Question about Music
Kustom Signal Pro 1000DS radar - Music
I have a Kustom KPM8420 PA mixer and the monitor channel comes through both the monitor and main speakers and vice versa. The two channels are not separate.How do I fix that?
On the back panel there is a section labelled Patch Bay
There are 2 small switches which assign each Power Amp to either Monitor or Main Output.
It would seem you have them both set the same at present. Set one to Monitor and one to Main, and use the corresponding Power Amp outputs direct to speakers.
Note you can send signal to external amps or powered speakers from the preamp outputs. This is really handy.
Download and print the manual from https://www.manualslib.com/manual/90516/Kustom-Kpm-8420t.html
and keep it with the mixer.
( Of course don't send speaker outputs to other amps or powered speakers )
Sep 11, 2017 | Kustom Music
Hello. Where is the fuse located to be replaced in my Kustom KPM4060 Amp. Thanks Shawn.
I have the same problem with my KPM 4080 amp. I have no clue where the fuse goes. I'm sure mine also needs a fuse replaced.
Mar 11, 2015 | Kustom Music
Kustom KPM8420T schematic
Where can I find a schematic for a Kustom KPM8420T?
Jul 07, 2013 | Music
Hi! I need two input/output plates for my Kustom floor monitors (KSC10ML). By input/output plate, I mean the unit that has the volume knob plus the two input/ output jacks that is screwed ino the side...
The KSC10ML has NO volume control... only two 1/4 inch jacks. To get a matching "jack cup" you will probably have to go to Kustom. I have searched for the item on the web and only jack cups that seem to come up are for Marshall or ones that use binding posts. I found one blank one but it is 5 by 7 inches... too big for that Kustom cabinet. In a pinch if you don't need it to be recessed, cut metal or ABS plastic plates and drill for two jacks.
Apr 16, 2011 | Kustom KSC10ML PA Monitor
I have my first ever electric guitar with a kustom dart 10 amp. I understand that the amp has to be plugged in to the mains through a power cord, but the kustom dart 10 brings none. Is this normal.?
No, there is a cord. OFTEN the cord is buried in cavities in the plastic foam or in cavities in cardboard like spacers in the original box. For some small amps the cord is permanently attached and is coiled up in cavity behind the speaker.
Jan 06, 2011 | Kustom Dart10FXA 10W Guitar Combo...
I NEED THE SCHEMATICS FOR A KUSTOM AMPLIFIER MODEL 4-15C SO WE CAN REPAIR IT, THANK YOU
Here is a link that might help:http://www.vintagekustom.com/FUDforum2/index.php?t=i&cat=2&rid=0&S=c04218e7e0f8ac8bb52d5b4ecde8a9d3 Also try here:http://www.stereomanuals.com/man/rep/kustom/index.htm Scroll down and be advised you will have to pay for it but at least it will be legible. This forum may or may not be of assistance:http://music-electronics-forum.com/t19128/ You might try here:http://www.kustom.com/MessageCenterDetail.aspx?ContentID=1325 Someone there might know someone who has one.
Nov 08, 2010 | Epiphone Blues Custom 30watt 2x12 Combo...
Music Logo
29 people viewed this question
Top Music Experts
Michial Gueffroy
Vito Vacirca Jr.
Are you a Music Expert? Answer questions, earn points and help others
