Question about Wristech Blood Pressure Monitor
Hi, I have new WRISTECH BP monitor. It gives me reading in kPA, not mmHg. is there a way to reset it? Thank you.
How do i reset the memory on my wristech model GL52177 bp monitor?
take battery out wait for 1 minute then replace battery
Aug 13, 2014 | Health & Beauty
How to calibrate omega 1445 bp monitor
My first question is how do you know it's not accurate? I would tee in a digital manometer (measure in mmHg), wrap the cuff around a glass bottle and let the cuff inflate. When it fully inflates the cuff...look at the readings between the monitor and your manometer. If they are within a few digits of one another, I would leave it alone.
Inaccuracies with patient nibp readings are usually related to improper cuff placement on the patient. There's usually a mark on the cuff to indicate where the cuff should be placed in relation to the brachial artery. I believe this unit utilizes oscillatory technology to determine readings and an improperly placed cuff can create inaccurate readings.
May 23, 2014 | Criticare omega 1445 BP Monitor
I got a wristech jb5538,i don;t have a manuel,can;t find 1 online.i need to know how to switch between kpa and mmhg
i got a wristech jb5538,i don;t have a manuel,can;t find 1 online.i need to know how to switch between kpa and mmhg.
the solution is when the unit is off, press and hold the left (<) button
until you see a kpa or mmhg in the display.
release then press and hold the same (<) button to choose between
kpa and mmhg .
press the start stop button to start measuring.
I also requested a manual from
info@jobar.com they sent me one.
Aug 10, 2011 | Asseenontvguys Wristech Blood Pressure...
The cuff squeezes my arm too much and it hurts. The reading is way too high everytime. I don't know how to adjust it.
do not inflate the cuff too much. if you know your usual blood pressure, just add about 5-10 mmHg when you inflate it so that you won't hurt yourself. for example, if your BP is usually 130/90, squeeze the cuff to 135-140 only. but if you doubt that your BP is way much higher than that by assessing on what you are feeling, just do not squeeze the cuff further than 200.
Jan 21, 2011 | Life Fitness Ultra Blood Pressure Monitor...
What does it mean when you get a reading then 3 consecutive readings say EE
What is the pattern of the EE? If the two E's are on the same line, then you didn't inflate the cuff to a sufficient pressure. (Wait 2-3 minutes before trying again and then inflate the cuff to 40 mmHg higher than the previous attempt.)
If the Es are arranged vertically, then you overinflated the cuff. Any [ressure above 300 mmHg is beyond the range that this bp monitor can handle. If you reached this point by getting several underinflation alerts, ask your medical professional to test your bp and recommend the starting inflation level that you need.
Make sure that you have the cuff on properly. You may need to consider a different bp pressure cuff size to get an accurate reading.
I hope this.
Sep 09, 2010 | Omron Model HEM 432C Manual Inflation...
My wristech bp moniter will only pump up to 08 and then it displays the error message, what's wrong with it?
You need to make sure that the bp is RIGHT over the pulse point, that is the only way for them to read. they are great little items, but I prefer the arm cuff, have used them for 15 years on all my patients, the reading seems to me to be more steady and accurate. but, I know you already have to wrist, so please check the locations that you are placing it on your wrist. Please write back should you need more info, would love to make sure you are on schedule..... Guy
Sep 08, 2010 | Asseenontvguys Wristech Blood Pressure...
How do I reset my monitor clear the deck wipe it clean as if it was new? wristech model ZSBP-002
Press both the memory and on/off buttons at the same time. Hold for a couple seconds and monitor will reset.
Dec 08, 2009 | RTO WrisTech Blood Pressure & Pulse...
WITH AUTOMATIC CUFF BLOOD PRESSURE MONITOR GETTING ERROR
E might represents insufficient inflation for your mom. For automatic inflation monitors usually there is a mechanism to keep inflating the cuff to higher pressures for people with higher BP. Check how is done. In some auto monitors,while cuff is inflated you keep pressing on START button until pressure reaches to some 15 to 20 mmHg higher than the pressure that auto usually stops and displays E.
Mar 04, 2009 | Mabis Automatic Digital Blood Pressure...
Wristech Blood Pressure Monitor Logo
63 people viewed this question
Top Wristech Health & Beauty Experts
Robin Hill
Robin Hill
wcdoc1953
wcdoc1953
Are you a Wristech Health and Beauty Expert? Answer questions, earn points and help others
