I would like to upgrade the ram and change a broken hinge. I can't figure out how to get into the laptop. Its a sony model PCG-4V1L
This isn't your model but it may help: http://www.youtube.com/watch?v=-kTuIIciEkM OR: http://www.youtube.com/watch?v=s5G4-ndTz6Q
SOURCE: Laptop Driver PCG-8N1M
Due to regional differences of the models, some model numbers may only be applicable to certain limited regions, could you pls try and verify if your PCG-8N1M is identical to the PCG-GRT895MP. If yes, you may want to try here.
Hope this be of initial help/idea. Pls post back how things turned up or should you need additional information.
Good luck and kind regards. Thank you for using FixYa.
SOURCE: DRIVER for Laptop SONY vIO MODEL 933A ( PCG 933A )
looking for sony vio vgn-cr34GN/b winxpp drivers
SOURCE: sony laptop driver model PCG-7G2L
http://b2b.sony.com/b2bMicrosites/landingpage/vaio_drivers/download_vaio_drivers.html
you can download from this web site
SOURCE: Sony Vaio Laptop PCG 9U1M
i have the same thing pcg 9u1m on bottom and pcg -k415s on screen part - and its 3 yrs old!
SOURCE: Upgrade the RAM of Sony Vaio VGN-B100B
The slots are located behind your keyboard. First disconnect the power cord from the computer and remove the battery. To remove the keyboard, there is a screw locate next to the release slider for the battery, remove it and set it aside.. Flip the laptop back over and lift it out from the top (by the function keys) and lay it keys down on the touch pad. You can remove the keyboard completely if desired, but not necessary. Install the new memory into the exposed slot following the instructions, and take all safety precautions. Assemble the computer reverse of how you took it apart.
