Question about Lenovo IdeaPad Y460 Notebook
Restore default desktop background wallpaper - Lenovo IdeaPad Y460 Notebook
Change desktop background select netbook
Go to gpedit.msc and select the user configuration,then change the value of the wallpaper.
Aug 13, 2013 | HEWLETT-PACKARD G56-127nr Notebook
Tip
Applying the settings to the logon desktop
Next, you need to apply the Screensaver settings to the Logon Desktop / Welcome Screen (Technically, HKEY_USERS\.Default registry key), so that the Screensaver is invoked when no user is logged on. Copying all the Screensaver settings to the Logon Desktop (or Welcome Screen) manually is a tough task. Use Tweak UI instead.
Download and install TweakUI.
Launch TweakUI and click Logon, click Settings.
Select Screensaver from the list box and choose Copy Now
The Screensaver settings are applied to the Logon Desktop
Restart Windows for the changes to take effect
Allow few minutes at the Logon screen, to test if the Screensaver is working properly. The Screensaver should launch after the timeout. It will look as if the Company Logo moves around.
Additional Tip
The User interface / slider allows the minimum value for picture change interval to 6 seconds only. To reduce the change interval to less than 6 seconds, alter the registry value named ChangeInterval (Set decimal value 1000 for 1 Second, and so forth) in this key:
HKEY_USERS \ .DEFAULT \ Control Panel \ Screen Saver.Slideshow
For Current user profile, make the change here:
HKEY_CURRENT_USER \ Control Panel \ Screen Saver.Slideshow
With no logon wallpaper set, Windows displays a pre-defined color for the logon desktop. ( If you have enabled Welcome Screen, press CTRL+ALT+DEL twice to see the logon screen background color. ) To change the logon background color to that of your choice, you need to alter the registry:
Click Start, Run and type REGEDIT and press Enter
Navigate to the following key:
HKEY_USERS\.DEFAULT\Control Panel\Colors
Backup the registry key by exporting to a REG file
In the right pane, double-click Background
In the Edit String dialog box, type the Color code in R G B format and then click OK.
Example: Type 0 0 0 if you want to see a Black background. You can choose any combination from 0-255
Points to ponder
If the logon Wallpaper is set, the background Color may not be visible. So, you must reset the Wallpaper value to a blank string in this key: HKEY_USERS\.DEFAULT\Control Panel\Desktop
If the Background value is set under the following Winlogon registry key, the above setting is ignored. In other words, the Winlogon\Background value takes precedence over the .DEFAULT..\Background value.
HKLM\Software\Microsoft\Windows NT\CurrentVersion\Winlogon
on Mar 24, 2008 | Microsoft Windows Vista Ultimate Edition
Wallpaper
To change desktop background/wallpaper on windows xp:
  1. Right click on desktop (a.k.a main screen) select properties then goto desktop then choose desired background.
See following website links for more info
homeandlearn
Microsoft
    Apr 25, 2013 | eMachines eM250-1915 Netbook
    I can't change background wallpaper
    right click on your desktop background in the options that pop up there should be a personalize option or similar- click it and you should be able to chang it to whatever you want such as the defaults or using your own pictures. hope this helps
    Jul 25, 2012 | Samsung N150 Notebook
    I have acer aspire one d255e notebook, and i want to change the dekstop background but i cant make, there are no choices that i can change the wallpaper, my operating system is windows 7 starter
    Dear user,
    Unforetunately you cannot do anything to your desktop background because that is the default feature of Windows 7 Starter Edition.
    You have to upgrade at least Home Premium of your Operating System for you to change it .
    May 09, 2011 | Computers & Internet
    I cant change my desktop background ..
    To change the desktop background:
    1. Go to Start>Control Panel>Appearance and Personalization>Change desktop background.
    2. This will bring up picture location : desktop background. You will see boxes next to all the different pictures that you can select as wallpaper.
    3. Select the box next to the picture that you want to choose as your wallpaper(this will put a check in it.)
    4. If you want the picture to fill the screen, under picture position, select "Fill."
    5. Click "Save Changes." in the lower right of the window.
    Another way to change the wallpaper-
    1. Right click an empty spot on your desktop.
    2. Click on Personalize. (This will bring up the personalization window with themes in the main window.
    3. Click on the blue link "Desktop Background"
    3. This will bring up picture location : desktop background. You will see boxes next to all the different pictures that you can select as wallpaper.
    4. Then follow steps 3-5 above.
    Hope this is helpful-Thanks for using FixYa.
    Apr 30, 2011 | Samsung X15 Notebook
    How to change the wallpaper in dell mini 10' inspiron
    1. Download the Oceanis Change Background (http://www.sevenforums.com/attachments/tutorials/42272d1272912523-desktop-background-change-windows-7-starter-oceanis_change_background_w7.zip)
    2. Open the downloaded ZIP file and extract the Oceanis_Change_Background_W7.exe file to your desktop, then run it to install it. NOTE: You will be prompted to restart the computer to finish installing this program.
    3. When your computer restarts, you will see this as your desktop background. Click on the Oceanis Change Background Windows 7 shortcut to change your desktop background. (see screenshot below) 4. Browse to the images that you want to use and check (select) a image, or more than one image to have a desktop slideshow. Select the Picture position for how you want the images displayed, and any desktop slideshow settings if you selected more than one image. (see screenshots below) NOTE: These options are just like the default ones in the other editions of Windows 7 here that are now being allowed by this program by Oceanis for the Windows 7 Starter edition.
    5. When done, click on Save changes.
    Oct 22, 2010 | Dell Inspiron Mini 10 Notebook
    Where i can find to choose my desktop background?
    Right click on your desktop and a menu will appear chose the customize option from it or you can also select any wallpaper you downloaded and right click on it and select set as background.
    Feb 20, 2010 | Computers & Internet
    Desktop wallpaper problems
    send me a more detail about your problem ............ok
    Dear you have problem to change the wallpaper do this setp
    1.right click in desktop and click the proparity option
    2. and click the destop option
    3.select in any one in background in list
    4.click apply and click ok .............
    Dec 12, 2008 | IBM NetVista A30p PC Desktop
    Desktop background problem
    The image that you are using as wallpaper, what is the location of that picture?
    Lenovo IdeaPad Y460 Notebook Logo
    26 people viewed this question
    Top Lenovo Computers & Internet Experts
    pankaj rautela
    pankaj rautela
    Are you a Lenovo Computer and Internet Expert? Answer questions, earn points and help others
