TV died? TV was buzzing and black when I came back into room. It had been working fine. Unplugged and replugged, changed power strip. Buttons don't work on the TV.
    Top Expert:
  • Televison & ... Master
  • 74,383 Answers
LOT fault. Check the horizontal output circuit. Check horizontal output transistor. If this transistor is faulty, this kind of buzz sound can occur.
Posted on Apr 27, 2013
Testimonial: "Thanks, Gopa, but I am not a tech-type and the only person in this tiny town says you can't get parts for a TV this old anymore. Maybe he just doesn't want to deal with it. Thanks for your input, I wish I could fix it myself."
SOURCE: Help K2001UM TV
I'ts possible that by accident someone activated the parental lockout. Your best bet is to locate your instruction manual and find the default code. Also problems(usually with software) can cause the the tv to do unusual things. Leave the set unplugged for at least 24 hours, the see if there is a response with the buttons on the tv. You may be able to reset the set to factory defaults. Scrivitron
Posted on Jul 09, 2007
buggyme
  • 28 Answers
SOURCE: TV will not power up. Makes a buzzing sound when plugged back in
Replace the Flyback Transformer.
Posted on Feb 03, 2009
SOURCE: my 36' RCA TV JUST QUIT WORKING. TURNED ON POWER
my 36" rca green light blinks 3 times, no picture or sound
Posted on Jun 02, 2009
joez47
  • 61 Answers
SOURCE: power surge-no picture or sound, just red blinking power light
Any malfunction associated with a blinking redlight usually indicates a circuit problem or defective component. Unfortunately, the days of taking off the back cover of your TV and replacing a defective tube or fuse are long gone. Proper servicing will require troubleshooting procedures that can only be performed by a qualified electronic repair facility or professional television repair person. Ask for an estimate and a realistic appraisal of whether the set can be adequately fixed. Depending on the age and condition of your TV it may not be cost effective to repair.
Posted on Sep 13, 2009
  • 69 Answers
SOURCE: my TV for the past week has periodically only
there is a bad connection at the vertical output ic.
you can try to resolder it
Posted on Apr 09, 2010
No picture on TV
Not sure if you saw Tom's Guide
at Sharp lcd tv power button flashing
(1) 4tinyhearts said:
I unplugged the TV and held the buttons down and it continued to flash. I continued to hold down the two buttons and replugged it in again and it worked. TV back up and working.
(2) lastditcheffort said:
Unplugged it. After looking for a new tv online I decided to try getting it to work. So, plugged it back in and held down the power button, a red light came on, held down the power button again and an orange light came on, held down power button again and green light came on and tv powered on. This was simply a case of trial and success!
(3) Nateinportland said :
unplug, hold power button, plug in. If that doesn't work, unplug all the HDMI cables, unplug the power, hold power button, plug back in.
Jun 04, 2016 | Sharp Aquos Televison & Video
Vizio sound bar 2.0 remote control not working
After only three days I would take it back, or at least take the remote back and try it on a different sound bar.
Jun 14, 2014 | Vizio VO47L 47 in. LCD TV
Magnavox issues
It sounds that the Line Output Transformer has damaged. Check the horizontal output section circuit for fault.
Apr 26, 2013 | Televison & Video
I just moving my tv from different room and stop working no power.
Check the power source?Tries unplug,replug the tv back like an hour later.The tv now is resetting itself back to the factory setting.The tv should be working now.If still have no power,than some how ur power supply board got shorted and died.Tries websites like Shopjimmy.com,Ebay.com to buy a whole refurbish power supply board for the replacement.
Nov 15, 2010 | LG 42LC2D 42 in. LCD HDTV
None of the buttons are working; unplugged and
Depending on the model its down to the keypad
Feb 12, 2010 | Panasonic Microwave Ovens
Remote control and buttons on top of tv wont work!
you unplugged the front panel with the buttons on it and the remote reciever
you have to slide the chassis out
reach in to the front and replug the front panel to the plug from the main board
then slide all boards back in place
Aug 26, 2009 | Sony KV-35V42 35" TV
Mitsubishi WS65611 no remote function & panel buttons not working
This TV is known for the buttons going bad. You can remove the speaker grille to gain access to the wires for the panel. You may have to pull off the font access panel to get to the connector. There will be two of them, one for the input, other for the control panel buttons. If the buttons are bad, unhooking them will make the TV work fine with remote. I believe the connector is labeled ZR and is not the one with the thicker black wires (shieled video wires). Unhooking is my fix for this problem as replacing the buttons seems to be only a temporary fix.
Dec 04, 2008 | Mitsubishi WS-65611 65" Rear Projection...
Printer doesnot Power On (no power surges either)
In case of Power Failures / Surges.....we should first check if the h/w of the printer has gone Bad... Try the following in the specified order... 1. Unplug the power cable at the back of the printer and replug it and then press the "ON" button on the printer to check if it works else... 2. Unplug the power cable from the surge protector (if you are using one) and replug it and then press "ON" button else just try unplugging from the wall jack and replug the cable (if you are not using a surge). 3. Else , Try a different wall jack 4. You may even try taking the printer to a different room and then check if you get some power. Now if the printer powers up but the "startup cycle" continues...it needs a "semi full reset" to do that-> 5. unplug the power at the back of the printer and 6. press # and "6" at the same time on the front panel 7. while holding these two buttons , replug the power at the back and keep holding till you see "semi full reset" on the screen 8. Now release the buttons and let the reset complete...you may be prompted to enter the language again etc.... Even if this doesnot work...try a "full reset" 9. Which is done by pressing "#" and "9" simultaneously with the same procedure Else the firmware(program inside the printer) has gone bad and may need replacement I got this valuable information from the engineers of ***
Jan 23, 2007 | HP OfficeJet 7410 All-In-One InkJet...
Televison & Video Logo
42 people viewed this question
Top Televison & Video Experts
Electro Med Services...
