Question about Movado Womens Ono White Dial Watch 0606097
How do I remove links - Movado Womens Ono White Dial Watch 0606097
Link removal from bracelet?
    1. Use the steps below to remove your band. You must separate the Link Bracelet into two pieces before removing the band from your Apple Watch. While removing the band, don't force the band or twist it. Use the steps below to avoid damaging the band or clasp.Jun 19, 2015
      Remove the Link Bracelet on your Apple Watch - Apple ...
      https://support.apple.com/en-us/HT204831 Apple Inc.
    Feedback
  1. How to resize or remove links from your Magnetic Bracelet ...
Jan 01, 2016 | Watches
How do you remove links from my watch band DKNY?
Instructions
    • 1 Determine the amount of links that need to be removed for the watch to fit on your arm correctly.
    • 2 Find the tiny holes on each link. Most DKNY link wristwatches, such as the 3107 model, have holes at the links near the clasp.
    • 3 Using the screwdriver, gently push the pin holding the link bar on the first link you want to remove. The link bar should come out on the other side.
    • 4 Take the pliers and completely remove the link bar from the band. The link band will still be attached to the clasp. Remove the link with the pliers. Repeat Steps 1 through 4 for each additional link you want to remove.
    • 5 Gather the watch band and and bring the two sides back together. Join the link bar and the clasp together and, using the screwdriver, press the link bar back into the hole completely.
How to Take the Links off DKNY Watch eHow
Aug 27, 2014 | Watches
How do I take the links off an m.z berger
There are three links on either side of the closure mechanism
marked with an arrow. These are the ones to remove. If you only
need to remove one link, remove it from the six o'clock side of the band. If more than one, then try to balance, one from each side, etc.
The easiest way to remove individual links is with a "link remover"
tool of the sort used by jewelers. These are not expensive. The other way is to get a very small, slim diameter finishing nail and
position the sharp head of the nail in the slightly recessed hole of the link to be removed. The watch band should be perpendicular on a wooden table. Gently pound the nail downward with a hammer. If you're skillful, and lucky, you can get a 1/16" or more of the retaining pin to protrude from the other end. Now, use needle-nose pliers to gently twist and rock the protruding nub of the pin, and try to pull it out. Good luck with that.
You'll need to remove two retaining pins for each link, or consecutive run of links, that you're removing. Then reconnect
and line up the remaining links and (gently) insert and/or pound
one of the removed retaining pins back into the hole to keep the watch band assembly intact.
Again, good luck!
Feb 17, 2012 | Watches
Band is too big. how do i remove links?
mcdevito75 here, generally the links are held together with pins, for this you"d need a link remover tool, Best Bet is to have a small watch repair shop remove these links, hold onto the removed links in case you need them again.
Feb 11, 2011 | Watches
Shorten the length of a Kenneth Cole "New York" watch band
With the watch on your wrist, check to see how many links need to be removed from your watch. Your watch should fit comfortably on your wrist. Remove the extra links with your paper clip or push pin.To remove the links from your watch, press on the small pins with your tool that are holding the links in place. The watch band should now separate allowing the pin to become free, and you can now remove the pins first and then the links one at a time until you have removed the desired amount of links. Reattach the watch band when you are done removing the links. To reattach the watch band to your watch, simply fit the end links into each other. To complete the resizing, use your push pin to re-insert a joining pin.
Jan 19, 2011 | Watches
I am trying to remove 2 links from a ladies indiglo watchband
mcdevito75 here, To remove the links from any watch band requires a special tool called a Link Remover tool, available on ebay. You can remove the links without the tool but the time and work, just isn"t worthit, even with the tool if you don"t know anything about watches, your best bet would be to look for a small watch repair shop in your area , and have them remove the links, hold onto these links in case you need to ever replace them.
Aug 26, 2010 | Timex 2J611 Watch
I recently received a Tag Heuer Link Calbre 5 Automatic watch as a gift. However, it needs 1-2 links removed. I took it to a local jeweler and they said it can't be sized because it they weren't ablwe to...
Here is how its done. First remove one end of the clasp (this is much easier on the adjustment side - just depress the pin and remove). Now you can separate the two halves of the first link (actually this is a half-link). Simply grab each half and pull. You may have to do some twisting - do it carefully so that you don't bend the pin. You may have to do some prying - if so, you can use a thin piece of plastic so you don't scratch the link and only pry along the pin so that you don't bend it. Once removed, you can now remove the first full link. Remove it in the same way. Now replace the end half-link and re-attach the clasp. Removing a link from the other side is a little more difficult. The clasp lock is held on with a long pin (slot on one end and screw on the other. One must be held in place while you turn the other. You may need another pair of hands to help you.
If you feel uncomfortable about any of the above, take it to a jeweler - a Tag AD is not necessary but probably best although any jeweler can remove a link if they understand how they are put together. Tell them the link is composed of a right and left half that snap together and they should then see and understand what they need to do.
Apr 28, 2010 | Tag Heuer Link Automatic Chronometer...
Removing links
Watches either have screws in the links that you can remove to remove a link. Or they have a pin in each link that you must push out to remove a link. Some have a "hairpin" looking keeper that you remove. Hope one of these will work for you. Good Luck
Dec 14, 2009 | Invicta Subaqua Noma Iii S
Movado Womens Ono White Dial Watch 0606097 Logo
16 people viewed this question
Top Movado Watches Experts
Jimmy Accardi
Are you a Movado Watch Expert? Answer questions, earn points and help others
