Question about Sony Handycam HDR-HC7 Mini DV Digital Camcorder
Touch screen Not working, touch function disabled
  • Klet Gozdecki Apr 28, 2013
    The connecting tape was replaced, but this didn't resolve the problem.
HOw do I turn off touch screen on a Sony VAIO Tap 20 Touchscreen All-in-One Desktop Computer, Intel Dual-Core i5-2430M 2.4GHz, 8GB RAM, 750GB 5400 RPM HDD, Windows 7 Home Premium 64-bit
1.Press the Windows logo key + X.
2.Select Device Manager from the list.
3.Click the little arrow next to Human Interface Devices to expand the list.
4.Click the touch screen driver (in my case, NextWindow Voltron Touch Screen).
5.Right-click, and select Disable from the list.
6.Click Yes on the dialog box that asks if you are sure you want to disable the touch screen driver.
7.Restart your computer
When you want your touch screen to work again, follow the process above, EXCEPT when right-clicking the touch screen driver, select Enable
See the website
Turn off VAIO all in one touchscreen function disable annoying system...
Mar 07, 2015 | Sony VAIO VPCL23CFX/B All-In-One PC - 2nd...
How do i turn off a my sony all in one touch screen, i do not touch the screen for options, and its driving me crazy
  1. Press the Windows logo key + X.
  2. Select Device Manager from the list.
  3. Click the little arrow next to Human Interface Devices to expand the list.
  4. Click the touch screen driver (in my case, NextWindow Voltron Touch Screen).
  5. Right-click, and select Disable from the list.
  6. Click Yes on the dialog box that asks if you are sure you want to disable the touch screen driver.
  7. Restart your computer
When you want your touch screen to work again, follow the process above, EXCEPT when right-clicking the touch screen driver, select Enable See the website
S
SeS Turn off VAIO all in one touchscreen function disable annoying system...
Mar 07, 2015 | Sony VAIO Tap 20" Touchscreen All-in-One...
My neighbor disabled my Toshiba touch pad. what do i press to re enable it?
Start menu. Control panel. Go from there with keyboard options and it should work. OR research stick keys/ on screen keyboard
Feb 24, 2015 | Toshiba Computers & Internet
What do when ipod touch is disabled and only one key is working
Go to where ever you got it and they will surely fix it.
Jul 10, 2014 | Apple iPod touch
On my samsung eternity, the touch screen wont work. i can do anything but touch the screen it wont work! how do i fix it?
Hey buddy,
The issue can be with the flex of your phone that connects to the touch screen. The connection might be loose thereby disabling the touch screen functionality.
The best solution is to take it to Samsung repair shop and get it repaired by an expert. They are well experienced with touch phone firmware malfunction issues.
Thanks!
Dec 14, 2010 | Samsung Eternity Cell Phone
Would like explanation of function key symbols I want to turn off the finger pad.
function key is Fn key on keyboard.
these keys might be in orange color
with the help of these keys you can control sound volume. you can adjust screen resolution like brightness .you can also turn off/on wireless features.These keys are like shorcuts keys to perform few functions on your laptop.
To turn off your the finger pad
You can use the Mouse Properties window to disable the touch pad and track stick or adjust their settings.
Open the Control Panel, and then click Mouse. For information about the Control Panel, see Windows Help and Support Center <findinfo.htm>.
In the Mouse Properties window:
Click the Device Select tab to disable the touch pad and track stick.
Click the Touch Pad tab to adjust touch pad and track stick settings.
Click OK to save the settings and close the window.
May 07, 2010 | Dell Latitude D610 Notebook
How to disable the touch srceen feature of a CF-73
If it's similar to the earlier models, as it boots up press f2 to access the bios. in the second or third tab there is an opportunity to disable the touchscreen. It is a part of the mouse function in windows...
You all take care. We're proud of you.
Jun 20, 2008 | Computers & Internet
Disabling touch pad
The touchpad should be able to be disabled through the BIOS.
Restart the computer, then push F10 to access the BIOS - if F10 doesn't work, try the other function keys and possibly the ESC key. You should find the option to disable the touch pad within the BIOS settings.
May 09, 2008 | Compaq Evo N610C Notebook
Touch Screen Damaged
To some degree you can use the control buttons on the device but you will be limited to what you can do. I suspect you will find the device impractical to use without the stylus.
Feb 14, 2007 | O2 Xda IIs Pocket PC
Sony Handycam HDR-HC7 Mini DV Digital Camcorder Logo
42 people viewed this question
Top Sony Video Cameras Experts
Larry Stiles
Larry Stiles
Are you a Sony Video Camera Expert? Answer questions, earn points and help others
