Question about Food Mixers
Motor runs but does not rotate bowl. - Food Mixers
What mixer is it ..if its a Kenwood Chef the bowl does not turn ...
Posted on Apr 27, 2013
What direction should a Hobart H600 mixer rotate?
Check Rotation (Three-Phase Machines Only)
Three-phase machines must be connected so the planetary rotates in the direction of the arrow on the
Drip Cup. To check rotation:
Set the gear shift lever on 1.
Apply power to the mixer, set the Electro-Mechanical Timer on HOLD; or, if equipped with a
Programmable Timer Controller, set it on [ -- : -- ]. With the Bowl Support all the way up,
momentarily run the machine by pushing the START and then STOP buttons.
If rotation is incorrect, DISCONNECT ELECTRICAL POWER SUPPLY and interchange any two
of the incoming power supply leads.
Oct 12, 2017 | Hobart Food Mixers
Kitchenaid food processor, motor rotates but when blade is inserted it won't rotate
It will be something in the mechanism that activates that switch in the base. It is more common for the fault to be in the lid but it is not so uncommon for it to be the bowl. You are using the pusher aren't you? That's the mechanism activator. This information is relevant to the wide mouth model.
Jul 30, 2014 | KitchenAid Food Mixers
Need a new bowl
Sadly FIXYA has no control or ability to FIX the problem you have with the mixing bowls you ordered that are not the correct configuration for your mixer. suggest you contact the manufacturer again
Aug 17, 2017 | Oster Stand Mixer model: Fpstsm5102
Mixmaster mx001
Refer this issue directly to Mixmaster.
Mar 04, 2014 | Food Mixers
Kitchen aid mixer 5kpm5 motor doesnt go round freely
Any appliance with a motor should rotate freely. These are basically gear driven devices, Kitchen Aid makes different quality equipment. So either the gears are worn or possibly if you notice an electrical smell the problem could be at the tail of the motor. there are 3 major components 1. the brushes where the armature spins if you look inside the vent holes you might see a slight arc while it is running 2. the tail piece which is how the motor is kept straight. or as I said worn gears. this is especially common when companies use plastic gears instead of metal ones. Commercial appliances made by people like Hobart are expensive, but they outlast most others..
Apr 09, 2013 | KitchenAid 5kpm5eer Pro-Line Heavy Duty...
When raised to do whipping my professional 550 hd mixer attachment does not scrap the bowl to mix properly
You can adjust the mixer bowl up and down slightly. If you lower your bowl and look at the back you will see a little screw, it looks like a flat head screw and it is on the "neck" of the mixer.
You can raise and lower the bowl by adjusting this cam screw. You can tell that your bowl is adjust correctly by attaching the flat beater and put a dime in the bottom of the bowl, the beater should just barely touch the dime and move it around the bottom of the bowl.
The beater will not scrape the sides of the bowl, if you are wanting the sides of the bowl scraped I would recommend the Flex Edge Beater made by KitchenAid which is basically a flat beater with a rubberized edge which will scrape the side of the bowl as it rotates.
Here is a link to the flex edge beater on our website: http://www.mendingshed.com/kfe6l.html
Let me know if you have any other questions.
Thank you,
ColleenCustomer ServiceMendingShed.com800-339-9297
Apr 04, 2013 | KitchenAid New Professional 5.5 QT...
The mixer turn table won't turn? Its only a year old?
Don't know a solution, because I am having the same damn problem.
I am very discouraged with this product.
It is a piece of ****.
I am thinking about taking it out back and shooting it with my 270 I bought.
That is the only solution I know.
Dec 03, 2010 | Sunbeam Heritage 2346 Stand Mixer
Seized mixer
It sounds like a stripped gear. Altho I can't find the parts diagram for the K5Awh I have found the diagram for the similar mixer with the lift bowl feature. Check the diagram below and make sure it is similar to your K5 machine since there are two designs for the motor on the lift bowl.
Look at the diagram below and find 9709231 worm gear item #18 in:
http://shared.whirlpoolcorp.com/assets/pdfs/literature/Repair%20Part%20List%20-%20W10157992.pdf
It is the one which usually strips. It can be purchased online for between 12 and 25 dollars so check the part number and put it into google to find the best price. Let me know if the motor design is different from what is shown in this parts list.
Take it apart first and see which gear is stripped.
http://www.misterfixit.com
alternate parts list is:
http://shared.whirlpoolcorp.com/assets/pdfs/literature/Repair%20Part%20List%20-%20W10168434.pdf
and the gear number is
W10112253
Apr 14, 2010 | KitchenAid K5AWH Stand Mixer
Hobart mixer A200 Rotation
Assuming the unit is 120v, single phase, my money is on a bad electronic start switch (not to be confused with the on/off switch) It's not visible without some disassembly. Usually, it is located at the rear of the motor cavity. Take note of all the info on your model data plate then go here to obtain a parts breakdown on your particular mixer. http://www.hobartservice.com/Parts/
I'd suggest replacing the capacitor as well.
Sep 28, 2009 | Hobart A200 Stand Mixer
Motor stalls out when mixing you unplug and plug back in and it will run had the motor checked out and was fine
You are overloading the bowl or you bought this used and when they wore the motor out, you ended up with it. Batters & icings 75% bowl capacity, doughs 65% bowl capacity. If you live by this, you will buy 1 mixer & never have to replace it, especially if it's a Hobart.
May 01, 2009 | Food Mixers
Food Mixers Logo
78 people viewed this question
Top Food Mixers Experts
Oscar Netto
Oscar Netto
Are you a Food Mixer Expert? Answer questions, earn points and help others
