Question about Philips 60PP9352 60" Rear Projection Television
Rear projection panasonic tv
Color comes in and out on its own and if you put pressure on one side or the other. When the color is out the picture is good, but black and white.
    Scholar:
  • 90 Answers
Cold solder joint somewhere. What's your HU? If S, then the chrominance pin may be broken off, leaving only the luminance pin. Replace the S patchcord.
If component, both Pb and Pr would have to be intermittent for there to be only b/w.
Mr Bob
Posted on Feb 03, 2008
SOURCE:
Picture has shadows and blue is a dominant color.
Hello, your Panasonic rear projection TV might be due for some color convergence repair, there are some power amplifiers that overheat and begin loosing the color correction control.
Dec 11, 2010 | Panasonic PT-47WX53 47" Rear Projection...
Green Color Tint
I had a similar problem with my tv. Sometimes it depends where the tv is located, have you moved it? Magnesium in the earth caused my tv to have greanish tints in all four corners of my tv. Try moving your tv forward, backwards, or side to side. Let me know if this works.
Cynthia
Feb 01, 2008 | Panasonic PT-47WX49 47" Rear Projection...
Samsung DLP R&R Color wheel Model #HLR5078w
Samsung's digital light projection (DLP) televisions use a spinning color wheel to create the colors that are seen on the screen. If the color wheel becomes misaligned during use, it will become damaged and have to be replaced. Replacing the color wheel on a Samsung DLP television can be done at home, once a compatible-sized color wheel has been bought from a TV supply store.Replacing the color wheel yourself will void any Samsung warranty that might be in place, but is the only solution for getting the TV working again in as short a time as possible.
Put on the anti-static grounding strap to keep static electricity from damaging the internal components of the Samsung DLP TV. Turn the Samsung around so that the back is facing you. Make sure the Samsung is unplugged from the AC socket.
Use the Phillips screwdriver to remove all of the screws from the back panel. Put the screws aside. Pull off the back panel.
Loosen the two screws from each side of the projection bulb's case. Pull the projection bulb out. Put the projection bulb aside. Use the Phillips screwdriver to remove the two screws from the left side panel. Pull the side panel and the circuit board attached to it out carefully and put it down so that the cables attached to it have not been pulled out.
Take a picture of the power cable's position with the digital camera so that you can put it back correctly later. Pull the power cable out from inside of the Samsung's case so that the center panel is free to be pulled out. Remove the two large headed screws from the center panel with the Phillips screwdriver. Remove the top two screws holding the panel to the plastic case using the Phillips screwdriver.
5
Slowly slide the center unit out a few inches. Take a picture of the projector lens' positioning with the digital camera so that you can put it back correctly later. Unplug the two cables from the left side of the center panel. Unscrew the sensor switch using the Phillips screwdriver. Slide the center panel completely out of the Samsung and put it down on the clean cloth. Blow off the color wheel assembly with the compressed air.
6
Use the tweezers to remove the green plug from the top of the color wheel cover. Use the tweezers to remove the two cables at the side that are coming from the color wheel. Use the Phillips jeweler's screwdriver to remove the screws from the top, front and back of the color wheel cover. Slide the color wheel cover straight up to expose the color wheel.
7
Use the Phillips screwdriver to remove the three screws holding the color wheel to the color wheel assembly. Lift the color wheel up and out of the color wheel assembly and discard it.
8
Position the replacement color wheel in the color wheel assembly. Reassemble the color wheel and reassemble the color wheel assembly. Put the color wheel assembly back into position in the rear of the Samsung DLP TV. Reassemble the Samsung DLP TV. Plug the Samsung DLP TV back in for power. Turn the Samsung on and enjoy seeing the colors displayed properly again now that you have replaced the color wheel.
May 02, 2010 | Samsung HLR5064W DLP Projection TV
My Samsung 56 DLP picture lost is color and is making a buzzing noise which I suspect is the color wheel. The picture is now black
you need to change the color wheel
5
6
7
8
Feb 07, 2010 | Samsung HLR5667W 56" Rear Projection HDTV
My panasonic dlp model pt43lc14 shows yellow picture
there are many mirrors, filters and lenses in the projection assembly, This happened to me too. I took the assembly apart and there was one of the filters that had gotten charred. I peeled off the plastic filter and cleaned the glass it was attached to then put the TV back together, now have a perfect picture again.
Dec 19, 2009 | Panasonic PT-43LC14 43" Rear Projection...
I might have issues with my color wheel, Im bnot recieving a picture with full color!
if tv is lcd it has three color filters which can be damaged by heat.If it is dlp then it has a colr wheel which spins.they are located in the light engine.alcd tv has 3 lcd panels a color filter(red green or blue)is mounted behind panel coloring light going through lcd.prisms combine pictures before going through lens. If color burns off of filter then color of picture is affected
Oct 19, 2009 | Panasonic PT-50DL54 50" Rear Projection...
No convergence of color lines
You can get the PT47WX49 Convergence repair kit at the following link which contains all the parts and complete detailed photo instructions on CD so you can do the repair yourself.
www.tvrepairkits.net
Jun 25, 2009 | Panasonic PT-47WX49 47" Rear Projection...
No green color in picture?
its a simple fix. just go to your menu in TV adjust the RGB color. balance the RGB settings.
May 26, 2009 | Panasonic PT-47WX53 47" Rear Projection...
Color separation
Convergence amp ic bad
http://home.earthlink.net/~oleg.filippov/ConvergenceFix.htm
http://cmpalmer.blogspot.com/2006/11/fixing-my-own-tv-part-ii.html
http://www.hdtvoice.com/voice/showthread.php?t=28929
Or send to ptscorp.com
http://www.hdtvoice.com/voice/index.php?s=
good luck
please mark the post with a fixya
Mar 03, 2008 | Panasonic PT-51HX41 51" Rear Projection...
Panasonic T.V...
What is your tuner source? Cable,Satellite, antenna?...accordianman
Nov 13, 2007 | Panasonic PT-47WX49 47" Rear Projection...
Philips 60PP9352 60" Rear Projection Television Logo
96 people viewed this question
Top Philips Televison & Video Experts
matt martin
matt martin
Steve Allison
Steve Allison
Are you a Philips Televison and Video Expert? Answer questions, earn points and help others
