E-Machine 4115c Will not boot. power light comes on, however the A light and the 1 light comes on. If I switch off and on again and again eventually after quite a while it boots
  • 7,627 Answers
Try unplugging, remove battery, plug in, reboot, and run a System File Checker using this procedure: http://support.microsoft.com/kb/929833 AND, test the HDD use this procedure: http://windows.microsoft.com/en-us/windows-vista/check-your-hard-disk-for-errors If this is a recent event do a System Restore to a date before this issue. Or a Factory Restore. Have you cleaned the fan, vents, and heatsink lately? Has there been ANY damage? Drop? Post results
Posted on Apr 27, 2013
freetek
  • 5568 Answers
SOURCE: laptop boots then shuts automatically off
If you haven't tried it yet, pull the battery out and try booting from the adaptor only. If it boots normally, then your battery pack may be bad (shorted cell) or the regulator that has the job of charging and monitoring the battery pack while keeping your system running may not be healthy.
If you own any multimeter (at the cost of Chinese DMMs, everyone should own one), check the battery pack for charge. Under normal conditions, they should measure a couple of percent higher than their rating. You will have either Lithium Ion or Nickle metal hydride batteries in the pack so should measure some multiple of the nominal cell voltage of one of those types that are respectively 3.6 & 1.2 volts.
Posted on Nov 28, 2008
  • 38 Answers
SOURCE: Sony Vaio VGN-N250E/W Not Booting/Responding
Take the battery and power supply out and hold down the power button for 30 seconds. This will reset your hardware settings. Your backup battery isnt your problem. Does your battery light turn on when charging? Does your keyboard lights light up when it runs for a second (try pressing caps lock)?
Posted on Mar 25, 2009
  • 1170 Answers
SOURCE: Qosmio G35-AV600 boot problems
You will have to reinstall both its BIOS and operating system, only that can properly solve the problem. I my solution was helpful, Kindly accept it.
Thank You, Arjun
Posted on Apr 01, 2009
  • 11 Answers
SOURCE: HP Laptop DV2415NR Need to power on twice to boot.
log in your bois and make sure first boot option is hard drive. not cd/usb or anything else. unless you need to
Posted on May 24, 2009
joecoolvette
  • 5660 Answers
SOURCE: Laptop won't boot up
1 suggestion.
Inside your laptop is a processor. The Cooling Fan, and Air Intake Duct you mentioned, are part of the cooling system. The main job for the cooling system, is to keep the processor at a reasonable operating temperature.
When a processor becomes too hot it turns off. (Actually BIOS turns it off)
With the amount of foreign debris you mentioned, (Dust/Dirt/Hair/Carpet Deodorizer/Food Crumbs/Lint, are a few examples of foreign debris), the Cooling Tube may be clogged.
Just using a can of compressed air for computers, in the Air Intake Duct, (DO NOT blow into the Exhaust Duct!), may not be enough.
Generally the Cooling Tube is about the width of your finger, and the height is half the thickness of a finger. Pretty small tube, and easily clogged. Also the Heatsink at the end of the cooling tube, can become clogged.
Laptops have a poor cooling design anyway. Everything is crammed into one tiny box. They use a small fan to cool them, and the Air Intake Duct is typically located on the bottom. (Some are on the side) This is a good (?) area to inhale readily available foreign debris.
On the link below the last photo on the page, shows an average Cooling Tube that is attached to a Heatsink.
http://www.insidemylaptop.com/clean-cooling-module-acer-aspire-3620/
This requires opening the laptop, and physically removing the foreign debris. Typical method is a combination of Q-tips, and Isopropyl Alcohol, plus a can of compressed air.
(AC adapter {Charger} removed, battery removed. Use an ESD wrist strap, and connect it's alligator clip to a good ground)
By the way. You DID have the AC adapter, (Charger), disconnected, and battery out, when you used the can of compressed air, right?
Posted on Jul 25, 2009
Dell E6400 won't boot up (most of the time)
Computer does not boot up
The problem maybe the RAM, it could be faulty or just needs reseating to make proper electrical contact.
Reseat the RAM and then boot up your laptop. If it still does not boot up then remove the RAM module/s and take them to your friendly computer repair shop and get them to test the RAM for you.
Just like you sometimes need a mechanic to repair your car, sometimes you do need a technician to diagnose and identify the fault or faults on your computer. Not only does a good service technican have the experience to deal with this type of problem, they also have the equipment that allows them to look at things the average computer user can't see, and he has a collection of replacement parts that can be used to quickly test individual components on your computer.
May 11, 2013 | Dell Latitude E6400 Laptop
I have a WC5225. When I switch on the machine the interrupt light keeps on blinking and the machine does not boot.
