Question about Emerson Microwave Ovens
How do I find a phone number for defectiveEmerson Mircowavess
My mircowave caught on fire & i sent the products that i was supposed to send back to the rerun center & nothing happened expect I got an email telling me it was supposed to be delivered to me on either April 24th or 25th & here it is April 26th & no Mircowave I need a phone to contact someone to find out where my merchandise I paid for a extra warrenty on it & now nothing please help me
  • Emerson Master
  • 9,098 Answers
The information should be on your owner's manual and your service contract paperwork.
Emesron support is here http://www.emersonradio.com/support.php or you can call:
Customer Service
Toll Free: 1.800.909.1240
Days: Monday - Friday
Hours: 9:00am - 5:30pm EST
Posted on May 04, 2013
MicrowaveSvc
  • 9098 Answers
SOURCE: Mircowave works, exhaust door opens, fan stop working
From looking at the owner's manual, it looks like the vent fan is only supposed to come on when the internal temperature of the microwave gets too high OR when you press the VENT FAN pad. Here are a couple of fan-related excerpts from the owner's manual, which can be found here: http://products.geappliances.com/ProdContent/Dispatcher?REQUEST=SKUOBJECTS&DOCUMENT=Use%20and%20Care%20Manual&SKU=JVM1840BD (or the better URL here: http://tinyurl.com/yn7r6g) Automatic Fan An automatic fan feature protects the microwave from too much heat rising from the cooktop below it. It automatically turns on if it senses too much heat. If you have turned the fan on, you may find that you cannot turn it off. The fan will automatically turn off when the internal parts are cool. It may stay on for 30 minutes or more after the cooktop and microwave controls are turned off. - Vent Fan The vent fan removes steam and other vapors from surface cooking. Press VENT FAN once for high fan speed, twice for medium fan speed, a third time for low faw speed, or a fourth time to turn the fan off. Press the VENT FAN BOOST pad for extra fan speed. - Hope this helps.
Posted on Nov 01, 2006
MicrowaveSvc
  • 9098 Answers
SOURCE: help, my mircowave
Quite often this is due to grease or food particles stuck to the inside of the oven or stuck on or behind the waveguide cover.
The waveguide cover is usually about the size of a playing card and held in place by a plastic rivet.
It can be fragile, and the metal edges behind it can be sharp, so be careful!
The cover and the metal behind it should be cleaned with a mild, non-ammonia cleaner.
If the cavity metal of the oven is chipped or charred, it will have to be sanded smmoth and clean.
Then you can apply some high-temperature appliance paint, available from places liek Wal-Mart or Lowe's.
If your waveguide cover is burned, it will need to be replaced.
For more help from Emerson http://www.emersonradio.com ; Get help using your appliance 1-800-898-9020 ; Get help locating a servicer or parts 1-800-695-0098.
If it's not a problem caused by outside forces, it may be covered under warranty.
Posted on Oct 22, 2007
SparkGap
  • 363 Answers
SOURCE: JVM290
The interlock switch is badly adjusted or worn.
Remove the case and adjust the switch.
Posted on Nov 04, 2007
MicrowaveSvc
  • 9098 Answers
SOURCE: Change light bulb in Sanyo Microwave EMS6786V
If there's no obvious removable cover over the bulb (and the owner's manual doesn't address it) some disassembly may be required.
Always unplug a microwave before removing or installing any bulbs.
If it's an over the range type, remove the vent grille across the top and see if bulbs can be accessed there. There may be a panel on the bottom covering the light(s), instead.
If not, chances are you'll have to remove it from the wall, then remove the outer cover. If so, the installation instructions are very handy, and it's best to have two people since the microwave can be heavy and awkward.
If you don't have your instructions, please reply back with your brand and model number.
Once it's out of the wall, the outer cover (wrapper) will need to be removed, just as you'll need to do on a counter top model.
On a counter top model, be sure it's unplugged, but otherwise ignore the instructions above this paragraph.
The screws you need to remove should be pretty obvious, but a special driver (such as a T20H type or GTXH20-100) may be needed.
Be sure to put all the screws back in the right holes, since some may be special grounding screws.
Bulbs can be had in most grocery stores, hardware stores, home improvement centers, and big box or department stores.
Many models use halogen lamps. You must not touch the new one with your bare skin, as the oils will shorten the bulb life.
Posted on Oct 20, 2008
vitg55
  • 78 Answers
SOURCE: how to change a light bulb in a emerson mircowave model mw8115ss
If this is freestanding m/w:
1. disconnect from outlet
2. take the cover off.
3. light bulb located on right upper corner.
Posted on Dec 01, 2008
Microwave door doesn't close properly.
It's doubtful that it's supposed to work that way. For safety's sake, Id take it in for repair.
Mar 13, 2016 | In Microwave Ovens
Ge mircowave message is P F
"PF" means that the power has been interrupted, so you need to set the clock, then the oven should work.
If you actually do have a problem with this oven, it will have to be replaced, since GE does not make repair parts available for it.
Jan 16, 2013 | GE Microwave Ovens
Goldstar mircowave model 1310b parts manuel theres a plate at top of cooking area thats is burned two plastic pins hold it to top of mircowave need replacement, help curtis
Assuming that model is MV-1310B, that would be your stirrer fan cover, part number 3301W2A017A, which you can get from Encompass here or by calling toll-free at 866-779-5835.
If you need new clips / rivets for it, they are part number 4051W3A001A.
Jan 09, 2010 | Goldstar Microwave Ovens
BAked Potato caught on fire in GE Microwave
Fuse is behind the control panel. Has cavity sensors and a magnatron thermal disc also. Start with the fuse and then pull it down if not the problem. Eric
Aug 27, 2009 | GE Profile Spacemaker II PEM31 Microwave...
My mothers Kenmore countertop microwave oven caught on fire late one evening. She remembers nothing of the fire circumstances as she was in a burn center for six weeks. My sister had the same model...
There is a GE/Kenmore recall: http://injurylaw.reganfirm.com/2007/12/articles/defective-products/cpsc-notice-ge-ge-profile-kenmore-microwave-ovens-recalled/. I don't know if your relative's models are involved. I suggest that you file an incident report with the Consumer Product Safety Commission.
Aug 03, 2009 | Kenmore Microwave Ovens
Microwave caught on fire.
I agree! That is an extreme hazard. Possibly due to over voltage of the power supply or faulty relay systems. Emerson is usually a cheaper brand anyhow. I would get the money back instead of exchange.
May 22, 2009 | Emerson Black Microwave Oven
Turntable doesn't spin
Well the table might not be on the revolving piece- that is what happened to my microwave oven, or the revolving piece might have to be connected to a belt inside that turns it
Jan 17, 2009 | Sanyo Microwave Microwave Oven
Decor DMO2420 Microwave caught on fire
Please write back with more details if this reply doesn't solve it.
(Such as, Was the fire inside the cooking cavity? Has the inside been cleaned since?)
There is a cavity temperature fuse located under the outer cover, on the top left side of the cooking cavity. It is rated at 150 degrees centigrade.
If there is a fire, that will open, killing all power to the unit.
A replacement can be found at a local appliance parts company.
We're happy to help and we appreciate your thoughtful rating of our answer.
May 29, 2008 | Microwave Ovens
Oct 31, 2006 | GE JVM1840 Microwave Oven
Microwave Ovens Logo
43 people viewed this question
Top Emerson Microwave Ovens Experts
William Miller
William Miller
Devabhakthuni...
Devabhakthuni...
Jerry Greenberg
Jerry Greenberg
Are you an Emerson Microwave Oven Expert? Answer questions, earn points and help others
