2" in from each side) that you will need to push in on with a putty knife while gently lifting up on the top to get the top to release. Carefully open the top and lay it back against the wall in a resting position. Make sure you support the lid so it doesn't fall open when you tilt the top back.
3. Remove the tub ring. This is the plastic donut shaped ring that sits on top of the wash tub. There will be a tab on either side of the outer tub near the back that you can use a screwdriver to release the tub ring. The ring is filled with fluid and is used to balance the tub. So, if you hear liquid sloshing around, this is normal.
4. Remove the center cone from the wash plate. Use a flat blade screwdriver and insert it into any of the slots available along the sides. Gently pry until it pops off. I say "gently", but you may have to use a little muscle to get it to come off. Sometimes they stick. Once the center cone is removed there will be a series of nuts under it.
5. Remove the nuts and the wash plate should lift out. Be careful not to damage the gasket under it. Clothing can get tangled in the leveler under the wash plate. This leveler should have a key on it. The wash plate will only go back in with this key mating to a slot on it. So, remember how you took it off. In addition, when putting the wash plate back on, make sure you tighten the nuts in a cross pattern and evenly tighten them as you go. This will ensure the gasket seats properly. Don't forget to put the tub ring back in.
- Check for objects stuck between the inner wash tub and the outer basket. NOTE: It is best to do this with the nunate plate removed. Use a flashlight to peer through the holes in the wash basket to see if anything is catching on the tub.
- Check the Motor Controller. You will need to determine if there is power getting the the board first and that the fuse on the board is good. If any components on the board are defective, the board has to be replaced. If you have power to the board and the fuse checks good, check for continuity between the Machine Controller and Motor Controller.
There is a tech sheet inside your washer along the interior cabinet (usually the front panel) that explains all these procedures to you. I would advise you to research the tech sheet for exact locations of the pin outs for the circuit boards. Its easier for you to view it rather than me explain it. If you need further assistance, please post back and let me know. I hope this helps you.
Posted on Jul 03, 2008
My whirlpool awo/d 5556 washer displays error code f:26 can you help please?
F26 Drain pump triac failure This error code is displayed when the main electronic controller fails to detect the triac that controls the outlet drain pump during the wash cycle.
  • Check pressure switch contacts and connectors
  • Failure of the pressure switch or level sensor can also give rise to this fault code
  • Run test program
  • If failure persists after test and verification of pressure switch, replace main controller
The above information was take from UKWhitegoods web site
http://www.ukwhitegoods.co.uk/help/fault-codes/220-laundry-fault-codes?type=rss&limitstart=0
Feb 09, 2017 | Whirlpool Washing Machines
How do I get washing machine door to unlock?
The error F26 does indicate a fault in the door switch circuit. See the image below for a complete listing of what can cause this error. There is a door unlock error that would display if the door is not locking or unlocking but the F26 means the control is not seeing the door switch open and close. One thing to try first before scheduling service or replacing the part is to check the connections on the door switch.
Unplug the washer first and remove the lower access panel and reach up to the door lock and try to feel for the connections and make sure they're tight.
Jun 16, 2014 | Whirlpool duet Washing Machines
Whirlpool 3LCHW9100WQ Semi-Professional 9kg Washing Machine
Possible fault with the door switch or the control panel but you can try to open and close the door few times to reset after removing power.
click this link: error code F26
Oct 03, 2013 | Washing Machines
Site fault
Jose,
Can you please be more descriptive with the fault. Is there a fault code number?
If you need UPS, Surge, or Power Related help don't hesitate to contact me!
Daniel • daniel@psihq.com • Power & Systems Innovations • 800.260.2259 • www.psihq.com
Aug 19, 2013 | Powerware 9120 UPS System
Whirlpool AWOE 9559 S, programme dial problem, no power activation on the first 3 programmes or their opposites on the dial, no error code or fault light indicated. I this a dial fault or is it someth
Sounds like you may have dry joints on the circuit board, you will need to contact washing machine repairs, not something you can fix yourself
Jan 02, 2013 | Washing Machines
Error code F26
This error code indicates that the door needs to be opened and closed.
The F26 code may appear the first time you try to use the washer. Open and close the door to clear the display.
The F26 code may also appear if the washer has run three cycles without the door being opened. Open and close the door to clear the display.
If opening and closing the door does not remove the error display, press Pause/Cancel twice
Oct 22, 2011 | Whirlpool WFW9200S Front Load Washer
Fault code f26
If opening and closing the door does not remove the error display, press Pause/Off or Pause/Cancel twice.
If Pause/Off or Pause/Cancel does not work:
  1. Unplug the washer or disconnect the power for one minute.
  2. Plug in the washer or reconnect the power.
  3. Re-select the cycle and press Start.
Jul 30, 2011 | Maytag Washing Machines
Whirlpool dishwasher Fault codes
Fault code related to Flow meter. Cleaned the connections and reconnected.It worked fine for 2 weeks and failed again.Replaced the water chamber which contains the flow meter and the issue is resolved. The water chamber cost me 87euro including postage from Quinnspares in Co.Derry Ireland.
Nov 24, 2008 | Whirlpool Dishwashers
F 26 Code that won't go away
The F26 error code on the Duet washer is a door switch error. The button inside the door opening might be stuck so that it doesn't register as being opened and closed. First press the pause/cancel button to clear the error display. Next push the button inside the door opening a few times and pull it so that it pops out completely. That should solve the problem.
Dec 29, 2007 | Whirlpool Duet GHW9150P Front Load Washer
Washing Machines Logo
55 people viewed this question
Dan Webster
Dan Webster
Sal DeAngelo
