Question about Garden
Ryobi cs26 aFTER STARTING AND WARMING UP - INRUN POSITIO - MOTOR DIES IF THROTTLE IS PRESSED TO FULL. wHN WEED WHACKING, IT DIES OUT
  • 7,482 Answers
Hi Brad
Sounds like you have dirt/debris in your caburetor jets,fuel passages or a diaphgram that is becoming non-flexible.
Check/Clean/Replace your Air Filter, a dirty air filter can make your engine run to rich with fuel.
Also be sure to check and clean your spark arrestor in the exaust,if you have one installed on your engine.
Note: ALWAYS USE COMPRESSED AIR TO CLEAN YOUR JETS AND PASSAGES, VERY IMPORTANT.
Note:Before you disassemble the carburetor:
Write down on a piece of paper or take a picture of how the linkage attaches to your carburetor for later reference when you go to reinstall your carburetor.
Mark each piece with a awl, or some kind of instrument that will make an alignment scratch before you disassemble the carburetor into separate pieces.
That way you will know which way it goes back together when you reassemble it.
Sometimes you can get by with priming the carburetor or by using a very small shot of starting fluid and letting it run a few times like that, and it will flush the gunk out of the jets,but most of the time you will need to rebuild the carburetor.
Be sure to check your fuel tank for water and dirt/debris, if there is water/debris then you need to clean your tank.
Check you fuel line condition after a while they will degrade and need replacment.
Check/Clean/Replace your fuel filter if you have one, normally they are located in the fuel tank of chainsaws and weedeaters.
When you remove your fuel lines from the carburetor be sure to make a drawing to how the lines are connected to the carburetor or take a pictue for later reference.
Normally the big line will be the line the fuel filter is connected to inside of the tank.The smaller of the two lines is the return to the fuel tank from the carburetor after it is pumped thru the carburetor by the primer bulb.
Make sure you are using fresh fuel...and oil if your using a two cycle chainsaw or weedeater with the oil to the right mixture...too much oil as it can cause hard starting and excessive smoking.
If the chainsaw/trimmer is over a couple of years old, then I recommend that you buy and install a new carburetor repair kit,because the diaphragm will get hard and that will cause it to be hard to crank.
The diaphgram may look good and flexible, but it can be deceiving and not act as a fuel pump as it should because it has become too hard and will cause hard starting,start and run and shut off, etc.
When you clean your carburetor, I recommend that you use a laquer thinner type cleaner to clean and dissolve the laquer build-up in the float and needle jet passages.
Be sure to remove all plastic and rubber parts before using the laquer thinner because it can dissolve the plastic parts and render them unuseable.
Be sure to use COMPRESSED AIR to blow out all the fuel and air passages.The higher air pressure is needed to blow some of the trash/debris from the fuel or air passages.
Be careful when blowing out the passages, because there are sometimes small rubber type seats in the bottom of some of the passages.
Keep in mind that the float (if you have one) for the carburetor must be level when you go to reassemble the carburetor or follow the instructions you get with the carburetor kit, or you could also ask the parts man that you get your kit from.
When you clean your carburetor and remove the jet screws, you will first need to lightly seat the jet screws.
But before you lightly seat the jet screws count the number of turns it takes to seat the jet screws from their original position.
Be sure to mark the turns down on a piece of paper.
That way when you put the jets back in, you know to lightly seat them first and then turn them back out to their original position before you started.
Note:
The little spring inside of the carburetor goes under the float arm.
That is where your fuel inlet needle/float valve is located...on the arm at the end.
Normally there is a small indention in the carburetor base and a small protrusion on the underneath of the float arm where the spring will be in the right postion for installation.
The spring will set in the indention and you will install the float arm with the needle/float valve and float rod into position over top of the spring,you will push down until it is in position and then you can tighten the screw that holds the float arm assembly in position.
Once you have your carburetor cleaned/rebuilt that should solve your problem.
Please take time to rate me
Bud
Posted on Apr 27, 2013
#1 Taper
  • 1040 Answers
SOURCE: CS30 Ryobi trimmer dies when I press throttle!
Yes. You just need to do a simple carburetor cleaning. Disassemble the carb. and spray with carb. cleaner. Make sure the small screen is in carb. is free of debris. Use a Den Tek Brush,(http://www.dentek.com/shop.php?target=products&product_id=7), to clean the small portals in the carb.
If you need further assistance, just let me know.
Jim
Posted on Jun 08, 2009
SOURCE: Ryobi 25cc grass timmer, cuts out when full throttle applied
check gas cap vent check ball may be stuck
Posted on Aug 19, 2009
  • 203 Answers
SOURCE: I bought a Ryobi RY34420 yesterday from home depot
Sounds as tho it needs a minor carburetor adjustment. It's not getting enough fuel when you pull the throttle. Don't know if the owners manual addresses this issue or not, may want to check.
Posted on Dec 23, 2009
rycgl
  • 1545 Answers
SOURCE: How to remove the carburator from the Ryobi SS30
It may just need a G & D kit installed. That is a gasket and diaghragm. Just take the 4 Torx screws out of the rear cover and remove it. You will then be looking at the choke plate assembly which has 2 long screws that go through the housing of the carb and screw into the rear crankcase cover/reed valve assembly. Pull the 2 fuel lines off (noting where they went) and you'll have it. Once you have the carb off, you can get the manufacturer and model # off of it and order a kit. The G&D kit will probably fix what ails it or you can go for a complete rebuild and get a rebuild kit. If the carb is a Zama or Walbro, they sell the kits on Ebay.If the carb has brittle diaghrams inside, replace them; if they are still soft and pliable, then you may only need to clean the carb real well and adjust the H and L mixture screws. They will be plainly marked, but are difficult to remove. Post back for more help!
