Question about Canon MP41DHII Calculator
How do i replace a ribbon on a canon MP41DHii
How do you change ink on a canon p20-dh calculator
For accounting offices and stores, calculators that produce a printed paper are indispensable. Canon's desktop or commercial printing calculators use ribbon tape, and you'll need to change the ribbon when it is used up. All Canon desktop and commercial printing calculators use the same method for changing the ribbon.
  • Turn off the calculator.
  • Pull up on the tab on the far side of the printer cover to remove the cover.
  • Pinch together the ribbon lock (the arrow shows you the direction to pinch). Lift the ribbon spools off the shafts and discard them.
  • Separate the new ribbon spools. Guide the ribbon tape around the four guiding pegs and set the spools on the shafts. The spools should be peg side down.
  • Rotate the spools so the peg at the bottom of the spool goes into the hole of the spool holder. Release the ribbon locks.
  • Rotate the spools to make the ribbon taut, keeping the ribbon positioned around the guide pegs.
  • Replace the printer cover and turn the calculator on.
How to Change the Ribbon in Canon Calculator eHow
Feb 06, 2016 | Canon Office Equipment & Supplies
How to change ribbon on canon mp11dx calculator
See Page 3, top right column for ribbon change instructions and images.
https://www.manualslib.com/manual/355934/Canon-Mp11dx.html
Apr 15, 2014 | Canon MP-11DX Calculator
Back Light ribbon broken
This needs to be replaced as a unit, these are very fragile items and great care must be taken.
Jan 21, 2013 | Canon PowerShot G9 Digital Camera
Replacement ribbon for canon mp-11dx calculator
I did replace the ribbon correctly. I used a universal replacement. the black part of the ribbon in on the top and the red at the bottom but I am not able to print clearly on the tape. What would be my problem?
Sep 23, 2012 | Canon MP-11DX Calculator
My Canon QS310 electronic typewriter ribbon is always out-of-stock in our country. What other typewriter ribbons (brand/models) that are compatible with Canon QS310?
If you had posted what Country you are located in, I could have ran a search to locate someone local to you that has this product in stock. I am located in California. I could give you information on compatible ribbons which are available in my area, but they may not be available in yours and that would not solve your problem.
I would suggest that you stick with the ribbon that is made for your typewriter if at all possible? If you are unable to locate stock in your Country, try ordering the ribbons online instead.
The ribbons are available at Office Depot. They sell the product online and have your ribbon in stock. Here is a link to your ribbon on their website:
http://www.officedepot.com/a/products/914465/Canon-Model-AP11-Correctable-Film-Typewriter/
Here is a link to a website that sells both the generic and brand name ribbon for your typewriter:
http://www.fjaproducts.com/SearchMe/Department8640.asp
I hope this helps? Good luck!
Jul 07, 2011 | Canon Office Equipment & Supplies
Need to replace ribbon on canon mp25dv calculator
remove the printer cover, insert one spool on the left side pin, guide the ribbon though printer and inset other spool on right pin. make sure the ribbon looks like a C with the ribbon coming around the outside of each spool.
Apr 27, 2010 | Canon MP-25DV Calculator
I was replacing my screen on the SD800IS.
Sounds like you need to also reseat the skinny ribbon cable. Believe this is the one that provides power to the backlight:
http://blog.jharding.org/2008/05/replacing-lcd-on-canon-sd850-is-few.html
Jul 29, 2009 | Canon Cameras
How do i reinstall the ink cartridge rubber ribbon that came off inside my canon ip1600 printer?
Usually, the best thing to do is go ahead and get a replacement ribbon. When a ribbon comes loose, it can sometimes snag, causing a tear, that tear can drop threads into your machinery, causing jams. If however the ribbon is alright, then you should be able to replace it without much effort. just make sure you load it into any guide slats (where applicable) and do not force anything in. Hopefully, you have the owners manual. If not, search the mfr website for a copy of that manual in PDF form or DOC form, or call their support line.
Jul 20, 2009 | Canon PIXMA iP1600 Printer
My canon 17-85mm lens does not focus properly
this lens has a design shortcoming in it's aperture's ribbon cable ,the cable will rupture after around 1 year using, this problem taken place in more than 60% of owners with this lens, it will lead error 99, can not focus, focus mistake. Canon has no respons with it problem and ask you send to their quick fix store for repair.
It will cost about $40 to fix in Canon store.
now you can buy a aperture's ribbon cable (the one which is bad design and most easy to repture) with only $4 in ebay and replace the bad one by yourself. I suggest you had batter ask someone who have lens fix experience to do this, or you may not be able to assemble after you replace the ribbon.
Jul 13, 2009 | Canon EF-S 17-85MM F/4-5.6 IS USM Lens
Canon MP41DHII Calculator Logo
64 people viewed this question
old marine
old marine
