Question about Hunter 52" Ceiling Fan With Light And Remote Control
Hunter 20720 light flickering - Hunter 52" Ceiling Fan With Light And Remote Control
What causes light flickering in Hunter Oceanus ceiling fan?
Might need a new receiver. I have one if that's your problem. fanman9952@aol.com
Sep 06, 2014 | Hunter 23534 Oceanus Graphite Ceiling Fan
Lights in ceiling fan flicker when turned on
Make sure you have the correct wattage for the socket!
Mar 29, 2014 | Hunter Dryers
Ceiling fan lights flicker in bedroom with 23watt cfl bulbs
Sounds like an older unit that has either a dimmer or electronic switch. You need to use dimmable CFL lamps.
Nov 07, 2013 | Hunter Dryers
We have a 2 year old Hunter Fan Model # 23285 The fan works fine. Last week the lights began flickering. We changed bulbs, checked for loose wires, etc. The lights go on dim and continue to flicker. ...
if problems with lights flickering. remove governor inside for the lights, and wire lights direct. this should cure problem. ( black box or governor ). part # 98480-02-- have a good day !!
Jan 06, 2011 | Hunter Ceiling Fans Individual...
I am using spiral flouresent bulbs in my 4 light Hunter ceiling fan. The lights are always flickering. What is the problem? We do not have the remote installed
it has a watt governor on inside for the lights. remove this governor and wire the lights directly. this will fix problem. ( part #-- 98480-02 ).
Nov 17, 2010 | Hunter 52" Ceiling Fan With Light And...
Flickering lights
make sure you have the remotes/receivers set to different jumpers. I installed 2 fans and had the same problem, just had to change the jumpers on one of the fans and the corresponding remote
Jul 19, 2009 | Hunter Fan Co. 60 In.Brushed Nickel...
Fan works, light doesn't on Hunter ceiling fan
I would begin by testing each bulb in a different socket somewhere in the house.
Apr 06, 2009 | Hunter 27187 Remote Control
Dryers Logo
498 people viewed this question
Top Hunter Dryers Experts
Paul Bade
Thomas Perkins
Thomas Perkins
Are you a Hunter Dryer Expert? Answer questions, earn points and help others
