Question about Tools & Hardware - Others
Swingline model 51110 parts
My Swingline model 51110 stapler is stuck in the staple position. How do I "unstick/unjam" it?
  • 40 Answers
SOURCE: instructions on unjamming swingline electric
First, are you using the recommended staples for this stapler? Many heavy duty electric staplers don't use "standard" desk staples. Second, try unplugging the stapler, unloading the staples, and if possible, reach a couple of fingers into the stapler and try manually pushing up on the staple head to see if you can get the driver blade to come down. Does it come down smoothly, or does it seem like there is something stuck in there? If you aren't sure about disassembling the unit (my usual method-but I'd recommend having the parts diagram handy), try using a flashlight to look at the underside of the staple head, where the staples come out - can you see anything stuck in there? If so, you might be able to use a small knife blade or small dental pick to get jammed staple pieces out.
Posted on Mar 14, 2009
  • 40 Answers
SOURCE: Swingline Stapler Staples Only After You Open It Up....
When you lift up the top of the stapler (as though you are going to put staples in), does the pusher slide freely back and forth? It might be getting stuck at some point and not pushing the staples (either due to a worn pusher spring, or friction). First (after removing the staples) try spraying some light oil on the mechanism and lifting the top part of the stapler up and down a few times and observe how easily it moves back and forth. Also, with the top open try GENTLY sliding back and forth a little - if it slides fine with no sticking, try loading staples and using stapler. If it slides ok, but doesn't quickly return to it's "normal position" when pulled so as to put tension on the spring, rhen the spring may be worn and need replacing.
  • 40 Answers
SOURCE: Nothing happens when you load paper to staple.
assuming it is plugged into a good power source and turned on (no offense intended, just getting the obvious out of the way - and I've fallen victim to the obvious myself before), look inside where you put the paper - is there a trigger mechanism? Most electric staplers have them (the paper hits the trigger and the stapler fires), and some allow you to set the sensitivity of the trigger. If yours allows you to adjust the sensitivity, try adjusting it. If it's not adjustable, the trigger probably needs to be replaced (under heavy use, they may need to be replaced every year or so).
  • 23 Answers
SOURCE: Need staples for my Swingline Heavy Duty Tacker #800
If you can find Arrow brand staples - 60x30 series staples are interchangable with the old Swingline 8xx staples, sizes as follows:
Arrow 60430 = 1/4"
Arrow 60530 = 5/16"
Arrow 60630 = 3/8"
Arrow 60830 = 1/2"
Arrow 60930 = 9/16"
Posted on Mar 22, 2009
  • 132 Answers
SOURCE: I need staples forthe swingline electric stapler
Go to Lowes or Ace. Take the stapler or an empty box along.
Posted on Jun 27, 2009
Swingline model 67 broken staple driver part replacement
you buy a new stapler . they do not make that part as a replacement
Aug 27, 2016 | Swingline 06702 Model 67 Electric Stapler
Who sells staples 101 4 for a swingling 101 stapler
Hi, you can purchase them on amazon, here: Amazon com swingline 101 staples I hope this was helpful. Have a nice day
Jul 28, 2012 | Swingline Tools & Hardware - Others
How do you open swingline tot 50
Here's a video that shows how to open an older Swingline Tot stapler:
Vintage Swingline Tot Stapler Demonstrated
Nov 15, 2011 | Tools & Hardware - Others
Swingline optima 40 how do you open and close the stapler?
Swingline heavy duty staplers provide the power to staple up to 120 pages of 20-lb. paper easily and consistently. The all-metal construction of these staplers makes them an indispensible office tool. However, the way to load staples into a Swingline heavy duty stapler differs from the method for loading most other manual staplers and can cause a little confusion.
Difficulty:Easy Instructions
    • 1 Remove the follow block at the back of the stapler by pushing the mechanism in, lifting the block up over the holding hooks and sliding it out from the stapler. The follow block is the spring-loaded mechanism that holds the staples in place within the stapler.
    • 2 Load the heavy-duty staples into the staple tray.
    • 3 Replace the follow block by inserting it back into the stapler and locking it into place over the holding hooks.
Read more: How to Load a Swingline Heavy Duty Stapler ' eHow.com http://www.ehow.com/how_5822366_load-swingline-heavy-duty-stapler.html#ixzz1bVwG5bBn
Oct 21, 2011 | Swingline ® High-Capacity Heavy-Duty...
My Swingline Optima Power Ease will not staple, nor can I open it to try to find out why. There are staples in there, but it feels like there are no springs
This happened to me as well. I am not sure what causes this but heres what I did to fix it.
Just grab the top part of the stapler ( where it says Swingline) and pull up, like you are trying to seperate the top and bottom. You will hear a click and your stapler should work fine.
Sep 14, 2010 | Staples Swingline® 36115 Staple Guns Tools...
My Swingline Stapler Model 51110 electric stapler no longer staples. The staples will not move forward and it just does "blank" stapling. Also, it goes off on it's own all the time running stapples...
I have the same issue; however, there is some resinous material that came out of it as a result of my trying to figure out why it wasn't stapling anymore. Anyone know where I can take it for repair?
Aug 05, 2010 | Office Equipment & Supplies
Hello. I have a model #1000 Swingline Power Gun. It says,the extra heavy duty staple gun on the handle. I would like to purchase a box of 1/4" and 3/8" staples. The gun is so old I don't know the new...
Went to the local hardware and read the labels. The store brand fit and works as good as the original staples. The 1000 has outlasted several of the new fashion staplers. And the local hardware store is an Ace Hardware.
Jan 20, 2010 | Staples Swingline® 36115 Staple Guns Tools...
Instructions on unjamming swingline electric stapler model 270; jam is at the front of the stapler; staplers come out either broken, flaten or crooked and does not secure document.
Mar 03, 2009 | Staples Swingline® 36115 Staple Guns Tools...
Tools & Hardware - Others Logo
54 people viewed this question
Top Tools & Hardware - Others Experts
Are you a Tool and Hardware - Other Expert? Answer questions, earn points and help others
