Question about Philips ProScreen 4600 Impact Multimedia Projector
Color alignment is off
Hi. My projector displays a 1/2 inch blue line down the right hand side, and a 1/2 inch yellow down the left. The color alignment seems to be off for the whole display. I have taken it somewhat apart, but is this an easy fix? Anyone know where I can get an internal diagram?
  • 1 more comment
  • Anonymous Apr 22, 2008
    I have the same problem but, I have an 1/2 inch blue line to the left and 1/2 inch yellow line to the right
  • ladamscmt77 Jan 05, 2009
    Same problem here...do you know of anyone that can fix this? would a local shop be able to adjust the board?
  • Anonymous Jan 09, 2009
    Got the same problem,
    A red hollow on the right, does any one has found an issue ?
I also have the exact same problem. i picked up 3 of these used for my work and kept one at home. I knew one had issues and another had a burned out bulb and so on. I had a repair place to combine the two to make one good one. The repair man said that they had a real hard time keeping the color locked in alignment. It's not a physical alignment, its controlled by the board output and somehow the board can be adjusted. It was vague to me. After about a good couple of years of hard use the one at home is now doing the same. On one hand I want to fix it but I dont even have a plasma so I may go and spend $800-$1000 on a hi def DLP. At that price it won't be the best but it will rock this projector. that would be my advice rather than putting more money into this old model.
Posted on Sep 05, 2008
SOURCE:
Yellow line down one side of mp 8749 projector
the LCD panels is defective
replace it with a new one
Have a good day!
We supply original projector parts: lamp, bulb, Lcd panel, Lens, DMD chip,color wheel,
motherboard, powersupply ... with high quality and competitive price.
Jerry China Lampdeng Limited
Tel: +86 131788 67858
E-mail: [email protected]
Skype: lampdeng.com
http://www.lampdeng.com
Feb 27, 2014 | 3M MP 8749 Multimedia Projector
Image is bright but there is a slight issue - on the left hand side a purple line displays vertically. Anybody knows why is this fault appeared and how could it be solved.
There is three LCD in the projector red, green and blue. If green LCD make any fault mean line or dot or dots then screen show these line or dot in purple color:
If line is very straight and sharp edges then green LCD is faulty and need to be replaced.
If line is not straight and faded edges then some thing in LCD block so your projector need service
Feb 22, 2011 | Sony VPL PX40 Multimedia Projector
What are the color codes for a factory stereo system in a 2006 Nissan alttima
use at your own risk. I can not confirm these.
+12V DC Battery(Constant) Yellow/green 31 15 Amp Fuse box on left front of engine compartment, near battery. Switched Accessory Purple 6 10 Amp Fuse block behind left side of dash Power Antenna NCA Green for antenna signal Illumination Red/yellow & red/blue Steering Wheel Control Wire Red/white, green, and blue If equipped, as for Mid-Line. Left Front + Blue/white Left Front - Blue/red Right Front + White/black Right Front - Blue/black Left Rear + Green/yellow Left Rear - Black/yellow Right Rear + Blue Right Rear - Red
titleicon.gif AT SPEAKERS
Wire Function Color Note Left Front Tweeter + Blue/white Left Front Tweeter - Blue/red Right Front Tweeter + White/black Right Front Tweeter - Blue/black
Feb 20, 2011 | 2006 Nissan Altima
Toshiba TP50H15
You can adjust the lines and make them straight. You can also in the same process, make them line up.
1. With the TV on, press the mute button the remote control so that you have picture but no sound.
2. With remote in one hand (holding it as far from the TV as you can but still be able to reach the TV with your other hand), press and hold the mute button again, with the other hand, using the control panel underneath the screen, press the menu button on the TV set.
You will notice an "S" on the screen on the right hand side about 2/3 from the left, halfway up the screen (If you did this right).
This means you are in service mode.
With the remote, curse right only once and you will have some information displayed in the upper left. The top line is Item, the one underneath is Data.
Press "7." This will display the built in cross hatch pattern. You can move the line around with the directional circle located at the center of the remote. Using the "3" button, you can decide which color to move. To move the curser to a new location, The number pad doubles as a direction key pad. (2-up), (4-left), (6-right), (8-down). To simplify the process, you can eliminate the red or blue or green lines and only focus on one color at a time. "0" will shut on/off the green line. "100 button" will shut on/off the red line. "CH RTN or Enter will shut on/off the blue line.
"7" will exit the process as well as get you there.
Power off when you are done and turn back on.
Repeat as needed.
Jul 05, 2008 | Toshiba 50HX81 50" Rear Projection...
Align cartriges message continuously displayed
Here's the deal with the cartridge alignment page....the machine will spit out a series of black lines mixed with yellow ink and at the beginning of each of these lines is a "Green" check mark. The carriage moves back and forth over these lines and green check marks and reads them by use of what is called a "spot sensor" that resides on the right side of the carriage assembly. This is usually noticed by the blue ray of light that shines out of it. So if you are getting an alignment failure one of two things is happening....1)You've have got a bad cartridge (usually the color) and it is not laying down the right colors, specifically the green check mark or 2)You've got a bad spot sensor...even though it may still be shining the blue light, the sensor board can't process the information. Its an easy fix either way.
Inkworks
May 25, 2008 | HP OfficeJet 6110 All-In-One InkJet...
LP690 projector displaying strange lines
to adjust those mirrors, you need to power down, unplug, remove the top, remove the wires from the main board, remove the main board, adjust one mirror, reinstall everything, power up, see whatever difference it made, power down and repeat until it's fixed. it's quite a chore. if that's not the problem, you'll need to replace the optical engine (which isn't cheap) because they don't sell individual parts.
Mar 09, 2008 | InFocus LP690 Projector, Factory...
Center adjust on Red gun is not aligning with B&G vert.
frist set blue and green than set red itwill shoew yu single chakall will be focous in single line than than gun will be allign horizontal if it will correct if itisnot comming than cathode problem.
Oct 06, 2007 | Sony VPH D50HTU Multimedia Projector
Projectors display
the lcds areout of alignment. you'll need to send it in to a service center to have them do it. you can try yourself, but you may need special tools.
Jan 04, 2007 | Boxlight SP 5t Multimedia Projector
MT830 Color Convergence (Blue Left - Yellow Right)
take a look here: http://www.extremetech.com/article2/0,1697,1049289,00.asp "... The others, however, have lost portions or all of their blue channels. TI's theory is that the shorter wavelength and higher energy of the blue light apparently causes the organic polarizing material in the LCD to get lightburn much faster. TI showed us a damaged LCD panel that controlled blue light transmission, and there was a large spot in the center that was apparently burned out..."
Aug 25, 2006 | NEC MultiSync MT830 Multimedia Projector
Philips ProScreen 4600 Impact Multimedia Projector Logo
765 people viewed this question
Top Philips Office Equipment & Supplies Experts
jasbo
jasbo
Ekse
Damen Wong
Damen Wong
Are you a Philips Office Equipment and Supply Expert? Answer questions, earn points and help others
