Question about Panasonic Telex Magnabyte Video Projector non-working unit sold for parts only
Telex p1200 projector
I messed with all the settings on my projector. And now I can't get any picture only the sound works From the dvd
  • 25 Answers
Can you still see the projector's menu? If so, do a 'Factory Reset.' That will re-set it to the parameters it had when it first came out of the box. Factory Reset is usually buried a couple of levels deep, in an 'Advanced' menu.
Posted on May 01, 2013
Want to transfer slide pictures from a Telex Caramate 4000 to a laptop. Is it possible to do this?
you need telecine transfer facility take it to duplication house they might help ypu
Dec 21, 2013 | Telex Caramate 4000 Used Audio Visual
My polaroid fxm-1911c picture is distorted, sound distorted with loud buzzing when I try to utilize the tv signal input jack, also the dvd player doesn't work
Looks like there are some partial defects in the TV and might need attention of a qualified service technician. Anyhow, make sure that the input cable, RC jacks and sockets all do not have any loose contacts. Go through settings and ensure that every set up is as it should be.
Aug 02, 2012 | Polaroid FXM-1911C 19 in. LCD Television
Can hear sound but cannot see picture
Hi, if your LCD projector turns on and projects light with sound but not the picture on your computer screen, first make sure the projector is plugged into your computer. If it is, check your computer display settings. Go to "Control Panel" and "Settings" or "Windows Setup." Select "Display." Make sure it's set to appear on your laptop screen and the the projector screen. Most laptops have a "Fn" key dedicated to changing the output display setting.
If your projector turns on but emits no light or picture, replace the projector's bulb, often called the lamp. Most have a life of between 2,000 and 6,000 hours. Your projector may warn you when the lamp life is about to expire, although some models simply stop working when the lamp needs replacing.
Thank you.
Jun 06, 2012 | InFocus Proxima UltraLight DX3 Multimedia...
I have an OLD telex projector. Looks like a box with a tv screen on one side and carousel on top. have no idea how to use it. maybe bulb needs replacing
Telex called those "CaraMate XXXX" (XXXX usually relating to model number ). The old ones projected on the internal screen. Newer models could project both on the internal screen and (by sliding a door on the top panel) on a projection screen for larger audiences.
If it needs a lamp, check with: www.bulbman.com But you may have to search - - it's been a long time since they were manufactured!
Good Luck !!
Jun 21, 2011 | Telex Office Equipment & Supplies
Our telex 100cdra drops many cd's on each cycle. how do i set the wheel timming on the automatic disk feeder
Not sure if I fixed it, but it seemes to be work a bit bettor. With out using your "FREE" pay for servoce. FREE MEANS FREE" not pay and get something.
Oct 15, 2009 | Telex Computers & Internet
Slide/tray advancement
http://www.fixya.com/support/t1564949-slides_advance_continusly
This link talks specifically about a Kodak slide projector. However the faulty mechanism in your Telex works in a similar way if you feel up to taking it apart. If you do, mark every screw and piece you remove, in a diagram. Though your symptom is sporadic advancing and the other link is continuous advancing, it's essentially the same cause, as sticking trigger mechanism in the clutch release.
Jan 27, 2009 | Telex 3280 Caramate 80 Slides Rotary...
Sharp XR-1S Projector
you'd be better off hooking the dvd up to an amp and run speakers off of that.
Jul 17, 2008 | Sharp XR-1S Multimedia Projector
Onkyo TX SR 702 AV Receiver
don't run you video from the projector to the reciever. just run it to the dvd and run the sound from the dvd through the reciever
Jun 01, 2008 | Onkyo TX-SR702 Receiver
My Telex Spinwise 7 DVD Duplicator
Go to Spinwise and see if they have a fresh download--sounds like your program is corrupted. Or try going back t a time when you know it was working, and do a system restore to that date.
Feb 13, 2008 | Telex SpinWise Seven Drive (301735000)...
No picture?
I called sony, even though the manuel shows that you can use a component wire to hook up the set top box and hdmi for the tv and dvd sony claims that you can not do this. The cable box must also be wired with an hdmi cable going into the video 2 port.sony claims it doesn't work using component and hdmi together because the receiver is unable to up convert. I hope this helps. I have not tried it yet (i'm at work) we'll see what happens when i get home.
Dec 25, 2007 | Sony STR-DG510 Receiver
Panasonic Telex Magnabyte Video Projector non-working unit sold for parts only Logo
99 people viewed this question
Top Panasonic Office Equipment & Supplies Experts
CheckitRight
CheckitRight
Norman  J Weimar Jr
Norman J Weimar Jr
Mitch S
Mitch S
Level 1 Expert
Are you a Panasonic Office Equipment and Supply Expert? Answer questions, earn points and help others