Posted on Oct 19, 2010
hunter19_46m
  • 7482 Answers
SOURCE: I have a RYOBI weed eater model ss30. I can get
Check your fuel filter in the fuel tank,if you have one it may need cleaning or replacement.
If the mower/weedeater is over a year old, then I recommend that you buy
Sounds like you will need to clean the carburetor or replace your carburetor
internal rubber parts like the diaphgram and O rings.
Be sure to use compressed air to blow out all the fuel and air passages.
Sometimes you can get by with priming the carburetor or using starting fluid
and letting it run a few times like that and it will flush the gunk out of
Keep in mind that the float for the carburetor must be level when you go to
carburetor kit.
and then turn them back out to their orginal position before you started.
This is a FREE answer,Please rate me
Posted on Dec 23, 2010
Starting procedure
Terry: According to eHow.com:
  • Put on a pair of safety glasses. Remove the fuel cap from the Weed Eater and set it aside. Fill the fuel tank with unleaded gasoline that has been mixed with quality 2-stroke oil in a 40:1 ratio. Replace the fuel cap.
  • Move the Weed Eater to a safe place and lay it flat on the ground. Depress the fuel bulb located beneath the carburetor approximately six times to prime the engine. Press it slowly so that fuel has adequate time to traverse the fuel line.
  • Slide the handlebar-mounted engine "On/Stop" switch to the "On" position. Slide the choke lever beneath the fuel tank to the "Full" position.
  • Depress the "Throttle Lock" lever located beside the engine "On/Stop" switch. Keeping the lever depressed, squeeze the throttle trigger. Release the throttle lock. This sequence holds the trigger in the depressed position, which aids in starting the Weed Eater.
  • Roll the Weed Eater so that it is resting on the engine and the trimmer head shield only. This will allow the spinning trimmer head to avoid contact with the ground. Brace the Weed Eater by holding it to the ground with one hand. Using your other hand, pull the starter rope quickly until the engine begins to run. Do not pull the rope more than a dozen times. If it fails to start by then, squeeze the throttle trigger and continue to pull until the engine starts.
  • Allow the Weed Eater to warm up for about 15 seconds, then slide the choke lever to the "Off" position. Let the trimmer run for another minute without touching the throttle lever. After the Weed Eater has warmed up, squeeze the throttle trigger once to disengage the throttle lock. The trimmer is now operational.
  • Read more : http://www.ehow.com/how_6720315_start-gas-weed-eater.html"
    Jun 08, 2015 | Garden
    Is the Ryobi model CS26 considered a professional weed trimmer?
    The Ryobi curved shaft trimmer is a consumer grade trimmer. Both the 26cc & the 30cc engines from Ryobi (Homelite) are pretty light duty. They have 1 piston ring and use an anodized aluminum piston and cylinder. A commercial grade engine would have 2 or 3 piston rings and the cylinder and piston would be chrome plated for longer life. Look for the emissions label on your trimmer. The emissions code of C would indicate a 50 hour emissions longevity (consumer grade). A code of B would indicate 125 hour emissions longevity (estate grade). A code of A would indicate 300 hour emissions longevity (commercial grade).
    I hope this helps.
    Dec 29, 2010 | Ryobi 30 Cubic Centimeter Curved Shaft Gas...
    My Ryobi cs30 weed eater tends to shut off after I release the throttle.
    Find the idle speed screw (not the jet screw) and turn it CW until the engine idles without dying. If too high, the string head will turn all the time. Hope this helps
    Sep 06, 2010 | Ryobi Garden
    How to start a Ryobi Gas trimmer CS26 RY26500B? I
    turn switch to on possition press primer bulb 5 to 7 times choke pull rope then turn choke off
    Jun 27, 2010 | Garden
    Getting the Ryobi Started
    You don't mention what model. On mine, CS26, it says, Turn handle switch to on (right as your holding it), press primer bulb 7x, turn choke handle to start (down), pull till unit starts. Run 6-10 secs then turn choke handle to run, (up). Do not squeeze the throttle trigger during start procedure. Hope this helps
    Apr 23, 2010 | Garden
    I have a 31 cc ryobi weed eater start for about
    I think a new carburetor kit and a good carburetor tune up is in order my friend. Sounds like it's starving for gas. If it bogs down after warm up when you throttle it, then yes it needs a carb tuning. The L screw is the low side screw and should be turned in lightly until it seats then back it out one and quarter turns (1 1/4). The H screw is your high speed screw. Also, turn it in lightly until it seats, then back it out approximately a 3/4 turn. With these settings the unit should start and may even stay running. Again, if it bogs when throttled, while running turn the L screw out a little more maybe only 1/16th of a turn and then try it again. If it does rev then you'll have to adjust the H screw in about a 1/16th of a turn. But make sure you only do this after the engine has warmed up.
    Hope this works, good luck
    Skidooer
    Sep 27, 2009 | Ryobi 30 Cubic Centimeter Curved Shaft Gas...
    My weed eater will start but when I push on throttle it dies
    well take the spark plug out take some WD40 and give it a shot inside the unit, remember to keep the unit level when hitting the throttle and allowing it to warm up for a few minutes before use also make sure where your choke lever is. also when starting I start it on the ground like most manuals state and leave it idle on the ground for a minute before picking it up and then when I pick it up I make sure that the gas tank is tilted towards the ground so there is no room for air to get into the filter causing and disturbance while the unit is warming up.
    Nov 15, 2008 | Ryobi 30 Cubic Centimeter Curved Shaft Gas...
    Garden Logo
    Top Garden Experts
    Dennis Key
    Dennis Key
    roeb
    john h