Try this: 1. Turn machine off 2. After it has completely powered down, unplug the power cord from the wall. 3. Go back to the front of the machine and turn it on and then back off again (remembering to leave it UNPLUGGED from power.) 4. WAIT 60 SECONDS (Very important) 5. AFTER 60 seconds plug it back into the wall and turn it back on.
If problem persists call for service.
Hope it helps!
Apr 30, 2011 | Xerox WorkCentre 52255230 Copier
I have a Fujitsu-siemens lifebook E-7010 laptop. The screen is not lighting up when i switch on the machine. The laptop hums normaly. the green light comes on, but the screen is not lighting up. Please...
You will remove the battery and unplug the dc adapter.After complete those hold down the power switch for 30 seconds.
Now install the battery and plug the dc adapter to laptop again and hold down the power button.I Nhope your problem will solve.
Dec 24, 2010 | Computers & Internet
Aspire one won't turn on, on switch illuminated but no display on the screen. battery light on but no other lights.
1.Remove ,the battery and adopter from your machine.
2.And then press the power button form 36 Second.
3.And then refix your battery and adopter to your machine.
4.boot your system
5.if you will get the same problem again means suspected issue with main board.
Nov 16, 2010 | Acer Aspire One AOA150-1570 Notebook PC
Had trouble booting the computer over time. Sometimes power light would come on and nothing else. By unplugging, waiting 15sec it would power up. Over time this stopped working. Eventually power light...
Time to look for a new computer. That and take out your hard drive to copy your files over.
Sounds like motherboard problem. Probably not worth repair.
I've got an HP desktop with similar problems. It turned on one day just fine. The next day not. I don't even get the boot up screens. Disconnecting Hard Drive and CD/DVD components do not help. I should at least get some BIOS POST beeps and a Hard Drive Not Found or such. I do not. On occassion it will boot to a blank screen with white cursor in upper left. Most the time no screen at all. On rare occassion it comes right on and boots Windows. I guess it could be the power switch ... but I doubt that.
Nov 22, 2009 | E-Machines eMachines Desktop PC
Ei system 4115c appears to boot up but no display on screen
This happened to me, give the pc 5 minutes, then:
Type your User name, then
Press tab and type the Computer description, press enter and wait 5 secs then press enter again. Wait for the computer to load windows for the 1st time and display will appear. Not sure why it did this. FYI pressing enter the 2nd time made there be NO password for this user logon so you'll have to go through control panel to assign one if desired.
Regards Zeth
Sep 29, 2009 | Dell Inspiron 9400 Notebook
Malfunction detected, please call Tech Rep. C3451
Here's the reset procedure.
1. Turn OFF the Main Power Switch.
2. Turn Main Power Switch ON again while pressing the Utility/Counter key more than
10 seconds after.
3. Touch [Trouble Reset].
4. Check to make sure that [OK] is displayed and the it has been reset.
5. Turn off the Main Power Switch and turn it on again more than 10 seconds after, and
make sure that the machine properly starts.
And yes, a power outage could cause this.
Jun 22, 2009 | Konica Minolta bizhub 350 All-In-One Laser...
Thank You, Arjun
Apr 01, 2009 | Toshiba Qosmio G35-AV600 Notebook
I have new ibmx3400 series serv er its not start but shown the green light if i press the power on switch on server and give also the orange color light what can i do i thing this is power problem please...
Just installed the very same server for 1 of our clients. This may sound dumb... however, after pushing the (green) power button - you must *wait* - it seems an inordiante amt of time for the boot to be shown. But should eventually come up!
If not, in warranty call IBM Server support: 8004267378 Make sure you have your mach. type to enter.
Cheers,
gurutim
Mar 17, 2009 | IBM x3400 Server
Power cycling
Hi, If the power on/boot up sequence does not even reach the Windows logo before recycling, it is not a software/virus issue. If at certain times the laptop would continue powering up and booting into Windows but more often recycle the powering up process then I am inclined to think that it is a hardware problem. Hardware possibilities: 1. Might be loose connection or corroded terminals/connectors; 2. Cold solder of surface mounted components in the mainboard; 3. a USB device is interacting - try booting without any USB devices attached; 4. try running the Toshiba without the battery and just the AC adapter; Your possible options: a. Try performing #s 3 and/or 4 and note if there is a significant change in the booting process; b. 1 & 2 would require opening the laptop and do a circuit diagnosis, you might be better off seeking the services of a qualified professional. Hope this be of some help/idea. Post back how things turn up or should you need further information. Good luck and kind regards.
Sep 03, 2007 | Toshiba Satellite M45-S169 Notebook
Computers & Internet Logo
David Payne
David Payne
